My Coleman Direct Vent Forced Air Furnace
The model number is 7970-656/D and its also a gas furnace, ive read similar posts about this, pretty much i can get the pilot started and the cooling fan will start but the actual fan that pushes the air through the place wont start, not to mention after getting the pilot light to start after a little bit it will go out. Im guessing because the fan that pushes the air through the place wont kick on, my neighbor says its prolly the pressure switch needing to be replaced. Either way please help? Its cold and id like the easy fix...not the lots of $$$ fix please lol
  • Matthew Jan 20, 2013
    The pilot light does actually light up...it just doesnt stay lit because the blower fan that pushes the hot air through the place doesnt start so the pilot goes out
  • Heating & Co... Master
  • 2,597 Answers
First clean pilot , then clean flame sencor this cost nothing only time , check tubes to pressure switch are tight not split of blocked , take asmall drill bit and clean out the connections on the pressure switch some times these can block ,blow it out after you have done this put tubes back on , then check air fitler is clean , you can try and jump ou tpressure switch some times you can fool it in to working , try doing this it may help.
Posted on Jan 20, 2013
5 Suggested Answers
jcpark50
  • 52 Answers
SOURCE: Manual for a Coleman Forced Air Furnace manual
If you haven't already tried Coleman customer support, try Google. You can find owner's manuals for all kinds of things. good luck, John
Posted on Nov 07, 2008
kdgrayson
  • 195 Answers
SOURCE: The pilot loghts in my forced-air furnace, but
ignition module, pressure switch and its tubings attachment orifices plugged
Posted on Dec 03, 2009
  • 557 Answers
SOURCE: We have a Colman Direct
thermocouple is bad, thats the little probe that sits in the pilot flame, and runs back to the gas valve
Posted on Oct 23, 2010
walterkunesk
  • 683 Answers
SOURCE: I have a coleman direct
Question? does it try to start?
Posted on Sep 17, 2011
Testimonial: "was a great help"
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
I have a coleman 7956c856 direct vent forced air furnace it ignites fine but the blower wont kick on
main fan should come on once furnace has heated up to supply hot air to the house. make sure proper voltage going to the fan. fan relay in board may be shot
Jan 29, 2014 | Goodman GMS90703BXA Heater
I JUST BOUGHT A USED COLEMAN EVCON FURNACE MODEL #BGU09516 AND I NEED TO KNOW HOW TO VENT IT. PLEASE HELP, THANKS
It should have a two part chimmney with a 4 inch inner exhaust section and a larger 6 inch outer section that goes over the flange on the top of the furnace. If your existing chimmney does not have this you may have to buy a chimmney kit for a mobile home application.
Dec 11, 2009 | Coleman Propane Forced Air Heater...
Need help with problem
Once you lit the furnace did you turn the valve to the on position. Russ
Jul 20, 2009 | Coleman Propane Forced Air Heater...
Furnace clicks multipal times while running.Is this normal?
As it starts and stops several switches will open and/or close, sometimes you can hear them. When it's just running then it may make a few noises from expansion and/or contraction.
Mar 30, 2009 | Coleman Heating & Cooling
How to wire a Coleman proprane furnace
I just bought a houseboat with the same furnace in it.  I will check it this weekend and provide you with the wiring directions should you still need them.
Mar 07, 2009 | Coleman Propane Forced Air Heater...
Nov 07, 2008 | Heating & Cooling
Coleman direct vent forced air gas furnace and asthma
maybe try a UV light on the duct work, my son has same problem and i installed a UV light and the house smelt better and my son could breath better.
Nov 02, 2008 | Heating & Cooling
Coleman direct vent forced air furnace
I am a furnace technician and to solve the problem.You will find on the opposite side of the ignitor their is a flame rod with a wire connected to it.Remove it and clean it with sandpaper and re install it and it should fix the problem.If this is dirty it won't sense ignition and the board thinks that is it introducing raw gas into furnace and it isn't igniting and shuts off as a safety precaution.If you see a blueish tinge on the flame rod you should probably replace it.
Jan 30, 2008 | Heating & Cooling
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
