Question about Salter Brecknell-200-ES (200ES) Stainless Steel LED Indicator Display
How do i resolve a problem when d display is just 888888
I powered the indicator on but it can only display is 888888
Invalid header
You are seeing the "Invalid Header" message on the LCD display on the T2250 because the pritner is in "boot" mode, which is the firmware download mode and is detecting data being recived is not a correct firmware file.
The most likely cause for this problem is the pritner has defaulted to 'Firmware Download Mode" due to a problem with either corruption to the firmware or damaged / faulty EEPROMS. When print jobs are sent to the pritner the pritner is expecting firmware and recognises the data it is reciving is not correct for a firmware file.
The solutions to this problem are;
  1. Power the printer OFF, disconnect the printer from the computer system, and any external print server (eg JetDirect etc). Power the printer back on, if the error is resolved check the method of connecting the printer to the computer system to ensure there is no damage to cables etc.
    If the printer displays "BOOT" on the display this indicates the printer is in firmware download mode.
  2. If the display reads BOOT first try reloading the firmware you may find details and firmware on the following web site,
    http://support.dascomeurope.com/index.php?option=com_docman&task=cat_view&gid=123&Itemid=48&lang=en
  3. If loading the firmware fails this indicates a logic board fault, the main logic board would need to be replaced to resolve the issue
Feb 18, 2011 | Tally T2250 Matrix Printer
Lcd power flame but no display, why? continue the solution how?
Hi ,
You ve got the power flame only which indicates that the power supply unit is OK, No display indicates that the Modulator Unit is malfunctioning, and with this model its just a detachable card on the motherboard, try and open it up, this should not be a problem to resolve, lets know the progress incase there are further issues
Jan 14, 2011 | LG L1915S 19" LCD Monitor
The speaker volume is too low...please can you let me know...as to what the correct settings should be to obtain the loudest sound out of the speaker...as it is too small
Reset your mobile factory setting .
Go>setting >security>factory setting>
First Try it:
Defalt phones codes(NOKIA) is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 4 Digit Security code(LG) 0000
Default 5 Digit user code(SAMSUNG): 00000
Default 6 code for (MOTOROLA)000000 or 888888)
Default 6 Digit Security code: 123456 or 000000 or 888888
Default 6 Digit Security code: 000999 or 1122
Default 6 Digit Security code(SONY ERICKSON) no number
Good by
Jan 06, 2011 | Cell Phones
What is wrong when the balance reads EEEEHI
It looks like your balance is missing some segments form the digits. It is trying to display 888888 but can nto do it. It needs to be repaired or replaced.
Sep 21, 2010 | Ohaus Compact Scales
F2 code
Hi, F2 code on the Kenmore indicates a problem with either of the control board and the user interface board. Run the console and indicators diagnostic test mode to find out.
Console and Indicators Diagnostic Test Mode Activation
  1. While in standby mode press the following button sequence within four seconds: SOIL LEVEL>WASH RINSE TEMP>SOIL LEVEL>WASH RINSE TEMP
  2. Press START within five seconds when "dt" shows on the display. All indicators in display are lit and "88" is displayed.
  3. Press START again. The two-digit display and the status indicators turn off while all other indicators remain lit.
  4. Press START again. The two-digit display and the status indicators turn on while all other indicators remain lit.
  5. Rotate the WASH CYCLE selector back and forth. The indicators will switch on an off.
  6. Press the buttons to check the functions. The indicators switch on and off and a beeping sound will be heard when a button is pressed.
  7. Press STOP or POWER button to exit diagnostic test mode.
  8. If no indicators light up or if no beeping sound is heard when a button is pressed or if some buttons do not light up indicators when pressed, check the control board, the user interface board, and the connection between them.
  • Unplug the machine.
  • Remove the three screws on the back of the console.
  • Lift the console off the cabinet.
  • The control board is located on the right side of the console viewed from the front of the machine. Disconnect the middle wiring harness connector on the right side of the control board near the pressure transducer hose.
  • Clean the connector and the terminals thoroughly with brush and alcohol.
  • Reconnect and disconnect the connector several times.
  • Reinstall the console and reconnect power.
  • If the problem is not resolved, replace the user interface board.
  • If the problem is still not resolved with the replacement of the user interface board, replace the control board. You may also replace both board at the same time and keep the old good board as a spare.
Take care
Jun 20, 2010 | Kenmore Oasis 27042 Top Load Washer
Lost Pin number
I believe the default unlock code is "888888", not "8888" Try that.
here's a very poor copy of the owner's manual:
http://www.techtalkpoint.com/downloads/A52HF-Nikkai-Digital-Receiver-Recorder.pdf
Take care,
Rob
Feb 27, 2009 | Televison & Video
Stove-top works, oven showing all 888888 across the screen
You're stove must be perfectly fine, but the thing displaying all those options may have a problem. Try to get this fixed as soon as possible.
Jan 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Phone rings to loud and everyone can hear my conversation please help
why don't u get a new one there only 79 dollars but if i was you i would keep the volume like that i rekon its good
88888
8
88888
8
8
88888
888888
8
888888
8
888888
8 8
8 8
8 8
8
8 8
8 8
Oct 21, 2008 | Samsung SGH-E630 Cellular Phone
Big Problem, Small Resolution (Or So I Hope)
Do you have any other lights or indicators on to indicate power. Sometimes the display gets accidentally turned off and looks like it has no power when it truly does
Dec 17, 2006 | Denon AVR-2805 Receiver
Salter Brecknell-200-ES (200ES) Stainless Steel LED Indicator Display Logo
Top Salter Home Security Experts
Lawrence Oravetz
Are you a Salter Home Security Expert? Answer questions, earn points and help others
