Question about Bush Audio Players & Recorders
Bush turntable mtt1 not going round
Turntable not going round I
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 236 Answers
Replace the belt.
Posted on Jan 29, 2013
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: bush MTT1 turntable - does it contain a pre-amp?
Yes, according to someone else online who owns one:
"It is a simple device (I have one)
33 or 45 rpm
Pre-amp on/off switch underneath.
Two leads out.
Arm up/down lever and slight speed control.
When the light are stationary due to strobe effect then the speed is right."
Posted on Feb 08, 2010
How to replace a needle Bush RPA 1
he plastic assembly simply pops out... pull straight out away from the arm, on some models, pull down. a new one can be found here: http://www.lpgear.com/product/BUSHRPA01.html
it snaps in place, be very careful not to damage or bend the needle. I recommend leaving the guard on when installing as well as any time the player is not in use or at least if you are going to move the unit. LP Gear stylus for Bush RPA1 turntable
Aug 17, 2014 | Bush RPA 1 Turntable
BROKEN ARM ON MY RPA1 TURNTABLE
I've seen a couple of these models going cheap on e-bay. You could buy one and use that for spare parts. It will probably be a lot cheaper than buying an original spare part! As long as the arm is good on the model for sale you will be quids in.
Apr 02, 2014 | Bush RPA 1 Turntable
Need needle for bush RPA1 turntable
Hi, we have them in stock. Cheers John. Stylus City
Mar 02, 2014 | Bush RPA 1 Turntable
User manual
try http://www.manualsdrive.com
Jan 17, 2014 | Bush RPA 1 Turntable
Turntable manuals
Hi, I am looking for a manual for a Bush SRP 52 record player as the turntable won't turn and I find it find out what the problem is. Is it a belt drive turntable. How to dismantle it and look inside.Thanks
Jan 03, 2014 | Audio Players & Recorders
Bush MTT1 turntable - does it contain a pre-amp?
33 or 45 rpm
Two leads out.
Feb 08, 2010 | Audio Players & Recorders
Fixing turntable
go to this site as if the belt came off it may have stretched in which case it will re-occur? http://www.needledoctor.com/Online-Store/Turntable the belt goes round the inner ring under the turntable platter and onto a little brass capstan on the motor. fit it on the capstan motor first then onto the inner ring on the platter. good luck.
Sep 06, 2009 | Kenwood KD-291RC Turntable
Have akai ap-b110 turntable needs belt. Can you tell me the length/specs
  • If you have the turntable belt:
    • State the type of belt used (Flat, Square, Round).
    • Pinch both ends of the belt.
    • Measure the pinched length.
    • Multiply the pinched length by two (2x).
    • If the turntable uses a Flat belt, measure its width (usually 0.187").
    • If the turntable uses a Round or Square belt, measure its thickness.
    • Please include the make and model of the turntable with the belt's measurements.
  • If you do NOT have the turntable belt or it is shredded:
    • State the type of belt that the turntable uses (Flat, Round or Square).
    • Use a piece of string to tightly follow the belt's path.
    • Measure the length of the string.
    • Measure the width between the rims of the motor pulley that the belt can pass through (usually 0.250 inch).
Jul 08, 2009 | Audio Players & Recorders
Connecting a turn table to a micro stereo system
You will need the following to connect this to that system:
1) Phono Pre-amp
2) 3.5mm to RCA adapter or 3.5mm 'Y' cable to RCA
3) Turntable
Your turntable will connect to the Phono Pre-Amp input. This pre-amp will also have an output. This output is RCA, from here you connect to your system using the 3.5mm adapter or cable.
That's it.
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Aug 07, 2008 | Audio Players & Recorders
110 people viewed this question
Top Bush Audio Players & Recorders Experts
 Grubhead
Grubhead
STEVEN MAYAMBALA
Level 1 Expert
Are you a Bush Audio Player and Recorder Expert? Answer questions, earn points and help others
