When were touchpads first used? - Computers & Internet
  • 103 Answers
In 1982 Apollo Computers had a touchpad on the right side of the keyboard
Posted on Jan 20, 2013
My touchpad on acer aspire 5735z will not work
Click "Start." Click "Control Panel" in the right panel. Click "Accessibility Options." Clear the boxes next to "Use Sticky Keys," "Use FilterKeys" and "Use ToggleKeys." Click "OK" to unlock the keyboard, including the keypad. Unlock Touchpad Click "Start," then "Control Panel." Click "hardware and Sound," then "Mouse." Click the "Touchpad" tab. Click "Default" under the "Touchpad" tab to reset the touchpad to its original settings.
Apr 08, 2013 | Acer Aspire Computers & Internet
Cursor problem
Disabling the touchpad on a Dell Inspiron can be useful when typing for long periods of time, or using an external mouse. Bumping or tapping the touchpad while typing can cause cursor jumping and unwanted results. Use the touchpad software to enable or disable touchpad controls. Download the driver for your touchpad at the Dell Support website.
Click on the "Touchpad" icon in the task bar. If the icon doesn't appear, you can download and install the driver for the touchpad from the Dell website, or choose "Start" and "Control Panel." Choose "Device Select" on the touchpad menu, or choose "Mouse" in the "Control Panel" menu and "Device Select." Click "Disable" under "Touchpad" to turn off the touchpad, or click "Disable Touchpad/Pointing Stick When a USB Mouse is Connected."
h
Feb 28, 2013 | Computers & Internet
How do i scroll down using a touchpad? im used to the scroll wheel on my old mouse
it depends what brand product you are using. for most touchpads you just drag two fingers next to eachother on the touchpad and it will scroll up and down. for some others you just drag one finger along the edge of the touchpad
Jan 20, 2013 | Computers & Internet
My touch pad on the Acer Aspire 5532 laptop doesn't work. how can i fix it?
Unlock Touchpad
hope this helps
Aug 17, 2012 | Synaptics PS/2 Port TouchPad
Dell Inspiron N5040 touchpad not working while charging
If battery works and ac adapter has problems that means electrolytic capacitors maybe dried up(not supplying the current needed to run the laptop) and has to be cured by using the laptop more often.
Apr 13, 2012 | Dell Inspiron Computers & Internet
I am using HP ELITEBOOK 8460p latop. My touch light glows automaticllay and unable use the touchpad. Please help me
You might have disabled the touchpad accidentally. If the touchpad is disabled it is indicated by a yellow LED on upper left corner of the touchpad and when the TouchPad is active, the light is off.
To turn the TouchPad on, quickly double-tap the TouchPad off indicator (the yellow LED).
Hope it helps!
CreativeTECH
Sep 20, 2011 | HEWLETT-PACKARD EliteBook 8460p Notebook
Where is the touchpad lock on the Hp probook laptop.
Hi.
Turn off the touchpad Most HP notebooks come with an on/off button near the touchpad. If you do not wish to use the touchpad at this time, press this button. Press it again when you wish to use this accessory again. If the notebook does not have an on/off button for the touchpad, touch and hold the top-left corner of the touchpad for approximately 5 seconds to disable it and do this again to activate it. When the touchpad is disabled, a small light will illuminate on the touchpad and an icon will appear briefly of the touchpad with a line through it. When the touchpad is activated, a small light will turn off on the touchpad and an icon will appear briefly of the touchpad. Alternatively, if the notebook does not have an on/off button for the touchpad, and you wish to turn the touchpad off, open the Mouse Properties window, select the Device Settings tab, and click the Disable button. You may re-enable the touchpad from here at any point.
Regards.
Sep 05, 2011 | HEWLETT-PACKARD ProBook 4520s Notebook
Dell inspiron mini 10 touchpad frozen and I can not log on
Hi slimmerkitty...
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time(F1,F2,F3) and then attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
Please take time to rate me
Sep 05, 2011 | Computers & Internet
My loptop touchpad (mouse) had a problem, it's lock i didnt know how to open it again..
Hi
If unsure which Function key enables and disables the touchpad, try each one at a time and then
Sep 04, 2011 | IBM ThinkPad T43 Notebook
Touchpad is not responding correctly
The touchpad of your laptop is a most important and frequently used input device. If your touchpad stops functioning, it may be difficult for you to use your laptop.
To fix your touchpad, follow the information from this link.
Dec 30, 2010 | Dell F3534 Touchpad
Computers & Internet Logo
339 people viewed this question
David Payne
David Payne
