Battery connector from battery to ups 5 pin 240vdc/40a
    Habit-Forming:
  • 159 Answers
Check owners manual, or technical manual at your local dealer
Posted on Nov 06, 2014
I need a fuse panal diagram for the 2013 VW Jetta, my 12 volt power ports are not functioning
Here you go. Fuses on E-box, on left in Engine Compartment
Fuse 1 - Not assigned
Fuse 2 - 10/15A - Engine control unit
Fuse 3 - 5A - Radiator fan control unit
Fuse 4 - 5/10/15A - Lambda probe heater,
Lambda probe 1 heater after
catalytic converter
Fuse 5 - 10A, 20A - Lambda probe heater1,
catalytic converter,
Fuel system diagnostic pump,
Charge pressure control solenoid
valve,
Exhaust gas recirculation cooler
change-over valve,
Crankcase breather heater element,
Vacuum pump for brakes
Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
Throttle valve module,
Activated charcoal filter system
solenoid valve 1,
Continued coolant circulation pump,
Auxiliary air heater heating element
Fuse 7 - 20A, 5A - Ignition transformer,
Fuel pressure regulating valve,
Fuel metering valve
Fuse 8 - 10A - Throttle valve module,
solenoid valve 1
Fuse 9 - 5A - Automatic glow period control unit,
Electric fuel pump 2 relay,
Fuel pump relay
Fuse 10 - 5A - Speedometer sender,
Brake light switch
Fuse 11 - Not assigned
Fuse 12 - 5A - Coolant circulation pump
Fuse 13 - 5A - Water pump
Fuse 14 - 5A - Engine control unit
Fuse 15 - 30A - Voltage stabiliser
Fuse 16 - 30A - ABS control unit
Fuse 17 - 30A - Automatic gearbox control unit
Fuse 18 - 20A - Automatic gearbox control unit
Fuse 19 - 1A - Onboard supply control unit
Fuse 20 - 30A - Onboard supply control unit (AW0)
Automatic intermittent wash and
wipe relay (AW1)
Fuse 21 - 50A - Secondary air pump motor
Fuse 22 - Not assigned
Fuse 23 - 40A - ABS control unit
Fuse 24 - 50A - Trailer detector control unit
Fuse 25 - 50A - Terminal 15 voltage supply relay 2
Fuse 26 - 60A - Automatic glow period control unit
Fuse 27 - 60A - Radiator fan
Fuse 28 - 40A - Onboard supply control unit (AW1)
Fuse 29 - 40A - Onboard supply control unit (AW1)
Fuse 30 - 50A - Terminal 75 voltage supply relay 1
Fuse 31 - 30A - Amplifier
Fuse 32 - Not assigned
Fuse assignment - Interior Fuse Panel
Fuse 1 - Not used
Fuse 2 - 5A - Electronic steering column lock control module
Fuse 3 - 10A - Instrument cluster control module
Fuse 4 - Not used
Fuse 5 - Not used
Fuse 6 - 10A - Vehicle electrical system control module,
Interior ceiling lights,
Tail lights
Fuse 7 - 5A - Fog lamp relay,
Instrument panel and switch illumination dimmer switch,
License plate lamps,
Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
Windshield washer pump
Fuse 9 - 5A - Airbag control module
Fuse 10 - 10A - Right steering column switch
Fuse 11 - Not used
Fuse 12 - Not used
Fuse 13 - 5A - Automatic dimming interior rearview mirror,
Light recognition sensor,
Parking aid control module,
Air quality sensor,
High pressure sensor,
Climatronic control unit,
Tire pressure monitoring button,
Back-up lamp switch,
Left washer nozzle heater,
Right washer nozzle heater,
28-pin connector
Fuse 14 4- 10A - Left steering column switch,
ABS control module,
Light switch,
Airbag spiral spring/return spring with slip ring,
Fuel pump control module,
Data bus on board diagnostic interface
Fuse 15 - 10A - 16-pin connector (diagnostic connector),
Headlamp range control adjuster,
Auxiliary heater operation relay,
Mass airflow sensor,
Positive crankcase ventilation heating element,
Left front headlamp,
Left headlamp beam adjustment motor,
Right front headlamp,
Right headlamp beam adjustment motor,
Fuse 16 - 10A - Engine control module
Fuse 17 - Not used
Fuse 18 - 15A - Left front headlamp
Fuse 19 - 15A - Right front headlamp
Fuse 20 - 10A - Automatic transmission control module,
Selector lever sensor system control module,
Tiptronic switch,
Ignition/starter switch
Fuse 21 - Not used
Fuse 22 - 10A - Ignition/starter switch,
Converter box,
Alarm horn,
Interior monitoring sensor,
Alarm horn relay,
Dual tone horn relay
Fuse 23 - 10A - Vehicle electrical system control module,
Light switch,
Rain/light recognition sensor,
Compass magnetic field sensor,
Fuse 24 - 10A - Vehicle electrical system control module,
Access/start authorization control module
Fuse 25 - 15A - Automatic transmission control module,
Multifunction transmission range switch
Fuse 26 - 15A - Brake system vacuum pump
Fuse 27 - Not used
Fuse 28 - 40A - Auxiliary heater operation relay
Fuse 29 - 1A - Vehicle electrical system control module,
Fuse 30 - 20A - Cigarette lighter,
12 V socket,
12 V socket 2,
Blocking diode
Fuse 31 - 30A - Light switch
Fuse 32 - 20A - Light switch
Fuse 33 - 40A - Heater/heat output switch,
Fresh air blower relay,
A/C control module,
Fresh air blower switch
Fuse 34 - 15A - Left front headlamp,
Fuse 35 - 10A - Steering column electronics control module,
Instrument cluster control module,
Signal horn activation,
Fuse 36 - 25A - Vehicle electrical system control module
Fuse 37 - 15A - Left front headlamp DRL
Fuse 38 - 15A - Right front headlamp DRL
Fuse 39 - 15A - Low beam relay
Fuse 40 - 15A - Towing recognition control module
Fuse 41 - 15A - Towing recognition control module
Fuse 42 - 20A - Towing recognition control module
Fuse 43 - 30A - Front passenger door control module
Fuse 44 - A25 - Rear window defogger relay,
Fuse 45 - 30A - Driver door control module,
Fuse 46 - 30A - Left rear door control module,
Right rear door control module
Fuse 47 - 15A - Fuel pump control module,
Fuel pump relay,
Fuel primer relay
Fuse 48 - 20A - Vehicle electrical system control module,
Fuse 49 - 20A - Climatronic control unit,
A/C control module
Fuse 50 - 30A - Front seat heating control module
Fuse 51 - 30A - Power sunroof control module
Fuse 52 - 20A - Dual tone horn relay
Fuse 53 - 15A - Front seat heating control module
Fuse 54 - 15A - Fog lamp relay
Fuse 55 - 20A - Light switch,
Fuse 56 - Not used
Fuse 57 - 15A - Radio,
Radio/navigation display unit control module
Fuse 58 - 1A, 30A - Telephone transceiver
DC/AC converter with socket, 12V-230V
Fuse 59 - 30A - Amplifier
Fuse 60 - 30A - Auxiliary heater control module
Jul 20, 2014 | Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6...
Fuse for the alarm system
Here is the full list of fuses for you! and for the car.
catalytic converter
valve,
change-over valve,
solenoid valve 1,
Fuel metering valve
solenoid valve 1
Fuel pump relay
Brake light switch
wipe relay (AW1)
Fuse 1 - Not used
Fuse 4 - Not used
Fuse 5 - Not used
Tail lights
Fuse 11 - Not used
Fuse 12 - Not used
Air quality sensor,
28-pin connector
ABS control module,
Light switch,
Fuse 17 - Not used
Tiptronic switch,
Fuse 21 - Not used
Converter box,
Alarm horn,
Alarm horn relay,
Light switch,
Fuse 27 - Not used
12 V socket,
12 V socket 2,
Blocking diode
A/C control module,
Fuel pump relay,
Fuel primer relay
A/C control module
Fuse 56 - Not used
Hope this helps
--N
May 31, 2014 | 2010 Volkswagen Jetta
Awz 9813 whirlpool
Check your thermal fuse, if that is ok make sure that your heating element has continuity. Also check your cord you need 240vdc at machine to operate, it will run with 120vdc but needs 240vdc to also heat.
Jul 31, 2013 | Dryers
Where is the diagnostic port located on a 2000 fiat marea
on a 99 2.0 model you will have 2 diagnostic ports. both of them will be the fiat 3 pin type.
to connect the 3 pin fiat connector to a 16 pin obd2 connector you need 4 lengths of wire. use 3 lengths of wire to connect the 3 pin connector to the obd connector. also use 1 length of wire for power to the obd connector.
on the 16 pin obd2 connector use the following pins
4- chassis ground (connect to ground on 3 pin connector, or any good chassis earth)
5- signal ground (connect to black wire pin on 3 pin connector)
7- k line (connect to white wire pin on 3 pin connector)
16- 12vDC (connect to battery positive terminal)
Apr 08, 2013 | Cars & Trucks
Jeep patriot won't crank
I had this exact same issue w/ my 08 Patriot. Had it towed the first time and mechanic changed the starter. Worked for about a week, then same issue. Found that moving the vehicle, even just a couple of inches, or putting in neutral helped start it. Issue stopped once weather warmed up. This all occurred last March (2014).
Until two weeks ago that is. Horn stopped working so I started looking for any corroded connections. I came across some relays under the left headlight. When I pulled them out, I found two had corroded pins. One was so bad that there was no pin left. It had barely been making a connection before I pulled it and now it wasn't going to at all. The wires to that pin were completely shot too. And guess what, car wouldn't start! Same symptoms as in March.
I ended up going to my parts recycling place and piucked up the whole relay enclosure w/ 4 relays and about a foot of the wiring. I used my smallest watch screw driver to carefully remove the spade connector from the recycled relay enclosure. The corroded connector in my Jeep completely destroyed its slot. I ended up having to gently remove the other spade connectors for the relay and relocated the surviving spade connectors to an open/unused location (luckily there were 2 open spots) and splicing in the salvaged connector. I used some dielectric grease on all of the relay slots, before putting everything back together, and was able to relocate the entire enclosure up next to the fuse enclosure (as recommended by by someone in anothe post. I apologize for not being able to find the link to it at the moment).
It's been working well for just over two weeks now. I hope this helps someone else.
BTW - horn turned out to be dead and I just ended up replacing it. Not related to the relays at all.
May 09, 2012 | 2008 Jeep Patriot
What or the color of the radio wires for in a 1993 bonneville
Use a multimeter to find the two feeds and then a 9v pp3 battery to check the speakers it thats simple .
Feb 25, 2012 | 1993 Pontiac Bonneville
I need a diagram of the underhood fuse block for my 2002 ford explorer. I don't have an owners manual.
Fuse/Relay Location*Fuse Amp Rating* Description
1 60A** PJB 2 30A** BSM 3 20A** Not used (Spare)
4 30A** Rear defrost 5 40A** ABS (pump)
6 60A** Delayed accessory circuit breaker
7 20A** Power point #2 8 — Not used 9 20A** Power point #1
10 30A** ABS module (valves) 11 40A** PTEC
12 50A** Ignition relay/Starter relay
13 40A** Trailer tow battery, Trailer tow turn signals
14 10A* Foglamps 15 15A* Memory (KAPWR)
16 15A* Headlamp switch 17 20A* 4x4 (v-batt 2)
18 20A* 4x4 (v-batt 1) 19 20A** High beam relay
20 30A** Electric brake 21 30A** Front wiper motor
22 20A** Autolamp; Low beam 23 30A** Ignition switch
24 20A* Rear Fog Lamps 25 – Not used
26 15A* Fuel pump 27 20A* Trailer tow lamps
28 20A* Horn relay 29 60A** PJB 30 20A** Rear wiper motor
31 — Not used 32 — Not used 33 30A** Auxiliary blower motor 34 30A** Power seats, Adjustable pedals
35 20A** Rear power point 36 40A** Blower motor
37 15A* A/C clutch relay/Transmission
Nov 15, 2009 | 2002 Ford Explorer
Need wiring diagram for 2001 dodge dakota... trying to hook up connector for towing
moz-screenshot-1.jpg 08-33-93f1.gif CAV CIRCUIT FUNCTION 1 Z13 12BK GROUND 2 B40 12LB TRAILER ELECTRIC BRAKE OUTPUT 3 L76 12BK/OR TAIL LIGHT (Trailer Tow Relay in PDC) 4 A6 12RD/TN* FUSED B(+) (40A, Always Hot, F8 in PDC) 5 L63 16DG/RD LEFT REAR TURN SIGNAL TRAILER TOW 6 L62 16BR/PK RIGHT REAR TURN SIGNAL CONNECTOR 7 L1 16VT/BK BACK-UP LAMP FIGURE 1: 7-Terminal Trailer Tow Connector
Jul 10, 2009 | 2001 Dodge Dakota
I need a wiring diagram for a 7 pin trailer board plug
Here's one
Mar 12, 2009 | 1993 Land Rover Defender
Radar screen shows "no scanner". Would like resistance data for cable pin-out from display to scanner head.
Hello Clifford,
This is an old message. Are you still having trouble with this or has it been resolved?
Aug 22, 2007 | Raymarine C80 GPS Receiver
Computers & Internet Logo
517 people viewed this question
David Payne
David Payne
