Question about Sony Playstation 3 (PS3) Console
How do I reinstall Multiman and PKG Files, all missing after updated version 4.31 installed
APPLICATION HPSU -0004 MISSING FROM LIBRARY
Basically, the HPSU-0004 Error states that one or more DLLs (libraries) needed for the Update utility to run are missing.
The libraries were deleted, or pointers to irrelevant libraries were left in the Registry.
2 Possible Solutions:
The EASY solution:
1. Remove all of your HP (Hewlett Packard) Printer software from your computer and do a fresh install from the CD that came with your printer.
The Hard Solution (only do this if the easy one doesn't work):
1. Download a current version of the FULL drivers+applications (single HUGE file) for your printer;
2. Start running the file downloaded in the previous step, until it offers the option to install the software (other options might be there, such as "read the Readme file");
3. Do NOT click on "Install", but rather simply exit the Installer (cancel, exit, ...) - the reason for step 2. above was to just have the downloaded file extract in an orderly manner all the files that it (and YOU) would use for its (and YOUR) further processings;
4. Locate on on your drive the installation folder created in step 2., and -- under it - the folder "setup\hpupdate" (the whole thing should be located somewhere under the TMP or TEMP folder - just run a Search/Find for it, using your search engine of choice);
5. IF (and only if) you have located the HPUPDATE folder in the previous step (you will, normally), continue:
6. Under Windows Control Panel, start the "Add/Remove Programs" applet, and -- in the list of applications it presents -- look for "HP Update";
7. Remove the HP Update application as you would any other application (the uninstall process might end with some errors for files not found - this is normal in this case, as we already know that some files are either missing, or mistakenly pointed at, as stated earlier in this text);
8. Now go to the setup\hpupdate folder located in step 5. above, and run (double-click on) the only *.msi fie found within it (this will reinstall the version downloaded of the HP Update utility);
9. When Installation (previous step) is completed, run the newly installed HP-Update utility, to find further updates both for itself (you might not have had the most recent version) and for any other HP application that might reside on your drives.
10. This completes the process
Good Luck!
May 17, 2012 | HP Pavilion a705w PC Desktop
G5 is flat. How can I bring it up to pitch?
Is your question about G5 ppc mac. or about Suzuki g5 motor cycle.-------------I assume its about g5 ppc mac.-------
Try downloaded the latest version 2.5.1 to update the 2.2 version;.---------- 1) Open Finder and go to the Macintosh HD -> Library -> Receipts folder. In here you'll see the Pitch 'n Time Pro 2.5.1 Installer.pkg file - delete this.
2) Go to the Macintosh HD -> Library -> Application Support -> Digidesign -> Plug-Ins folder. In here you'll see the Pitch 'n Time Pro.dpm file - delete this.
3) Run the Pitch 'n Time Pro installer again.
----------------- If there is no installer.pkg. File.Then However,you will see these other two files as follows :---Pitch 'n Time Manual.pkg-------
Pitch 'n Time PlugIn.pkg--------
Delete this files.-------- Then try installing latest version and see.--------- ------------- Check out, keep updated, thanks.Helpmech.
Jul 31, 2011 | Suzuki 25Note Chromatic Tone Chime Set
Quicktime
You can try the following,
1) Navigate to library, it will be in your main drive.
2) Remove all files from the QuickTime*.PKG, where "*" is your version number. This tells you that those packages are not installed.
3) Click on the "download Quicktime" link. DO NOT USE THE AUTOMATIC UPDATE UTILITY. Download QuickTimeInstallerX.dmg. Double click this file (probably on your desktop) and then invoke the installer by double clicking QuickTime701.pkg.
4) Restart the computer.
Regards,
Shrey
Dec 21, 2009 | Computers & Internet
Cant get rid of Error 15103 Document Viewer
Error 15103 error symptoms can include program lock-ups, slow PC performance, system freezes, shut down and startup problems, and installation errors
uninstall regcure uninstall quickbooks.....run ccleaner and then cold start the pc ...now reinstall quickbooks .....reboot
www.ccleaner.com
good luck
Apr 05, 2009 | Intuit QuickBooks Premier Accountant...
No Audio Output Device is Installed
control panel audio
then voice make sure in device default you have your type selected and also default device for mic
then press apply
let me know if this helped you may need to update driver
Jan 24, 2009 | Compaq Presario 700 470024-192 Notebook
Corel paint full uninstall
Try to reinstall the old version and then, uninstall it in order to proceed toa clean installation
Hope this helps
Oct 27, 2008 | Corel Paint Shop Pro Photo X2
sound card is a hardware buy it at computer shop
Aug 14, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
I had the same problem. After gemoving the service pkg.1 it works correctly. I couldn't remove the SP1 myself so I brought in to the repairshop (35 euro'). Good luck
Aug 08, 2008 | Acer Aspire 5100 Notebook
the Solution to your problem is that your Laptop need an Audio Driver to drive the Sound card on your system. i Suggest you contact your hard ware vendor for the latest sound driver
Sony Playstation 3 (PS3) Console Logo
67 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
