Question about Zanussi FS1255S Front Load Washer
Starts and then ends after about 1 min without doing anything
When you press start the start and washing light comes on and the door locks but after about 1 or 2 minutes the program ends and the door unlocks again. Any ideas guys?
  • richard jones Jul 17, 2007
    Thanks, all it turned out to be was some debris blocking the pump and stopping it from spinning, I know its an easy fix but the missus is quite impressed.
    You were on the right track with the pump, thanks anyway.
Wire off the circulating pump or faulty door switch if you gis a bell on 01132570737 we can go through it with u we do a lot of work with zanussi washers and are willing to help
Posted on Jul 17, 2007
6ya staff
SOURCE:
I have an aeg washer dryer L87695NWD which is stuck on drying. When I turn the button to select a washing program the drying light stays on, and the washing light is still off.. what can I do?
From user manual:
10.4 At the end of the drying programme
1. The appliance stops automatically.
2. The acoustic signals operate (if they are active).
3. In the display (number "0") comes on.
4. The indicator of button Start/Pause goes off.
5. The last minutes of the drying cycle the appliance performs the
anticrease phase. The anti-crease symbol ietounus3lrwasi2ko2vq2k81km1my9gxk62inwk5r2qaaaabjru5erkjggga=flashes. The
door is still locked (the key ezfxrjud2vanwq0oeawt0sih4u7drnvleuvj3nru5hkbv+p2lq2ra1xbwbjeddwhka3byaaaaasuvork5cyiiasymbol is on).
6. Press button On/Off for some seconds to deactivate the
appliance. After some minutes from the end of the programme,
the energy saving function automatically deactivates the
appliance.
7. When the door locked light goes off you can open the door.
8. Remove the laundry from the appliance. Make sure that the drum
is empty.
9. Keep the door ajar, to prevent mildew and odours.
10. Close the water tap.
If this doesn't help than check:
- If the delay start is set, cancel the setting or wait for the end of
countdown.
- Deactivate the Child Lock function if it is on
If anything of this doesn't help then pay attention to all the symbols appears on the display and check what it means in the user manual.
Dado
Apr 01, 2017 | AEG Washing Machines
After washing a load there remained 1 min and the door would not unlock. I manually unlock the door, load was spun out, but could not get another load started.
you couldnt wait 1 minute??,now you need to check alignment of the door lock and switch,make sure that the lock works and all the door switches are aligned
May 18, 2015 | Kenmore HE2 Plus Front Load Washer
Ge 9 min light flashing
I broke down and had a technician come and fix it for me. It ended up being a loose wire in the panel.
Apr 22, 2013 | GE WBSE3120B Top Load Washer
Aq9l292i not starting
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
Apr 17, 2013 | Hotpoint Washing Machines
Opening the door after a wash
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped.
Mar 18, 2013 | Bosch Logixx WFT 2806 Front Load...
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Maytag neptune washer
Doesn't your unit have a lock light in addition to an on light? On mine when you start the machine a red light comes on, then after a minute or two the lock light above it comes on. Once the lock light lights, the machine shouldn't stop. If only the initial light comes on, the door isn't locking. As a result, as the drum moves the clothes and they push against the unlocked door, it turns the machine off. You might need to check/tighten the door latch. Also check the door wax motor/door lock assembly.
Dec 10, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Wash cycle will not start
the door interlock is faulty, hit the door handle area with the palm of your hand, make sure machine is turned off 5 mins before hand. Replace door lock IRE bye.PS it should open when you hit it bye again. remember the palm of your hand
Nov 02, 2007 | Whirlpool GHW9200L Front Load Washer
Zanussi FS1255S Front Load Washer Logo
197 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
