Question about Saws
I had the 7' dewalt grinder disc for metal shatter and cut my face and i lost my eye what do i need to do to file a cliam for injurys agianst dewalt with out a layer
  • 885 Answers
I'm really sorry to hear of your injuries. If you are going file a claim against a large company like Dewalt, you will need a lawyer. They have lots of them and pay them well to prove injuries aren't caused by their products. All they have to do is prove it was because you used the tool improperly, use the wrong accessory or for something it wasn't designed to do. Most lawyers will do a consultation with you for free or low cost fee to determine if you have a case or not. If you do, they usually have you sign a contract to get their payment if you do win and are awarded any damages.
Posted on Jan 23, 2013
I had the 7in metal cuting ginding disc shater and cut cut my face from my noise to my forhead and i lost eye
posted in wrong section but if you read the warnings on the device and cutting wheel its says proper protection requirements safety glasses /face shield
Jan 20, 2013 | Cars & Trucks
I have a D28110 angle grinder and I want to use a 1/8"cutting disc with it. Do I need a different guard than what it came with?
haven't heard of a different guard for the cutting disc you want to use. Most people remove the guard when using them
Sep 15, 2011 | Dewalt D28110 Heavyduty 412" Small Angle...
I want to use flap disc's on my grinder with out the threaded portion attached. What do I have to do to install them on the grinder.
flap discs can be used on a grinder the same as grinding disc and cut off wheels . You may need a centre adaptor as some flap discs are larger in the centre hole
Aug 31, 2011 | Dewalt D28402 412" (115mm) Small Angle...
Hi, I'm trying to change the fiber disc on a DeWalt DW402 but after pushing the locking button on top I'm not able to unscrew the wheel. If I turn counterclockwise the wheel turns, but it seems I...
  • 1 Check the grinder before you begin. The newer discs on rotary grinders have patented buttons that allow you to remove the disc without any tools. You may have one like that. In models like this, there's usually a spot to depress and then remove the disc.
  • 2 Turn off the grinder before you attempt to remove and change the disc on your rotary grinder. If it's battery powered, put the grinder in lock position so you can't accidentally turn it on. If it's electric, unplug the grinder from the wall.
  • 3 Look for a nut in the center of the disc. This is a give away that you need to use your special wrench. Sometimes the grinder comes with a tool necessary to loosen and remove the nut. Other times you need to use a wrench.
  • 4 Lock the wheel into place before you begin. You can find a button or switch at the side or back that allows you to do that. When you lock the wheel in place, the disc remains still as you loosen the nut in the center.
  • 5 Remove the nut in the center with either the tool provided with the grinder or a shop tool and lift the disc off your rotary grinder.
  • 6Lift the disc off the rotary grinder. If you have different discs, remember to check for the best fit. Put the nut back on a different way for different discs. Check for a rim and indentation on one side of the nut and a flat side on the other. A visual inspection of the disc for the rotary grinder gives you information about the side to use.
  • Here is a diagram of your grinder and the tool you are looking for is number 50...
    http://www.ereplacementparts.com/images/dewalt/DW402_TYPE_6.pdf
    Jun 11, 2011 | Dewalt 4 1/2" Small Angle Grinder D28402
    Is it safe to use the 41/2" hand grinder one handed?
    The danger of using a grinder single handed is that if the disk catches in the workpiece, the grinder will try to pull out of your hand and you can loose control of it and risk possible injury or damage what you are working on. This is especially dangerous if you are working off a ladder or on a height as you could loose your balance.
    When using an angle grinder you should always wear eye protection and try to keep your head to one side out of the plane of the disk avoiding sparks and possible fragments of the disk which will fly at high speed if it shatters.
    Mar 04, 2011 | Garden
    Do you need to keep grinding guard on when using a cup wire wheel on the grinder?
    Hello, W/D here.
    It's always a wiser choice to leave the guard on to help keep particles from being slung at you.
    In addition to the guard, you should also wear eye protection. I have extensive experience in industrial work, and I cannot emphasize strongly enough how important this is. Where I worked, working with a wire wheel required that the guard be in place and that the operator wear safety glasses and a face shield. An eye injury is one of the most serious accidents that can be easily avoided.
    Best regards, and work safely, --W/D--
    Feb 09, 2011 | Dewalt DW802G Heavy Duty 4 1/2 Inch High...
    I have a dewalt 4 1/2", 120V angle grinder. I am breaking the thin cutting wheels when I use them very quickly or I pull out the stamped metal ring in the center of the cutoff wheel. The RPM rating...
    If you are using these disks you need to apply very light pressure with the angle grinder and ensure you aren't putting any side pressure on the side of the disc.
    Also imagine a line at a tangent to the disk. This should be kept at a shallow angle to the work piece to prevent the edge of the metal digging into the cutting disk.
    As a rule of thumb you have the correct angle when the sparks are flying at less than 30 degrees back towards you.
    Also make sure the retaining flange nut on the angle grinder is the correct way around to grip the disk, sometimes the nut has to be reversed to grip grinding discs.
    Nov 24, 2010 | Dewalt Welding Tools
    When i lock the disc in with the wrench as tight as i can the disc still seems to spin freely, its a thin disc for metal that came with is this meant to happen and will it happen with all discs or just the...
    Well, I would make sure your arbor flanges are installed correctly. If you arent sure, I would make sure that the one with the chamfer goes on first, with the chamfer facing the tool (see picture 1). Put your disc on, and then install the locking flange (picture 2). If the disc isnt tight, flip the locking flange upside down and see if it gets tight. It is entirely possible that the disc is too thin, or the ID of the disc is too large. Let me know how this goes.
    Nov 24, 2010 | Dewalt DC410KB Heavy - Duty 4 - 1/2" 18...
    Safety Problem
    Always protect your eyes - wear only an approved eye or face shield
    Aug 27, 2008 | Dewalt DW824 5" Electric Angle Grinder
    Saws Logo
    126 people viewed this question
    Top Saws Experts
    Tom Chichester
    ray gallant
    Are you a Saw Expert? Answer questions, earn points and help others
