Question about Olympus Vr-340 16mp Camera Digital Optical Zoom With 10x
Olympus VR340 dead after firmware flash.
I was flashing an updated firmware and accidentally pulled the usb cable out of my PC, when I moved the camera. Tried to turn on the camera but it is totally dead. Is there any way I can recover this?
    Genius:
  • 1,019 Answers
I am afraid this will need to go to the shop as the rom has been corrupted, They can probably fix it.
Posted on Jan 26, 2013
Jeap
  • 114 Answers
SOURCE: dead c 310
that camera needs to have the mainboard replaced, it´s pretty normal, with that kind of model
Posted on Jan 23, 2007
  • 479 Answers
SOURCE: Can't download photos from Olympus SP500UZ
it would appear that the computer is seeing the camera incorrectly... the camera should be recognized as usb mass storage device and uses the driver usbstor
Posted on Aug 22, 2008
silly girl
  • 513 Answers
SOURCE: olympus sp 350
Are you sure you finalized the firmware upgrade procedure according to the instructions? This sounds a little like you pulled the plug a little too soon... Have you done it according to these instructions: http://www.olympusamerica.com/cpg_section/OMfirm.asp And kept the camera connected until the update was 100 % complete? If you did everything right, try reseting the camera - take the batteries out for the day, and see if it helps. if you're back to step one(the reason you did the upgrade), try the firmware upgrade again. If still it doesn't work contact olympus, and I hope you have a valid warranty. Good luck
Posted on Jun 25, 2006
leecom72
  • 4806 Answers
SOURCE: My Olympus FE-170 won't connect to my PC
Hi there
Possibly not, try another camera lead in a different USB port.
If its the same format the camera card and try again, if you still get the same result, the camera is faulty.
Good luck and thanks for using Fixya!!
Posted on Feb 13, 2009
SOURCE: Olympus mju 770 sw.The lens cover is stuck open.
me too, any suggestions?
Posted on Oct 17, 2009
Hello my name is Danielle and my nokia n96 will not turn over after I did an update that was not completed because it showed an error. What can I do? Thanks
Your phone is dead but you can fix it by taking it to a cellphone repair center. They can flash your cellphone so that the firmware will be fixed. Updating your firmware is simple as long as you have sufficient battery because when the update has been interrupted, it will result to what happened to your phone. Also make sure that the usb cable will not be moved..
Apr 25, 2011 | Nokia N96 Cell Phone
I have downloaed ebudy on my nokia 5130 XM, but it's not installing.It shows connection failed.Something about java settings.What to do?PLZ HELP!
1. first install phoneix service
2. open it
3. In Phoenix, click File>Manage Connections.
4. Now click New.
5. Now select the type of cable you are using. If you are using DKE-
2, CA-53 [N-Series] cable, select USB.
6. Click Next. It will find your product and say FOUND. If it doesn't
find any, you can try changing your cable type by clicking Back.
7. Click Next and then Finish.
8. Now your cable type [USB] appears in the connection list. Select
it. Click APPLY and then CLOSE.
9. Now select File>Open Product.
10. A list of RM code will open. Select your phone's RM code. Like
RM-133 for Nokia N73. Click OK
11. Now select File>Scan Product.
12. Your phone's firmware info will appear at the extreme bottom of
the Phoenix window.
13. Now go to Flashing>Firmware Update.
14. A window will open.
15. On that window click Browse button [the one with three dots].
16. A window will open with various products and various regions.
Choose the region or country of your choice according to the
language pack you want to install.
17. Click Ok.
18. Click Refurbish.
19. Now your actual flashing has started. Don't touch your phone or press any button until the flashing has finished. Also don't touch your data cable and your computer system.
20. At the end Phoenix will tell you to remove your phone as the
21. Now wait for your phone to reboot into latest firmware.
22. The flashing procedure takes 8-9 minutes, a lot faster than Nokia
Software Updater.
Flashing dead phones [Which show only white screen on startup]
Note: You can install any firmware in dead phones whether it is latest and
or the old one.
1. The procedure is the same for flashing Dead phones.
2. Start Phoenix. Connect your phone with USB Cable [phone is off
at this time].
3. Click File>Open Product. Select your RM code from the window
that appears. Click OK.
4. Click File> Manage Connections. Select No Connection. Then
APPLY and CLOSE.
5. Now straight away click Flashing>Firmware Update.
6. A window will open. Click on Browse button [the one with 3 dots].
7. A window will open with various products and various regions.
8. Check the option "Dead Phone USB Flashing".
9. Click Refurbish.
10. Flashing has started.
11. After some seconds flashing will pause asking you to turn your
phone ON.
12. Press POWER button of your phone until backlight comes up.
13. Flashing will proceed.
14. Your phone will automatically start when the flashing finishes.
After finish you can safely remove your data cable
AND THEN INSTALL E BUDDY>........
Jan 20, 2011 | Cell Phones
My nokia n72 phone has been affected by virus. please give a solution
download the software by the given link
http://download368.mediafire.com/zhg7o8ua5dog/toyyinzjmtv/Phoenix_Service_Software_2010.08.004.41526.exe
follow the steps
2. open it
4. Now click New.
the Phoenix window.
17. Click Ok.
Software Updater.
or the old one.
at this time].
APPLY and CLOSE.
9. Click Refurbish.
phone ON.
Jan 20, 2011 | Nokia N72 Cellular Phone
My nokia x3 is not switched on.
2. open it
4. Now click New.
the Phoenix window.
17. Click Ok.
Software Updater.
or the old one.
at this time].
APPLY and CLOSE.
9. Click Refurbish.
phone ON.
Jan 20, 2011 | Nokia Cell Phones
I am mehraj sir plz tell me how i can format or flash the nokia 5300
1 .First downlad phoneix service
2 .open it
4. Now click New.
the Phoenix window.
17. Click Ok.
Software Updater.
or the old one.
at this time].
APPLY and CLOSE.
9. Click Refurbish.
phone ON.
After finish you can safely remove your data cable from h
Jan 09, 2011 | Nokia 5200 Cellular Phone
My nokia 5130 comes to white colour screen
1 .first download phoneix service
2 .open it
4. Now click New.
the Phoenix window.
17. Click Ok.
Software Updater.
or the old one.
at this time].
APPLY and CLOSE.
9. Click Refurbish.
phone ON.
Jan 09, 2011 | Nokia 5130 Cellular Phone
My calculator is gone.. how to recover it please tell... i have tried by restoring factory settings but nothing happened.. please help!!!
You cannot recover the calculator without flashing /update firmware the phone So, you have to do something just follow the instruction..
Firstly try to download this http://www.driversdown.com/drivers/Nokia-Phoenix-Service-Software_92760.shtml
Secondly download
7210cfile And install it in your PC..Disconnect all usb devices.
Now connect the phone with usb data cable without power on the phone to PC.Open Nokia pheonix...Click to "FILE" and select "open product" Choose7210c rm436.Next Click to "Flashing" and then open "FPS-8C FLASH " after opening this just click to "Close" button and again click to "Flashing" select "FIRMWARE UPDATE" NOW you can select the firmware version as well as the product code at the top right whch is showing a small browse window.Remember if the product code of the particular is not there just select the highest one.
After loading ..Click to "Dead phone" and again press to "REFURBISH"
Wait until a message shows that "PRESS POWER BUTTON" Press it and wait until the phone automatically switch on.
Good luck.......thanks for votes
Sep 28, 2010 | Nokia 7210
I cannot switch on my nokia 3110c. when i try to switch it ON, it flashes once and automatically switch OFF.
This is 100% software problem you need to flash/update firmware the phone contact mobile tech,But now you can do it by yourself if you have the requirments ..
3110c files Secondly download
Now connect the phone with usb data cable without power on the phone to PC.Open Nokia pheonix...Click to "FILE" and select "open product" Choose 3110c rm237.Next Click to "Flashing" and then open "FPS-8C FLASH " after opening this just click to "Close" button and again click to "Flashing" select "FIRMWARE UPDATE" NOW you can select the firmware version as well as the product code at the top right whch is showing a small browse window.Remember if the product code of the particular is not there just select the highest one.
Good luck.......
Sep 21, 2010 | Nokia 3110 Cellular Phone
Help !!!! Firmware updates scx 4521f
FLASH UPGRADE There are methods to update the Flash. (1) Local Machine • RCP (Remote Control Panel) mode This method is for Parallel Port or USB Port. Connect the PC and activate the RCP (Remote Control Panel) to upgrade the Firmware. < Method > How to Update Firmware using RCP 1. Connect PC and Printer with a Parallel Cable or a USB Cable. 2. Run the RCP utility and select Firmware Update. 3. Search for the Firmware file to be used to update the set using the Browse Icon. 4. Click the Update icon. The firmware file is transmitted to the Printer automatically and the printer is initialized when the download completes. 5. Click the Refresh icon and check that the updated version numbers are displayed.
Aug 19, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Olympus Vr-340 16mp Camera Digital Optical Zoom With 10x Logo
285 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
