Question about Acer Extensa 5420-5687 Notebook
Keyboard is locked
I loaded A T & T wireless USB Connect Mercury. I had to turn off and restart. WHEN it restared, the keyboard is locked and I can't get past the Password Window
  • maryduke Apr 02, 2009
    loaded at&t software cannot get keyboard or touchpad to function
    so it apparantly disabled my drivers, I can get in through safe mode, and also when I hooked into a usb mouse, it worked. This started after I loaded it and went to restart.
How to turn the wireless capability on a dell slate st series
You may turn ON the wireless capability by following the instructions mentioned below:
a)Connect a USB keyboard to the computer and restart the computer.
b)Press the F2 key at the Dell logo to "Enter Setup".
c)Select F9 to load defaults.
d)Select F10 to Save settings and Exit.
WLAN will connect automatically after windows starts up.
Note: If you Wifi driver is not installed, you may download the required driver from the below link:
http://downloads.dell.com/FOLDER01146814M/1/ST_Network_Driver_TKWFP_WN_3.1.2.87-7.4.0_A07.EXE
Hope this helps.
Mar 05, 2015 | Dell LATITUDE Computers & Internet
Tip
Wireless keyboard and mouse
Most problem with the wireless keyboards and mice are one of them is not responding or not connecting to the wireless USB adapter that's connected to the computer, here are the things that you may do:
1. Make sure to use fresh batteries.
2. Verify if the keyboard and mouse are turned ON.
3. Avoid putting any possible wireless interference such as base of a cordless telephone and cell phones.
4. In pairing up the keyboard or the mouse, try pressing the connect button on the USB wireless receiver followed by the connect button on the wireless keyboard or mouse.
5. If that did not help, then hold down both connect buttons (on the wireless receiver and on the keyboard or mouse at the same time for five (5) seconds and then release them both).
The keyboard or the mouse should connect to the USB receiver. If same problem occur, then the device needs repair.
on Dec 01, 2009 | Computers & Internet
My computer will not read the mouse or keyboard, which worked earlier today. Just installed a antivirus protection on my computer restarted it and cant get past the user account screen.
Connect a usb keyboard if you were using the one with pins or vice-vesa, Restart the computer and watch the lights on your keyboard if they blink while restarting. If it works, restart again while pressing F2 or Del to get to the BIOS settings. In the BIOS, go to Load Default/factory settings or values. Hit F10 to save and exit. Switch it off, re-connect your keyboard and mouse and restart. If all this doesnt work, I suggest that you put the Operating System Disk and repair it.
Dec 19, 2011 | HP Computers & Internet
I have a gateway mx6453.every since i gooked up my wireless gear via usb, the keypad on the laptop has the numbers on the letters UIOJKLM stuck into number ock even when I unplug the wire less. what...
this may sound weird to you but turn off the laptop, remove the bezel, screws and the keyboard. start the computer until you get a keyboard error. enter the bios and restart with f10 and enter. when it restarts, shut off the laptop again. reinstall the keyboard. restart the computer and try to use the locked keys. i doubt the usb wireless caused this. if the keys are still stuck, then the keybaord is faulty. spill liquid on it?
Jan 28, 2011 | Computers & Internet
How do I connect F8E825eaUSB to my Samsung mini notebook N510
Well please follow the below steps -
1. Shut down the notebook.
2. Connect the receiver either directly or with the USB
extension cable to the USB port on the PC.
3. Place the receiver beside the notebook or desktop PC.
4. Turn on the PC.
5. Switch on the power of the wireless mouse located on
the backside of the mouse.
After that you need to install the driver please follow the below steps -
1. Insert the installation CD into your CD-ROM drive.
2. The CD should automatically load the installation. If it
does not load, click “Start” then “Run”, then type “X:\
setup” (replace “X” with the correct drive letter for your
CD-ROM drive, usually D). Then follow through the onscreen
instructions to complete the installation.
3. When the setup is complete, the system will restart
automatically. It will show a mouse icon in the bottom
right-hand corner of the screen.
Please follow the below link to download the owner's manual (Please follow the owner's manual for more information with pictures)-
http://safemanuals.com/414159.php?ID=1150132&k=2e40c3e810da174a496e00f48f318480&q=BELKIN%20SOURIS%20OPTIQUE%20MINI-WIRELESS#F8E825EAUSB
(Just copy and past the above link in your web browser)
Please post comments if you need more help or information......
Good Luck!!
Thanks
Mar 02, 2010 | Belkin F8E874 Mouse
GE Wireless "Malfunction" "Unknown Device"
Does the mouse and/or keyboard have a "connect" button on the bottom of either? Try restarting your PC, then, if you have installed new batteries, and the mouse/keyboard is still not connected, try the "Connect" button if any.
Jan 01, 2010 | GE Wireless Optical Mouse
Logitech MX 5000 Wireless Laser Keyboard & Mouse Combo
HELLO, ALL YOU HAVE TO DO IS TO DOWN LOAD THE SOFT WARE THEN PLUG IN THE USB AND AFTER THAT ON YOUR RECIEVER CLICK THE CONNECT BUTTON ON THE RECIEVER TILL IT RECONIZES BOTH KEY BOARD AND MOUSE I HAVE THE LOGITECH WIRELESS SYSTEM AND I LOVE IT TILL THE BATTERIES GO OUT ON THE MOUSE OR KEY BOARD LOL THEN RESTART YOUR COMPUTER.
Apr 05, 2009 | Logitech Cordless Mouse
Microsoft wireless keyboard stopped working
There are a couple ways to fix the num lock problem. The first is to enter the BIOS setup when you first turn on your PC. The second involves a registry edit. Neither is difficult to do, but if not done correctly can cause serious damage to your PC.
If you feel confidant we can assist with this.
Mar 14, 2009 | Microsoft Wireless Laser Desktop 3000
Keyboard locked
Hi there
If its a wireless keyboard press the "connect" button underneath and check the batteries.
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Logitech 967437-0403 Keyboard
Labtec ultra flat wireless desktop usb mouse & keyboard problems
im having simular problems but manage ome times by tapping caps lock,scrol lock and num lock from the momment you pc starts till the caps lock majes a noise, then i know its working, if mouse starts mocing slow and not clicking it is your batteries, got me mad this has and dunno how i aint smashed it lol
Jun 13, 2008 | Labtec 9674170403 Keyboard
Acer Extensa 5420-5687 Notebook Logo
112 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
