Question about AEG Lavamat 74640 Front Load Washer
E30 error for washmachine - AEG Lavamat 74640 Front Load Washer
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
Pressure sensing
Posted on Mar 31, 2013
Canon irc2100
Sir, there doesn't seem to be an error code accounted for that reads E30.
Canon IRC 2100 Service Repair Manual
That is the link to the service repair manual which also has the error codes so you can diagnose what is going on although there doesn't seem to be an E30 code accounted for.
This is a more extended list of all of the error codes and once again there seems to be no E30. There are 9 pages of error codes if you'd like to look.
Error Codes Canon iRC2100 page 1
Perhaps a mistype?
Aug 30, 2014 | Canon iR 2016i Black and White Copier
Frigidaire affinity washing machine E30 error message
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Nov 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
What does error 10 mean on a front load washmachine
thermal protection motor: test for defective.
or call to some service tech for assistance.
God bless you
Jul 02, 2012 | Kenmore Washing Machines
Error e30 on mp198 printer
Error E30 are not related with resetting printer :D. Error E30 is caused the main board or board of the printer wet by ink or other liquid things that make some components of the board short. Maybe temporary short and also permanent short, it caused printer mall function. in my experience on the canon printer board is only temporary mall function till we clean the board. You can clean it with thinner or other liquid cleaner.
source : http://scmedan.com/2012/how-to-fix-error-e30-canon-printer.html
Jul 16, 2011 | Canon PIXMA MP190 All-In-One InkJet...
F21 error on kenmore he2plus washmachine. Door locks. Due to no spinning and water remaining in the machine? I run the rinse/drain&spin program (15 minutes) several times. it stays at 15min remaining...
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 23, 2010 | Kenmore HE2 Plus Front Load Washer
Hi, i have an AEG washmachine and it is displaying an error code C9 does any one know what this is. Thanks.
C9 is motor problems, its possible the brushes need changing and the machine re-setting, needs an engineer I'm afriad.
Sep 19, 2009 | Washing Machines
Calypso washmachine
you have a flood condition,,or overfill,,we must get rid of the water it seems the pump cant do it,,also it can be tripped or make this display fl if to much suds are in unit ..press stop than cancel and it will clear...than put unit in drain,,if water doesnt drain we have a drain problem that caused the fl error..onthejob
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
Jan 18, 2009 | Washing Machines
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
AEG Lavamat 74640 Front Load Washer Logo
105 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
