Question about Toshiba 57H82 57" Rear Projection Television
Toshiba 57H82 hyper module
In the process of removing hyper module. Got as far as the module but can't figure out how to remove the module itself. Can you explain this process.
Toshiba 57H82- Distortions on the picture screen
You have leky caps in your regulated power
supply they are typ 220 uf 200v and are large
and round next to flyback
Jun 23, 2009 | Toshiba 57H82 57" Rear Projection...
Removing the hyper board
I ordered a Next HYPER Board, PD0264A (as seen in the service manual). I ordered it from Vance Baldwin Electronics (vancebladwin.com) The only part available is a substitute, PN 23148017 MODULE, SCAN CONVERTER. The cost was 219.50. It was backordered so it did not arrive for almost 3 months. Install is a little tricky. It is accessed from the back. You need to remove the input board, the video processor, and some brackets to get to the Hyper board. The hard part is putting the TV on either its front or back (much eaiser if its laying on the screen, although more dangerous) and then desoldering for tabs that go through the signal board. There is a lot of solder on these and two of them have been twisted for some pain in the **** reason. They are difficult to twist back without damaging anything. When it is desoldered and twisted back, the board should come out. Be careful not to crack the signal board when pulling this out as I did. See above for what it does. I found a slight chip in my signal board and it took some difficult board repair to get the runs connected again (please be careful, as the repair is difficult and not nearly as relaible as an unbroken board.
Anyways, install your new board, put everything back, and power it on. I'm sure you'll have to do a convergance and some other adjustments, but if your doing this fix, a convergence should be cake. My problem has been fixed and I'm thrilled to not have to trash my TV.
Jan 22, 2009 | Toshiba 57H82 57" Rear Projection...
Service Manual
Jimmy,
Will send it out post haste... But be VERY careful inside the hyper module you can easily lift the traces when trying to remove the smd caps and ruin the module beyond repair...
Just send me a private mail and I'll return with the service manual.
Bill
Premium Technologies
premtech@willapabay.org
Oct 14, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba
Just pull the hyper module and send it in for rebuild - then simply reinstall it...
Bill
Jun 15, 2008 | Toshiba 57H82 57" Rear Projection...
Shakey screen
Needs to have the hyper module repaired... There are a group of caps on the hyper that need to be replaced... The hyper module is a stand-up board on the left looking in the back of the unit just behind the jack panel... Need to remove it and send in in for rebuild or attempt the repair yourself..
Bill
Jun 12, 2008 | Toshiba 57H82 57" Rear Projection...
Same Prolem with Toshiba 57H82 57
Just sent the manual via Pando - If you don't already have Pando you will need to download it first. It's a free download..
Bill
Apr 13, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82 57 in. Rear... Problem
Matt,
Sent a copy of the manual via Pando... Download Pando first, it's free...
Then download the manual from the link you're provided...
I repair hyper boards for $160.00 including the shipping back to you...
Bill
PO Box 442
Long Beach, WA. 98631
Mar 20, 2008 | Toshiba 57H82 57" Rear Projection...
Tv only watchable through component Toshbia 57H82
this is a known problem with these toshiba tv's, they will do nothing to help you we should form a consumer group and complain to Washington! The part that needs to be replaced is a hyper pcb,pd0637and is available from Tritronics, in Miami Fl.phone #1-800-365-8030.the part cost me $263.00
Dec 06, 2007 | Toshiba 57H82 57" Rear Projection...
TOSHIBA 50HDX82 - hyper board failure
Toshiba likes to solder shields / covers in place.......check..
Small boards have a side clip = release with screwdriver while
releasing end clips = hard to describe, best to visually inspect.
I will let you know about service literature = CD ROM.........T.
Nov 07, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 57h82 replacing caps on hyper board
trace them with a continunity meter and all will be ok...
Sep 17, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
292 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
