Question about Kitchen Ranges
Traditional Stove DBL2000A-MS3R Operating Manual
Need a manual for new house owner
fridgetech
  • 473 Answers
SOURCE: MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Posted on Nov 18, 2007
jsrock516
  • 5911 Answers
SOURCE: cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Posted on Feb 16, 2008
aborcass
  • 2651 Answers
SOURCE: need an owners manual
here it is
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318200506en.pdf
Posted on Apr 04, 2008
SOURCE: Tappan Series 110 Gas Stove Owners Manual
stovetop works well, oven will not ignite. Whats up?
Posted on Oct 03, 2008
  • 19 Answers
SOURCE: I NEED A OWNERS MANUAL
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=gr478lxpt&siteCd=WHRCOM
Posted on Apr 28, 2009
Would like to buy operation manual for mod#970C653520 ser#VF34276106
The 970C653520 electric range was built by Frigidaire with the Kenmore name. Frigidaire has the manual on the support page: http://b2b.frigidaire.com/support/manuals.asp . Just enter the model number in the Search box. The current direct link to the Owner's Guide is ftp://ftp.electrolux-na.com/ProdInfo_PDF/Springfield/316902151en.pdf .
I hope this helps.
Jan 29, 2016 | Kenmore Kitchen Ranges
What are the pros and cons of operating the Quadrafire Mt Vernon AE pellet stove in manual mode?
They probably cannot suggest running it on 'manual' due to liability reasons....leaving home for an extended time and forgetting its on manual...comes to mind.
What may be suggested is to make sure ANY and ALL safety controls still function to shut off fuel (pellet) flow in the manual mode as an extended overtemp condition is the first thing that comes to mind when you think of damage to a heating system or to the structure within which it is installed.
I think its a judgement call on your part once you determine you pretty well KNOW the full and complete operation of the device. The key to that statement is KNOWING WITHOUT A DOUBT the FULL operation of the system.
I also would NEVER recommend to a customer to operate it in the manual position.
Mar 25, 2015 | Heating & Cooling
Light bulb above stove under microwave hood
According to the GE manual it is a 120 v 20 watt halogen bulb, the GE product number is WB36X10213. That is the cooktop light/nightlight that would be on the stove hood. HTH!
Sep 25, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
Need a owners manual for IBM G41 2886
There is no traditional user manual for this model:
http://support.lenovo.com/en_US/guides-and-manuals/detail.page?DocID=UM002042
Service and Troubleshooting guide
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/92p2196.pdf
Hardware Service Manual:
http://tim.id.au/laptops/lenovo/thinkpad%20g40%20g41.pdf
Also check out this site for great info on Thinkpads:
http://www.thinkwiki.org/wiki/Category:G41
Dec 31, 2011 | Computers & Internet
Hi, Have bought new house with a Ultimate Supreme 18 solid fuel wood heater and need info or user manual - where can I get a copy of details on line? Many thanx, Sue
Sue, the Owners Manual for your stove is really hard to find. Almost impossible, because it manufactured and sold only in Australia. However, I have located a dealer of the Supreme line that should be able to provide you with an Owners Manual. Their email address is TREESquared@hotmail.com
Mar 23, 2011 | Heating & Cooling
I need the owners manual for the GE stove/oven model # JHC56 OV4W11 and also need to find a filter (# WB2X3022) for the vent on the stove.
Owners manual is here: http://genet.geappliances.com/DocSearch/pdf/49-4629.PDF
You can probably find the part by using google -- I am about to buy a switch for a similar range.
Dec 17, 2010 | General Electric Stove/Oven/Range Chrome...
I HAVE A BIFLAME FLAME EFFECT STOVE THAT LOOKS LIKE THE MOTOR HAS GONE AS THE FLAME EFFECT SPINDLE IS NOT TURNING BUT EVERYTHING ELSE IS OK.WHERE CAN I GET A MOTOR FOR IT.MODEL DBL2000A-MS3R
Hi
i have found a seller in China who is posting 2 motors to me at a cost of $80 including DHL Shipping.
I ordered two so i have a spare if it goes again as nobody in the UK Sells them.
email him at Zq_qle@yahoo.com.cn
Your motor will be a TY-50A the same as mine.
Hope this helps
Paul
Nov 04, 2010 | Heating & Cooling
Kitchen Ranges Logo
175 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
