Question about HP OmniBook XE3 Notebook
Backlight suddenly disapears.
When I take out the adapter, put it in again and restart the pc, the light comes on again. This happens quite often. Sometimes it comes back when I change the angel of the screen a little bit. What`s the problem ?
    Sergeant:
    Novelist:
  • 200 Answers
Sounds like it could be a loose connection to the backlight. This can happen with the opening and closing of the machine over time. The only way to check is to open the case and possibly remove the screen in order to check the connections. It could also be that the backlight is starting to fail. This is not a serviceable part and would have to be replaced.
Posted on Jan 20, 2013
2 Suggested Answers
camille zar
  • 95 Answers
SOURCE: backlight keeps going out
hi
there are possibly two answers to your situation.
  1. the connector which connect the display with the motherboard is not properly connected.
  2. the display module in the motherboard is malfunctioning
in both the cases you must call the customer care.and if your system is under warranty they will repair it for free.
if you find the solution useful plz rate me carefully.
thnx
Posted on Jul 02, 2009
MY PROBLEM IS THAT I HAVE A 1998 SEBRING CONVERTIBLE ,MY ALTERNATOR LIGHT COMES ON ,ONCE IN A WHILE AND THEN IT DIMS ALL THE LIGHTS BUT WHEN I TURN IT OFF AND RESTARTED IT DISAPEARS AND THE LIGHTS
alternator voltage regulator failing have alternator checked out at any auto parts stores.they can check alternator out put with battery in car while engine idling.most time alternator failing will cause headlights dim and vechile stall out.
Dec 24, 2012 | 1998 Chrysler Sebring
Engine suddenly quits with no warning
Without knowing where the sound is coming from, theres no way to know if it is important.
Is it possible the noise is the ac clutch, and the ac compressor is locking up and killing the engine ?
Sep 24, 2012 | Cars & Trucks
I have a GigaByte M1022 netbook. It comes with an LED backlight.. But for some reason the backlight doesnt light up anymore... Its 4mnts old. I have restarted, etc, which didnt resolve the issue.. How...
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 23, 2011 | Gigabyte BOOKTOP M1022 Notebook
Light is turning red not green and sometimes dosent come on when xboox is turned on
the adapter only comes on usually when the xbox is turned on and booting itself up. try restarting the xbox over and over again and replugging in the adapter.If the light is red that meanes its on and running but cannot connect to your router or modem etc. if this is happening reconfig your connection so it recognizes your router.IMPORTANT: if you have security on your router you must enter everything in before you can connect. If your adapter still doesnt read your router you must be out of range or the router is not putting out a signal.
Feb 05, 2010 | Microsoft Wireless Network Adapter Xbox...
Dim Laptop screen
It could either be your power settings dimming it (battery saver mode), or more likely when you replaced the screen, you replaced the backlight with the one that came with it. The replacement backlight is probably not as good as the one you had. You can try putting your other backlight in it (the backlight is that circuit board near the hinge that you plug in when you switch the screens out). Since it's going in and out, I'd check the power settings first though.
May 04, 2009 | IBM Computers & Internet
Windows xp problem
you need to disconnect the "e" drive and see if "D" comes back.
if not dissconnect d drive and set e to master and see if e comes back as d drive
Feb 12, 2008 | Microsoft Windows XP Professional With...
Sound not coming out from the center OR the rear speakers
To play soud ...it needs sound driver... which comes in mother board cd..
Sometimes it happens... No sound....then that case, RESTART u'r system... if problem persist then install audio driver once again from u'r mother board cd...
Avoid loose connection..... Power on!!!! Off... of sound system in the middle of use of u'r PC.
Dec 27, 2007 | Logitech X-530 Computer Speakers
Series Back Light
It is possible that by holding the power button down too long, that you turned off the backlight. When you hold down the power button, a menu eventually comes up with "Backlight Off" highlighted. The easiest way to undo this, is to simply do a soft reset. Or, you can hold down the power button again, and "Backlight On" will be highlighted (if there's enough ambient light you can see this message); just tap it, and the backlight will come on again. Also check out your backlight settings by tapping: [Start][Settings]tab[System][Backlight] the tab [Battery Power] should be highlighted; adjust as desired. Next tap the tab [External Power]; adjust as desired. Finally, tap the tab [Brightness] and make sure the sliders are high enough.
Sep 07, 2005 | HP iPAQ H6300 Pocket PC
HP OmniBook XE3 Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
