Question about Shimano Rod & Reel Storagereel Covers
I have just bought a new Shimano Aerocast 300XH Rod. Battling to assemble the three parts. Very very tight and stiff, and i do not want to force it! Any advise on what to do?
Marcperkins@vodamail.co.za
    New Friend:
  • 37 Answers
You're right, you shouldn't force it. I would first try lubricating the parts. If that doesn't work, your best bet is to contact the manufacturer. It's possible that the item is faulty, but more likely you might be missing a step or two in the assembly process.
Posted on Feb 21, 2013
Where can I find Shimano 4000D parts RD 13537 Bail Trip Strike RD 13535 Bail Assembly RD 10391 Bail Trip Caver RD 10753 Bail Spring RD 13531 Bail Trip Lever
This belongs in Fishing Reels, but why not either Google "Shimano Reel parts" or just buy a new one?
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
May 02, 2017 | Shimano Cycling
Exploded view of parts diagram for shimano tourney st-ef40 shifters for re-assembly?
If you can't find with a search for st-ef40 diagram or on the Shimano site then it does not exist. Although not identical carefully disassembling the other shifter may give you enough insight.
Apr 08, 2015 | Shimano Tourney ST-EF40 3x7 Speed Brake...
Parts assembly diagram
Shimano Tourney parts are one of their lower end component groups and as such are not really designed to be serviceable. Shimano uses a system of "controlled obsolescence" so that their components cannot be repaired. they are inexpensive enough to just replace them, and with all of the plastic that they use these days it's not worth the effort when a new derailleur can be had for $30.
Apr 08, 2015 | Shimano Tourney ST-EF40 EZ-F 2-Finger...
How do I install a new latch assembly on my D4C Rainbow vacuum?
If you have the part already first you need to push out a small hinge rod from the side of the latch. Be careful may take a little force to get it out part way then grasp with a pliers to pull it the rest of the way out. To reinstall the new latch push the rod back in through the latch the same way you took the old one out.
Aug 26, 2014 | Vacuums
I can only get 4 gears on a Shimano 7 speed. Shifter lever will only move three times.
Could be just an over-tight cable.. or the limit screws at the gear end over-tightened so that the selector does not transverse the full width of the gear cluster cassette...
Apr 09, 2014 | Shimano Deore Xt Thumb Shifters 7...
I am using a new shimano 6603 SL braze on derailluer with a fairly new, but in good shape shimano 6603-G crankset, but an older 6510 triple shifter, all with a 9 speed chain. Shifting onto the middle and...
It is hard to tell via the Internet. I suggest that you take it to a bike shop. They will get it shifting smooth, and, if not tell you what is wrong.
Jul 22, 2011 | Shimano Ultegra ST-6603
I bought a new tire rod end, should any part of the tie rod move? Because the one that I bought is very stiff.
The ball joint of a new end will be tight, but it will rotate if you push it hard enough. After screwing it onto the tie rod, you will have to force it into the hole on the steering knuckle of the hub. It will rotate as needed when you tighten the castle nut onto the end. If you are/were careful not to move the locking nut on the tie rod, you may be able to avoid getting an alignment, but it's always best to get an alignment after doing suspension work. If the ball joint has a grease fitting, make sure you grease it up with a grease gun. Sometimes the grease fitting is not installed, so you have to screw it in yourself. Please let me know if you have more questions.
Jun 10, 2011 | 1999 Pontiac Grand Prix
Can i replace a tie rod {inner} on a 94 ford mustang , drivers side without taking off rack and pinion. I need to get a roll pin off the inner tie rod and thats the problem it looks pressed in not set...
Real simple, assuming you know how to take the outer tie rods off. You have to take the clip that holds the plastic boot on off, then slide back the plastic boot, and you'll be able to unscrew the whole inner tie rod assembly. The hardest part of the whole process is installing the new ones to the exact settings of the old ones
Mar 13, 2010 | 1994 Ford Mustang
SHIMANO FISHING REEL
The drag is set by turning the knob which secures the spool to the reel.
To cast, hold the line against the rod with index finger on right hand. Then flip the bail open which frees the line to come off the spool. The bail, when it gets to a certain point will lock open. When casting, release your finger on the line when the rod gets to 11 o'clock.
Flip the bail back by turning the reel handle -- the bail will pop back over the reel -- then you're ready to reel it in.
The bail is the wire-like device on the top of the reel.
There is probably a button/switch for turning anti-reverse on & off -- when on, this keeps the reel from turning backwards when force is applied to the line.
I think those are the highlights.
Charlie
Sep 10, 2009 | Shimano REELS TYR20 Tyrnos Lever Drag...
Hoover windtunnel U6476-910 switch doesn't work
What has worked for me on this vacuum is once the handle is off and the on-off switch is visible, work it back and forth manually.  Mine was very stiff and it did not get any better.   I went to radio shack and bought a spray can of Control/Contact Cleaner and Lubricant. It comes with a small piece of tubing.  I put the tube into the top edge of the switch and pushed the button FOR A FRACTION OF A SECOND and then did the bottom edge of the switch.   I worked the switch manually a couple of times.   I repeated the spraying one more time and the rocking.   I put it all back together and has been working fine for me.   This stuff is made for electrical contacts...  HOWEVER, use it very very sparingly!!!  ALSO, a new can has a bit of pressure so watch out that you don't blow some back at you.   JOE
Oct 05, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Shimano Rod & Reel Storagereel Covers Logo
89 people viewed this question
Top Shimano Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
John
Are you a Shimano Fishing Expert? Answer questions, earn points and help others
