Question about Philips GC 8220 Iron
Refill water tank light won't go out
Hi there. I have a problem with my Philips GC 8220 steam iron. The red 'refill water tank' light will no go out even though the water tank is full and properly engaged. The iron does not make a pumping noise either but I am assuming that's because it thinks there's no water to pump. Any help would be really appreciated - it seems like it might be quite a simple problem... (here's hoping anyway!)
  • Alex Matthews Jun 08, 2013
    Sarah, I have the same issue with my Iron. Did you ever solve the problem?
    Top Expert:
  • Philips Master
  • 75,235 Answers
Then replace it because they are not repaired.
Posted on Jun 30, 2017
5 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Philips Azure self-cleaning steam iron
philips do not have a manual for this iron online, sorry contact them if you want; http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?sct=IR_STEAMIRONS_SU&cat=HOP_IRONS_CA&grp=HOUSEHOLD_PRODUCTS_GR&session=20070313063306_83.37.63.254&ctn=HI296/54&slg=ENG&scy=GB The best way to clean these irons is with neat vinegar - try to get white vinegar and you have less smell to get rid of - fill the iron, give it a good shake and leave it overnight, then use the iron as normal (use it on a kitchen drying up towel or similar) then leave it for another few hours/overnight and then empty out any remaining vinegar and rinse through with water a couple of times. this normally solves any problems caused by limescale - if not then just leave the iron a little longer with the vinegar, also try to pour a little vinegar into the steam vent holes with the iron upturned and leave for a while. Hope this helps :)
Posted on Mar 13, 2007
heatman101
  • 43501 Answers
SOURCE: Iron producing lots of water
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
heatman101
  • 43501 Answers
SOURCE: We have a GC8420 steam
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Posted on Jul 14, 2011
ib_yang
  • 1098 Answers
SOURCE: Have lost operation manual for
Hi there.
You can get the manual here. Make sure that you have an Adobe Acrobat Reader.
Let me know if you find any problem with the link.
Thank you!
Posted on Jul 26, 2011
Red light refill flashing but water in the tank
Hey did you ever get an answer to your question?
I have the same problem
Jun 10, 2013 | Philips GC 8220 Iron
My iron is getting hot but giving no steam can anyone advise
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jan 31, 2013 | Breville Vin227 Extreme Steam Steam...
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
Philips GC 8220 repair manual
Red water light has come on for the first time.
water chamber is full of water.
Iron is not producing any steam what could be the problem ?
Sep 14, 2012 | Philips GC 8220 Iron
I need to descale my iron and don't have any instruction manual.
heatman101
Apr 03, 2011 | Philips GC 2522 Iron
How to clean a phillips gc 8320 steam iron
<div class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Hi,<br />Here is a tip that will help you with that problem...<br /><br />Cleaning a Steam Iron Soleplate</span></div> <div class="solution-text"><span><br /><a href="http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate" target="_blank">http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate</a></span></div><span> <div class="solution-text"><br />Cleaning a Steam Iron White Scale and Brown Water</div> <div class="solution-text"></span> </div> <div class="solution-text"><span><a href="http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown">http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown</a><br />heatman101</span> </div><!-- /solution text --><!-- helpful bar -->
Aug 26, 2010 | Philips Irons
Cleaning Carezza soleplate of iron
Here is a tip that will help you with cleaning the sole plate of your iron...
heatman101
Jul 06, 2010 | Philips GC 8220 Iron
heatman101
May 18, 2010 | Philips GC 8220 Iron
Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Nov 12, 2007 | Tefal Ultraglide 1549 Iron
Philips GC 8220 Iron Logo
211 people viewed this question
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
