Question about Infinuvo Vacuums
My Cleanmate 365 QQ -2L says Error and only moves in reverse
The display says Error and when Start is taken the machine moves for a short distance is reverse only. Have checked all aspects but can't work out what is the problem. Can anyone help? Is there a technical support phone number for these robotic vacuum cleaners?
ukvacfan
  • 328 Answers
SOURCE: Samsung SC8571 VACUUM CLEANER
Either check your local region of EBAY for any vacuum cleaner repair specialists who may be able to sell you a replacement hose/parts OR enter your postcode in Australia for this Samsung customer service:
Dont forget to rate.
http://www.samsung.com/au/support/repairlocation/ServiceLocationsMain.do
Posted on Jun 13, 2008
  • 52 Answers
SOURCE: No suction from vacuum.
Blow out the filter with an air compressor if available. this is causing your problem. its usually a foam filter
Posted on Mar 26, 2009
  • 1116 Answers
SOURCE: I need a Operate Manual
You can find your manual at the link below. Just click and it will open and you can download/print your manual:
http://www.irobot.com/images/consumer/cs/Roomba-owners-manual.pdf
Posted on Jul 05, 2011
jharwell668
  • 640 Answers
SOURCE: my dirt devil Rampage Robotic pool cleaner vacuum
There is a ring that is designed to fit over bottom drains to prevent robotic pool cleaners from getting stuck. There are several different brands/kinds available and any of them should prevent the problem. Here is one example:
http://www.backyardcitypools.com/Automatic-Pool-Cleaners/NE290-Smart-Ring-Drain-Cover.htm
Posted on Jul 20, 2011
SOURCE: panasonic vacuum cleaner MC-5030 stopped and don't work
Unplug, check if brush has cord wrapped. Check for fuse, if applicable.
Check power lead in another supply socket. Check for reset button, if applicable. Contact Panasonic technical support for suggestions before heading to service centre.
Posted on Jun 17, 2012
Unit starts, moves a short distance (a couple inches), turns 90 degrees, moves a short distance, etc.
Fully charge the unit, then put him/her (C'mon, we all assign a gender to our roomba, don't be shy about admitting it) on the floor and press the "Clean" button three times. This resets him.
Jan 06, 2016 | iRobot Roomba 540 Vacuum
The hose is sucking up but the base plate doesnt?
If you have taken the bottom end of the machine apart, you might not have reassembled it correctly so that the path to the floor (base) plate is obstructed when the vacuum cleaner body is laid back, otherwise:
You have either a blockage in the section of the cleaner in the vicinity of the short flexible hose and the floor (base) plate or the the short flexible hose has become detached at one or both ends.
1. Stand the machine upright with the beater bar in the "off " position. Machine switched off but plugged into the mains outlet.
2. Lay machine on its left hand side. You will see the short flexible hose uppermost. Check that it is attached at both tends and has not split or cracked. Check for obvious visible obstruction inside.
3. Remove the floor (base) plate by releasing the three plastic clips with a quarter turn anti-clockwise. Lift floor plate forwards and check no obstruction. Replace floor plate. Stand machine upright on floor.
4. Press two plastic clips to release the inspection cover, on bottom right hand side of machine (when standing behind it). Look into the hole: you will now be looking down into the U-bend that leads to the hose. Switch on the machine: full suction should be at the hole on the side of the machine (otherwise the hose would not have worked). Switch off.
5. Lean the handle and machine body backwards, as though you were going to use the machine on the floor. The hole to the hose now becomes covered and you will be able to see into the short flexible hose that leads to the floor plate. Check for obstruction. Replace inspection cover.
If there's no obstruction and the flexible hose is sound and attached securely then the machine will work - there's nothing else to check.
Jul 10, 2014 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Only suction from hose
What again for the third time? Already answered this but if it helps:
Jul 05, 2014 | Dyson Vacuums
After running a short time ok, it starts going in circles, then gives error code 9
The nine-beep error means you have a dirty or defective bumper sensor. You might want to start by spraying compressed air around the sensors to move and dirt or debris that are causing the vacuum to think it is jammed against a wall or furniture.
Feb 28, 2011 | iRobot Roomba 560 Robotic Vacuum
User manual
Hello, I too could not locate the manual. I did however, locate a "video on Youtube on how to use the QQ-2. Link is below.
I hope this helps!
-CBR2009
http://www.youtube.com/watch?v=fR4rfVfd_Pw
Jul 11, 2009 | Infinuvo QQ-2 Robotic Vacuum
Hoover agility--poor suction, still!
When you remove the dirty water tank, on the machine, there is a screen that gets clogged and will prevent good suction, is this one clean? If it is, do you feel suction at that screen, if so then there is a problem with the tank. If no suction there, then you will have to check it over for a air leak or a bad seal.
Apr 29, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Vacuums Logo
71 people viewed this question
Top Infinuvo Vacuums Experts
JoeVacs
Are you an Infinuvo Vacuum Expert? Answer questions, earn points and help others
