What is a digital note taking pen? - Computers & Internet
    New Friend:
  • 103 Answers
It lets you write notes in your own handwriting on any regular piece of paper, then a receiver 'copies' the notes and when you plug the receiver into a USB you can put your notes on the computer, ipad, etc
Posted on Jan 20, 2013
S Pen for my Samsung Note 3 stopped working how can I fix it
Samsung Galaxy Note 3: S Pen stopped working on screen:
Hello. The S Pen is not powered by a battery per se. The screen on your phone generates a magnetic field. There's a coil inside the S Pen that captures energy from the field to power the pen.
1. Question are your S Pen options turned off?
Settings>Controls>S Pen>
turn on Direct Pen Input
turn on Air Command
turn on Air View
etc..
2. it could be the pen tip that is worn out and needs to be changed. Check the tip by pressing it into the pen with your finger.. if you feel the tip going into the pen too far, it's probably the tip that is broken or worn out. Some customers say buying new tips is too much trouble, and getting a new OEM Samsung S Pen made for your Note 3 is a safer option.
3. it could be the wacom digitizer screen that is having problems on your phone and needs to be fixed. If you had fixed the screen prior, it could mean the person who installed the replacement screen could have did a bad job.
4. if you are using a magnet closure case, try taking it off and then using your S Pen. Because the external case magnet can interrupt the magnetic field the S Pen uses for power rendering it useless, until you remove the magnetic closing case.. and then all should be well again.
5. You can do tests on Note 3's that are not carrier locked by dialing *#0*# (this is not a solution but it can help eliminate possibilities)
DIAGNOSTIC TEST your Pen for Samsung Galaxy Note 3
6. If you bought an Aftermarket knockoff S Pen, that's probably the problem right there. A lot of non OEM Samsung S Pen's have their own issues and work for only some things.
7. You can try fixing the sensitivity of the S Pen
8. Buy an original Samsung Galaxy S Pen. A Note 1, 2, 4, or Note 5 S Pen will work for your Note 3, but it may not fit inside the Note 3's internal compartment/holder. You can try buying a used one to save money, but be aware that you might have to change the tip
Feb 08, 2016 | Samsung Galaxy Note 3
The pen on my Samsung Galaxy tab 3 only works sporadically. ..... it'll start recognising threw pen when it's about 2 inches away from the tablet...... there are some spots. .....s note mainly. ..... that...
you mean galaxy note 3 .first be sure the pen has a nib in it not a hole where one has fallen out. then it is about 1/16th or so outof the pen and rounded next try replacing the pen nib your phone came with a packet of replacements. they pull out and are snapped back in. Last and for sure , there is actually a battery inside the pen if it is old and weak you will have to get another pen say from ebay (best price) but before you do go to phone store and use one of theirs to test . if you have the same problem and only certain spots do not work on the screen then your digitizer screen is in need of replacement. also another ebay cheapest item. but whatever it turns out to be it is fixable. come back if you need advice will check every couple weeks.
So pen has nib , or nib needs replacement,pen has weak battery and need replacement or digitizer needs replacement. all solutions are under 100 dollars most under 50 . no nibs or bad nibs under 15.
Dec 23, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
How many 1.2 ML in 18 MG?
Hello there,
Note First that One Millitre is the SAME as One Milligram
Well, if you look at this guide here.. http://www.novo-pi.com/victoza.pdf#guide
It says quite clearly that.
'Your Victoza pen contains 3 mL of Victoza and will deliver doses of 0.6 mg, 1.2 mg or 1.8 mg.
The number of doses that you can take with a Victoza pen depends on the dose of medicine that is prescribed for you. Your healthcare provider will tell you how much Victoza to take.
You take 1.2 mg per day so you will get two doses per pen.
So you need one pen every two days so you need 15 pens.for 30 days.
Sep 20, 2014 | Office Equipment & Supplies
Do digital pens have other colors of ink or are they all the same?
You can buy replacement ink cartridges for your digital pens, but while you are writing you can only have one ink cartridge in the pen.
Sep 30, 2013 | Computers & Internet
Where can I buy a livescribe smartpen for digital note taking?
You can get a livescribe smartpen online at Amazon or ebay, staples also carries the pens in their stores as well as some apple stores.
How much does a digital pen cost?
Digital note taking pens are pretty expensive because the technology is still fairly new. They start at around $100 and the best ones cost closer to $200.
Do i need special paper to use with my digital note taking pen?
no, you can just use regular paper. what is important is that you have the digital pen and the receiver
Jan 20, 2013 | Computers & Internet
How to use the Medion Digital Notepad
With my medion digital notebookproblems with the pen instead of writing left to right, it rights on the right to the bottom of the page on the right can you help please as well
Jan 02, 2008 | Computers & Internet
Computers & Internet Logo
1,116 people viewed this question
David Payne
David Payne
