Question about HEWLETT-PACKARD Hewlett Packard 448337-001 - HP 520 Series Intel Chipset Celeron M Based Laptop Motherboard (System Board)
Public wireless conection unable to connect
My hp 520 laptop does not work wireless connection. It display no wireless connection available. But the public wireless connection there.
  • HEWLETT-PACKARD Master
  • 3,606 Answers
Hello It`s probably your wireless router that`s not working, or you could be too far away from the antenna.
Is the power supply working, for the router, are the cable set right, is the router on, are your internet connection working.
You can take the router, to a computer repair shop and let them test it.
The router must be connected like this:
But the wireless setup code for it, is different from one router to another.
If the wireless is working elsewhere, the pc is not the issue.
Good luck
Posted on Jan 21, 2013
How to retreve my wifi
Enable the wireless network card on the laptop.
Some laptops use a physical switch on the front or side of the computer to enable and disable the wireless card.
Most newer laptops use a software switch that can be toggled with a couple of keys on the keyboard.
The most common software switch toggle is by pressing the "Fn" key and "F2" at the same times.
Click the wireless icon by the clock in the lower-right corner.
Click on an available wireless hotspot.
Stronger signals are represented with more and longer bars.
Click the "Connect" button.
Enter a password, if required.
Click on Home, Work or Public when the dialog box appears.
Each of these three options represents different security levels.
When connecting to a public Wi-Fi hotspot, always select "Public."
Hope this helps.
Nov 19, 2012 | Computers & Internet
Does not not conect to the wireless network
Check for a wireless button/switch on your laptop. Sometimes it gets turned off.
Were you on the wireless network before? If so, what changed?
Are you able to connect to public wireless networks?
Feb 22, 2012 | Toshiba Satellite M45-S2653 Notebook
I recently reformatted my IBM (2003) and re-installed the dwl-520 adapter and for the life of me it is not allowing me to connect to the internet. It is not pulling up all other wireless networks. I...
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Apr 24, 2011 | D-Link Air DWL 520 802.11b (DWL-520)...
My hp mini 110 will not wirelessly connect to the itnernet. it is the same network that my old laptop connected too,but it says it is unable to conncect. now it shows that there is not network available....
Did you see a switch on the side of the HP machine or a key on the keyboard with a wireless symbol? Turn on that switch or press the key to get wireless adapter started. Then try again to search for wireless networks. Please post if the issue persists and I will help on that.
Nov 26, 2010 | HP Mini 1000 Netbook
I'm unable to connect to my push2tv netgear box. I could connect fine with my Toshiba Sattelite (Best Buy Blue model). However, I'm unable to connect with a Toshiba Sattelite M645-S4070. It has Win 7...
Sounds like you have a firewall problem either with the Windows 7 built-in firewall or an anti-virus application firewall. Do you have an Anti Virus program installed?
Nov 24, 2010 | NetGear Push2TV TV Adapter for Intel...
Wireless quit working on Hp PV9720 laptop. Wireless button is on (and light is blue indicating it is on).
Turn your wireless router off.
Wait 13 seconds.
Turn your wireless router on.
Try again to make a wireless connection.
Find a friend with an iPod Touch or iPhone or laptop,
and see if they can make a wireless connection to your router.
If not, your router is the problem (maybe, it needs to be configured?).
Take your laptop to someplace (public library or Starbucks) that offers "free wireless". Can you connect your laptop to that network? If so, your laptop's hardware is OK.
Sep 30, 2010 | HP Pavilion dv9720us Notebook
I am unable to connect to the internet using a wireless connectio
I would first try and reset the router, then run a Repair on the connection again.
If this doesn't work, try going into the Device Manager and removing the Wireless Device. Restart the computer and reinstall the Wireless Device drivers.
Jan 26, 2010 | Intel S6240 Notebook
Picks up wireless network but unable to connect to the internet. I am trying to connect to the wireless on a laptop and a phone, both work fine else where but i am unable to connect to the internet using...
what is the wireless status in system tray? is it local or local and internet.
1. first check if it works fine with wire conection or not.
2.if it fine with cable then issue is with wireless. probably issue with Wireless security key.
3. go to available wireless networks and select the net work, if it is asking for wireless key please enter that. if you donot remember that perform router reset.that takes care of it.
Sep 24, 2009 | Linksys Wireless-G WRT54G Router
I am having troube getting my emachine laptop 5310 to connect to the internet it says it has WIFI do I need an adapter or something else to connect to it?
Your laptop has lan access go here for directions on how to use it.
http://downloads.emachines.com/userguides/Wireless_Supplement_AACR53700002K1_Online_en.pdf
Jul 13, 2009 | E-Machines M5105 Notebook
Trying to set up wireless from desktop (Main ethernet computer) to Laptop @ home. Have cable modem (comcast) connected to desktop (main ethernet plugged computer)Belkin Wireless Router G ethernet is hooked...
Check that the wireless drivers are installed properly on both your laptop and desktop. THe certificate error is because your laptop does not "trust" your computer. Under network conections click add a connection ec, and when you try to conect, microsoft should ask you weva to trust the connections from computer to computer that should do it :D
Sep 07, 2008 | Belkin Computers & Internet
HEWLETT-PACKARD Hewlett Packard 448337-001 - HP 520 Series Intel Chipset Celeron M Based Laptop Motherboard (System Board) Logo
55 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
