Question about Canon SmartBase MP360 All-In-One InkJet Printer
The Waste Ink tank is full
How do I locate and empty the waste ink tank? I am unable to print at the moment due to this issue. An error ##343 is showing on the display.
  • 1 more comment
  • karen_and Mar 02, 2009
    Hi DJ,
    Thanks for sending info through, unfortunately I couldn't access the website with the address you gave me, pls could you check this and advise?
    Many thanks,
    A.
  • distinguishe Mar 03, 2009
    The waste Ink tank from my priter is full, how do I Iocate this tank
    product is Canon smartbase mp 360/370
  • BeccyA Mar 07, 2009
    Hello I have the same probem re the wate ink tank on my excellent smartbase 360. Can anyone help? thanks
Go to www.neilslade.com/papers/inkjetstuffll..htl
scroll down to 370
CAREFULLY FOLLOW INSTUCTIONS
1st remove USB cable
take your time BETWEEN OPPS
print out ???????????????????????instruions FIRST
hit the red triangle followed by scan copy scan
you should now be in service mode
now slow down it is not fast
dj
PS your tank is a bin and could over-FLOW on to your nice sheep skin RUG=warning
Posted on Feb 04, 2009
  • wotaheadack Feb 04, 2009
    pps its not a tank but a set spunges that collects cleaning ink which happen each time you turn on the mc/n.
    there on the safeside===its @ the bottem of the thing and is a BA---
    toget @ shoud be????????????????????????/ OK TILL next time.
    put the SUNDAY TIMES underneath
  • wotaheadack Mar 03, 2009
    http://www.neilslade.com/Papers/inkjetst...
    This is the correct code procedure for resetting the Canon MP370
    (and hopefully other similar designated models
    1) Printer on, press Additional Functions, Scan, Copy, Scan. Now you should be in service mode from there for waste ink tank reset it is simalar to what has already been posted
    2) Select Test mode which is like the last available selection
    3) Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
    4) The menu will now say EEPRON Clear. Select Ink count which is option (0) and press set
    5) Select Ink count which is option (0) and press set.
I have just performed the following procedure, which has caused the warning sign WASTE TANK NEARLY FULL to cease display.
1. Disconnect USB cable.
2. Place newspaper under machine.
3. Press the small black button with a star inside a white circle sign above it, followed by Scan Copy Scan
4. The display now says SERVICE MODE #1 SSSW
5. Press + until TEST MODE is displayed
6. Press OK. Then TEST MODE [1] - [9] is displayed with 1.D-RAM below it.
7. Press + until #8 PRINTER TEST appears in the display.
8. Press OK. PLEASE WAIT is now displayed.
9. The machine makes some noises and after a while - 8-1 - and then - 8-2 - is displayed. After the machine has made its starting noise and movement a couple of times,
10. Press +. - 8-3 - is now displayed.
11.Press OK. -8-3- EEPROM CLEAR [0] INK COUNT is now displayed.
12. Press OK. 8: PRINTER TEST -8-3+ is now displayed.
13. Press the orange triangle button and the display reverts to the normal one without the WASTE INK NEARLY FULL sign flashing at you.
Posted on Mar 25, 2009
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
How do I reset waste ink tank full on Smartbase mp390?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Jan 05, 2010 | Canon SmartBase MP390 All-In-One InkJet...
Tank for used ink is full - how do I change it?
Dec 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Absorber tank is full
Dec 01, 2009 | Canon Office Equipment & Supplies
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
Reload the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Error ##343 and it didn't print anything Orange light below screen has been flashing, screen message "Waste Ink Nearly Full". No idea where waste ink container is kept? Have changed cartridges. Now saying...
Manual Reset procedure Waste Ink Tank for Canon MP390:
  1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode (must be the last available selection).
  3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
  4. The menu will now say EEPROM Clear
  5. Select Ink count which is option (0) and press set
  6. Press Stop/Reset Followed by the power button and then wait for it to restart.
hope it helps
cheers
Jun 09, 2008 | Canon SmartBase MP390 All-In-One InkJet...
CANON MP730 ERROR MESSAGE 343 WASTE INK FULL
1-press the "menu" key
2-press the"copy" key
3-press the"#" key
scroll thru the menu heading until you come to "counter"
press "ok"
press "menu"
and select "clear all" it will ask you to "please wait"
then press menu two times
restart your printer
it will work
Feb 22, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Open Questions:
See all Canon SmartBase MP360 All-In-One InkJet Printer Questions
Canon SmartBase MP360 All-In-One InkJet Printer Logo
493 people viewed this question
old marine
old marine
