Question about FUJIFILM Cameras
Can't download videos longer than 60 seconds on my computer
    Genius:
  • 1,019 Answers
Sounds like the program you are using has a limit set as default that needs to be increased.
Posted on Jan 25, 2013
HT-RC360 no longer feeds video to my TV .
Update firmware (usually every 6 months). Connect the ethernet to the unit, press Net and Power button simultaneously. Hit Enter as directed. Takes up to 60 minutes. OR (if no internet service), download firmware updates onto a USB (32MB) and connect it to the USB port. If you do not update voluntarily, unit will suddenly not feed video.
Aug 26, 2012 | Onkyo Ht-rc360 7.2ch Network Audio/video...
How can i use the motion eye camera to capture picture? only video recording is the one i can use.. please help..Thanks
Frame rate is also a term used in real-time computing. In a fashion somewhat comparable to the moving-picture definition presented above, a real-time frame is the time it takes to complete a full round of the system's processing tasks. If the frame rate of a real-time system is 60 hertz, the system reevaluates all necessary inputs and updates the necessary outputs 60 times per second under all circumstances.
Owing to their flexibility, software-based video formats can specify arbitrarily high frame rates, and many (cathode ray tube) consumer PC monitors operate at hundreds of frames per second, depending on the selected video mode. LCD screens are usually 24, 25, 50, 60, or 120 FPS.
The designed frame rates of real-time systems vary depending on the equipment. For a real-time system that is steering an oil tanker, a frame rate of 1 FPS may be sufficient, while a rate of even 100 FPS may not be adequate for steering a guided missile. The designer must choose a frame rate appropriate to the application's requirements.
http://www.mercedesbenzwheel.com
May 23, 2012 | Computers & Internet
I have a horn that sounds when my hay baler chamber is full. I am looking for a timer relay that will allow the horn to sound for 3 to 5 seconds and then disconect the circuit so it won't drive me...
DEI 528T appears to be 12Volt 'wait to start' or ON-delay timer.
528 receives electrical signal, and then delays the start-circuit by up to 60 seconds.
For example home alarm system. Door is opened and alarm sounds. Install DEI 528 and set for 60 seconds: Door is opened and alarm will not sound for 60 seconds.
You need 12-volt off-delay timer.
Off-delay timer receives electrical impulse, and then begins a countdown.
After countdown expires, then circuit turns off.
ELK-960 appears to have off-delay feature for 12V DC
http://www.homesecuritystore.com/p-423-elk-960-delay-timer-module.aspx
Use wiring diagram #7 for alarm cut-off:
http://download.homesecuritystore.com/downloadmanual.aspx?FileName=ELK-960_Install.pdf
Aug 25, 2011 | Directed Electronics Dei 528t Pulse Timer...
Clear.fi for some reason will no longer play you tube movie trailers
Try to use last version of Adobe Flash player. It depend on flash (and old flash can have some issue). I use Firefox browser and have DownloadHelper plugin for downloading video from YouTube to computer in flv (flash) or mpg (mpeg) format. It ad some 'rotating point icon' to browser and when you click on arrow, you can download video from YouTube. It is useful to me...
Aug 24, 2011 | Computers & Internet
DISABLED OR BLOCKED IPHONEA1303 16GB
You can enable or activate your phone without Restoring or Loosing data.Please follow this procedure...
* Open iTunes.You can check your iTunes version by clicking "iTunes" in the menu bar and then clicking "About iTunes."
If you don't have itunes yet,download the highlighted keys below.
DOWNLOAD ITUNES
* Make sure you have the Blackra1n jailbreak tool on your desktop. download the link below
BLACKRAIN FOR WINDOWS
BLACKRAIN FOR MAC
* Attach your iPhone to a USB port on your computer by using the iPhone data cable. Open the Blackra1n tool and then click in the middle of the box where it says, "Make it Rain." Now perform a hard reboot on your iPhone.
To perform a hard reboot, simultaneously, press the iPhone on/off button located on the top right of your iPhone and the "Select" button centered on the bottom of the iPhone below the screen. Hold down both buttons for approximately 60 seconds. Your screen will go black. Then you will see the apple logo. Then your screen will go black again. After about 60 seconds, you will see the normal iPhone reboot screen, which shows the iTunes logo and a picture of a USB data cable.
Release both buttons and you will see the Blackra1n reset screen which looks like a picture of a teenage boy surrounded by iPhone images. Your iPhone should now be fully functional and no longer disabled.
Good Luck...
Aug 04, 2011 | Apple iPhone (16 GB) Smartphone
My computer will begin to project using my NP400 but after 60 seconds it no longer projects
Is projector went down or just lost signal? If it's losing signal it can because your computer's video card or projector's.. Try to wiev from only projector , not with both of them...
Mar 01, 2010 | NEC Office Equipment & Supplies
All videos are very choppy such as HULU or utube and machine seems to run slow in general . Start up and shut down seem to be slow also.
Downloaded videos can sometimes play "faster" than your Internet connection can download them, in the same way that parents can never keep enough food in the refrigerator to feed their teenagers.
Start downloading the video, and click 'pause' to let the download continue for 30 to 60 seconds, and then click 'play', to see if the video is "smoother" when the "buffered" content is being read from your local disk-drive.
If not, then the "performance" of your computer needs to be investigated.
How much RAM in your computer?
Windows 2000? XP? Vista? 7?
Is your anti-virus software working correctly?
Have you recently done a "full" virus-scan -- computer-viruses can cause your computer to slow down.
Disconnect the Ethernet cable from your computer, and then reboot.
Does the reboot go faster with _NO_ Internet connection?
Jan 07, 2010 | Computers & Internet
Cameras Logo
21 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
