Question about Sony MHC-RG444S CD Shelf System
Sony MHC-RG 444S sound output issues
Hello everyone. I seem to have some trouble with this stereo. The sound is missing at times from the right channel. I re-checked the connections , swapped the left-right channels , but it seems like the right channel of the stereo is having troubles as the right speaker , if plugged into the left channel outputs , it goes ok. The strange part is that if i increase the volume , it turns back to normal , and i can hear the sound from both channels. Yesterday tho it started to play around with both channels (meaning that all i could hear was the sub playing). However , from time to time , the left-right start to work again ( for a limited time). Today i tried a cold reset , and so far , it goes well , but i have my doubts. I can tell for sure that there is no loose connection. I have installed some sort of speaker terminals , that just stay still in the "push" connectors on the stereo. My big question is , could it be related to some faulty joints of the push speaker terminals? Could it be the amp board itself? Could it be the volume knob? I'm in the dark here... . Thanks im advance!
4 Suggested Answers
  • 883 Answers
SOURCE: Sony MHC-RV888D - TAPE Recording to Laptop as mp3
on laptop, ensure the following: 1. go to Volume control (look for icon on system tray). 2. under Options tab select Properties. 3. under Adjust volume for recording option, ensure that microphone is is check-boxed if no luck, borrow a second amp and connect your L/R jacks (red and white colour) to the borrowed amps line in jacks and test whether you hear anything to confirm your line out capability.
Posted on May 27, 2007
SOURCE: Sony CMT CP1 Right hand speaker output very noisy, humming, crackling
It sounds to me like you both are having a problem with a capacitor going bad. some capacitors act as a noise filter and it sounds like you both have a bad one. If you are any good with a volt-ohm meter that reads capacitors you should check them to make sure they are at their proper values which will be posted on the capacitor. then replace it. if you dont know how to use a v-o meter then take it to a shop and have them replace it
Posted on Jan 23, 2008
SOURCE: I own a sony MHC-GX45. A while ago the left
Sorry, I have a similar problem and came here looking for a solution. I believe the problem is with the speaker or the speaker wire. When I move the "good" speaker to the other set of lugs, it continues to function OK. I wish I could get the speaker box open without major surgery, but, alas, they are not made for repair. Don't know if I will cut into the box. My temp solution is to turn the unit off/on. This gets both speakers working. Bit of a drag, but I am finding it real difficult to find a new system w a tape player.
Posted on Apr 19, 2010
Sony mhc-gx555 stereo systeme put demo mode off
Pretty sure you just press the display button repeatedly to shut it off, but here is the manual just in case I missed it:
https://docs.sony.com/release//MHC-GX255_GX355_GX555_RG575S_RG475S_RG470_RG270_RG170.pdf
Jan 25, 2017 | Sony Car Audio & Video
Sony hcd vx55
Hello. I downloaded the manual for the Sony system with the model number MHC-VX55. It seems that the part you are asking about is not a speaker system, but a preamplifie/power amplifier with integrated inputs from CD/Video, tape and tuner. The speakers that connect to the HCD-VX55 are a three way passive design with a nominal impedance of 6 ohms and model number SS-VX55. To answer your question I will assume that you meant you would like to connect the MHC-VX55 system to your computer for playing back audio tracks from your computer. Yes, you can do this. Your Sony system is equipped with an input labelled MD/Video (audio) With a sensitivity of 450 mV, this will (not ideally) the output from your computer headphone jack (if a laptop) or, even better you may have a desktop with an audio output at line level. You will need a simple audio connector with a 3.5 mm stereo plug on each end (very common and readily available for a few dollars. Be careful when setting up that you have your source turned down low and the input on your Sony machine about half way. You will find the sweet settings so that you get good sound without distortion. If you get distortion your source level is too high. Hope this helps. Cheers, Don.
Dec 13, 2013 | Audio Players & Recorders
Sony mhc- rg 55 MECHA ERROR disc spin then turn off
My mhc-rg 55 shelf system reports a Mech error when I turn it on (after rotating the CD tray to try to take up each CD twice ) Then is shuts down.... I took the unit apart and saw noting obvious... (Of course it was more difficult to reassemble and still doesn't quite fit properly.) But the problem persists. Looks like it over to the repairer. Sorry - No solution here
Nov 21, 2012 | Sony MHCEC99 Mini MP3 hifi system Shelf...
My speaker outputs, including headphones, makes a loud pulsing sound. the stereo is a sony mhc-rx70 bookshelf system.
It is mobile phone system's problem, you can try to mobile phone shop where to install system. Instead of Stereo Earphone problem.
Sep 11, 2012 | Sony MHC-RX70 Shelf System
Can i connect an ipod to a sony mhc-m500av (circa 2000)?
Seems you are looking for one of these: http://www.cablestogo.com/powerreviews/pwr/product-reviews/9969/Cables/Cables-To-Go/p/35507p-35507-4ft-iPod-reg-Compatible-RCA-Stereo-to-Dock-Connector-Cable.html Or one of these: http://www.cablestogo.com/product.asp?cat_id=3905&sku=40371 Without knowing your gear, sounds like you are saying it has the red and white RCA connectors for input. Which cable depends on your iPod version.
May 30, 2012 | Sony MHC-M500AV Shelf System
How can i connect an ipod to my sony mhc-rv777d. with no aux port. Can i use the video/sat port??
Hello - Yes you would plug an Ipod to stereo RCA cable into the appropriate L/R inputs for video/sat. This comes from the device user's manual.
According to the user manual it is preferable to use the SAT setting as the Video setting can output some noise at times. You would then of course use the SAT button to hear playback.
Enjoy the music
Mikeywaf
Mar 20, 2011 | Televison & Video
How to connect MHC-RG222 speakers to my pc
If you have an output function at the back of your mini HIFI then surely you can.What you need is a Dual RCA [from the mini HIFI] to 3.5 mm Stereo Jack [to the PC]. The cable is easily available in the market...go to this site n you'll get the idea http://www.vpi.us/cable-audio.html
Jun 17, 2009 | Sony MHC-RG222 CD Shelf System
Power Protect still comes on now and again
Amplifier output chip in stereo is defective and unit gives error message of push power protect.
You need to replace output amplifier IC and check supplied voltages.
Feb 28, 2009 | Sony MHC-RXD5 Shelf System
Sony MHC-RV888D Tape Recording to LAPTOP - How to connect?
you have to connect the S-VIDEO output of the device to your laptop via s-video - usb cable , if they do not have a cable like that than you might as well use an adapter from s-video to usb, if u have your hands on one.
the second method is to hook up a audio recorder from the speaker output, and use a volume controller witch steps down the speaker output so you can plug the cable directly to your laptop microfone output..
good luck!
Apr 11, 2017 | Sony MHC-RV888D Shelf System
Sony MHC-RG444S CD Shelf System Logo
82 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
