Question about Graco Spree Baby Gear
I want left VX by 20mm, as where i live they have old stone cutters
Can you help me, i just want lift my vx2 commodore 20mm. As where i live the have old stone gutter and if you go off the edge of the you mark the side of you bumper bar I was told to use 5.0lt coil or vu ute fronts spring Do you know where i can get some second hand One person gave me a part number Jm 92058074 tag id JM for VU ute Or HS spring tag Id off 5.0lt VT The council want charge me $800 for planning permit and there got to do the new gutter and they cant give me costing on that I sick pay the insur company $650 each time i want part my car in the drive way. Ever when we get when we put our bins out, we have to put one each side. As street is only as wide as the truck. If you park car on both side of street you cant get down it. So yo got swing wide to get out of your drive way. If anyone got any of these front spring i would be greatfull Cheer bruce
  • 126 Answers
SOURCE: Handle bar issue...
PHONE: 1-800-460-2922
Posted on Apr 28, 2008
  • 255 Answers
SOURCE: vw passat 2002 tdi 130
Hi,One of the fans is the regular one , the other is an auxiliary one it should come one when you turn the air on . they must be working properly . leave the car runing with the hood open and wait till fan comes on , if it does not comes on you should have it check by a tech...good luck....
Posted on Aug 15, 2008
SOURCE: Jane Powertwin bumper bar you can find parts or ebay.
Posted on Aug 16, 2008
  • 1861 Answers
SOURCE: Need to fit coil springs to Landcruiser 79 series ute (2004)
You need a coil spring compresser, and the proper skill level to use it.
If you try to change the coils without a compresser, you CAN & WILL GET HURT. Coil springs are not something to fool about with if you do not have the proper tools. These things are danagerous.
Posted on Sep 09, 2008
  • 7 Answers
SOURCE: vt commodore
Yes what problem do you have?
Posted on Oct 04, 2008
What each colourvwiringis for in vx ,2002,Commodore
The Holden Commodore (VX) is an executive car that was produced by the Australian manufacturer Holden from 2000 to 2002. It was the second iteration of the third generation of this Australian made model. Its range included the luxury variants, Holden Berlina (VX) and Holden Calais (VX), and it formed the basis for a new generation Holden Ute (VU) coup? utility and Holden Monaro (V2) coup?.
The VX series was produced between October 2000 and September 2002, as a minor restyling update to the VT series from 1997. It introduced greater model differentiation along with gains in crash safety. An intermediate Series II was launched in August 2001, featuring a revised suspension system among other changes.
Apr 16, 2017 | Cars & Trucks
Will ls1 go in vx commodore s 2000
yes VX V8s were fitted
depends on what state you live in
LS1 fitted may need a modification plate
needs the LS1 engine ecu and
and a few extra wiring and
join the just commodore forum for loads of helpful information
Jul 29, 2016 | Cars & Trucks
Check transmission trian on Vx commodore executive it had no fluid have filled it but keep getting that message is their a reset button
try this just commodores forum
on the VZ 2004-- 2006
Forum VZ Holden Commodore 2004 2006
I only know of engine service message
clearance using the mode buttons on a VT.VX
i hope you are a lucky person because
any commodore transmission man or auto
driven without fluid would have taken some internal damage
Jun 23, 2016 | Cars & Trucks
Will vx trans fit vs commodore
You will need to check with a salvage yard on this, they have cross reference books to tell them this.
Oct 11, 2012 | Holden Commodore Cars & Trucks
Fuse box diagram for vx commodore
Anything for less than $200 is great.
Jun 05, 2012 | Holden Commodore Cars & Trucks
Replace fuel pump vx holden commodore
To Replace the fuel pump on a vx commodore I would highly recommend the flowings
*1st try and find out roughly how much fuel is in the tank.
*Disconnect battery
*raise vehicle on hoist at a comfortably working height
*release metal strap in the centre of the fuel tank
*position a transmission jack in the centre to balance and support tank.
*Undo both remain straps but when undoing the one closest to the filler neck becareful not to damage earth lead.
*very slowly lower the transmission jack now to again access to fuel lines so they can be disconnected.
*now all fuel lines are disconnected lower transmission stand fully.
*with the help of someone else lift the tank off jack and place on floor.
*mark position of sender unit on tank before removing.
*you will either need the correct tool or old nudge bar and hammer to tap free the locking ring around the fuel sender.
*once the locking ring is free lift up the sender unit and you will see the fuel pump connected to sender unit .depending if you feel the gauge might not be reading correctly you can replace sender and pump as one unit or just the pump.
*which ever way you decide to go about it I would strongly recommend once its all back together you calibrate the fuel gauge.
*to refit just follow these steps in reverse .
good luck
Oct 08, 2011 | LG VX 4400B Cellular Phone
Reprogram remote key vx commocore
mr minit! locksmith! what area do you live in? most small workshops have a scan tool that will program commodore keys from vn to vy. hope this helps
Aug 04, 2009 | 2004 Isuzu Rodeo
Here is a good website with radio mods for most radios, here's the mod for the vx2, also note the other files, I guess that radio has had a few problems in the past....
Oct 29, 2008 | Radio Communications
Baby Gear Logo
273 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
