I bought Indesit IWD71250, in july 2012. suddenly. The machine does not drain or spin. It was repeatly filling and rinsing but not competing the cycle. The wash cycle was 10
SOURCE: indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Posted on Feb 27, 2008
  • 1073 Answers
SOURCE: washing machine not draining and spinning
check the lid switch
Posted on May 01, 2008
barkencoa
  • 3463 Answers
SOURCE: Error code F-03 Indesit wixe127
Hi.
The code F03 means the wash thermistor is open circuit.
Unfortunately, you will have to call an engineer.
Cheers.
Posted on Nov 21, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
My indesit wixl143s, fills with water normally but immediately it drains. washing movements do not start. When manually set to rinse and spin cycles it works.
I would like to know is there any fault code?
Identification of the error code using the 4 LEDs. One or more different combinations of LEDs indicates the failure.
25889772-23mqg50qavgoaobxweiobkxp-5-0.jpg Dado
Oct 02, 2015 | Indesit Washing Machines
Programs don't advance. The machine seems stuck in each mode, it will fill and wash but doesn't advance through the programs. I have to switch off and manually advance the dial to rinse, spin, drain etc
Try moving your drain hose to a different height.t may need lower than you have it. My washer did the same , Drain hose needs to be higher than the pump that drains the washer.
Aug 09, 2013 | Indesit W 123 Front Load Washer
Not competing a wash cycle or draining
A machine this old is due for replacement
Mar 11, 2017 | Speed Queen Washing Machines
My wife restarted the rinse cycle to add fabric softener. Now the cycle timer isn't working. Washer will not drain OR spin. Everytime the timer gets to the spin cycle, it agitates instead. It is a...
Lay the drain hose down to floor level, and drain of the water into something.
Then try it on spin, if it spins o/k, then the pump or filter is probably blocked.
Hope this helps.
Jan 19, 2010 | Indesit W 123 Front Load Washer
My washer will not drain...it fills up and then stops no drain no spin
hi
if it fills then stops working,no washing motor action then you may have a motor or pcb fault,check motor brushes and connections.if it works fine upto rinse and dont drain check filter for blockage or drain pipe if plumbed to sink.
Aug 02, 2009 | Indesit W 123 Front Load Washer
Hi! I have an Indesit W84TX washing machine. Lately, it has stopped working every time it reaches the rinse cycle. It seems to rinse and drain just one time before the process stops and the settings dial...
Actually, while the settings dial spins, there is also a kind of grinding/clicking sound from down where the drain port is. I checked it and there is no filter there when I open it.
Apr 05, 2009 | Indesit WA 115 Front Load Washer
Indesit washing machine
washing machine working until final drain, rinse and spin then 3 lights flashing, door lock, stain removal and extra spin.
Unable to empty machine or unlock door.
any suggestions
May 15, 2008 | Washing Machines
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Final Rinse
im a repairman and just ran into that same problem on the ge washer. the problem is the control board. That control board is expensive, but it will fix the problem
Feb 02, 2007 | GE WJSE4150B Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
