Question about Kitchen Ranges
Ge profile electric range display not working
The heating element burned out. I know this can be easily replaced, but the display panel is not working either. This shows the time and oven settings. Did this go out so that the oven cannot be operated while the element is not working or is there some type of fuse that may have blown?
  • Faddie Ent
    Faddie Ent Feb 05, 2013
    The model number is JBP79B Y2BB. The stove top and controls work. I checked into replacing the display and it runs about $200 at repairclinic.com or appliancepartspros.com--I appreciate everyone's help.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Jan 21, 2013
  • 1 more comment
  • Faddie Ent
    The model is JBP79B Y2BB
  • Richard Roth
    Richard Roth Feb 06, 2013
    Here is that part to order.http://bit.ly/XLCOT1 The part comes with a 365 day, any part, any reason return policy.
  • Faddie Ent
    Faddie Ent Mar 02, 2013
    Thank you. I am going to order that part from Appliance Part pros. Thank you for checking into that.
  • 112 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
Techsim
  • 59 Answers
SOURCE: Oven heat
There is a bottom hidden element that is the main element used for baking and cleaning. If its not heating then the element has gone bad and needs replacing. If you have a volt meter then you can confirm this by checking the voltage between the two terminals sticking out of the rear of the range. There should be 240vac across the two. If you have that then you need a new element if you don't then you need a new control board.
Posted on Nov 03, 2008
BNewberry
  • 93 Answers
Computer is cooked. Sorry to tell you.
I am a factory servicer for Electrolux / Frigidaire
I replace tons of those clock controls. They shouldn't be $160 though
Any questions about these stoves send me and email.
I will be glad to help you out.
Thanks
Posted on May 23, 2008
  • 29 Answers
SOURCE: ge range electric oven won't heat up
WHEN BAKE CYCLE IS SELECTED?
Posted on Jan 29, 2009
jumptrout51
  • 3361 Answers
SOURCE: GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Posted on Feb 21, 2009
Should we repair heat element, or buy a new oven?
It sounds like your element is electric. When food drips on that element it can cause a heat spot on the insulation around the electric element and eventually burns through. You can easily replace that element for about $50 - $60. It requires about three hand tools and 15 minutes to remove old one and install a new one. You should be in business for another 14 years if you clean any drippings on the element itself.
Mar 10, 2014 | GE Profile Spectra JBP95 Electric Kitchen...
My ge profile electric oven will not Heat.
Does the broil still work? Did you check the fuses? Maybe the bottom element is burned through. If so, there is usually a strange looking bubble on it, or it is broken. They go after 4-5 years. If you want to check it pull the plug, then remove screws, usually 2 holding it to the back. Pull it gently out and unscrew the two wires. Check with an ohm meter, or take it in to a place that sells replacements and they will check it. Replacements are about $25
Oct 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
GE Electric Spectra Oven botton element will not heat
If only one element does not work, then test heating element continuity using a multimeter.
If oven does not bake or broil, then test temp probe.
If there is nothing wrong with elements and temp probe , then test wiring harness to control panel and timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 20, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
GE Profile Still Heating with nothing selected
IS THIS A DIGITAL RANGE,IF SO REMOVE THE TOP BACK COVER AND SEE IF ANYTHING ARCED(BURNED SPOTS) ON THE CONTROL BOARD,IF NOT DIGITAL, YOUR OVEN KNOB SWITCH IS STUCK IN CLEAN MODE,I HOPE IT'S NOT THE CONTROL BOARD AS THEY RUN ABOUT $200 ,LET ME KNOW-MIKE
Jun 15, 2008 | GE JBP65 Electric Kitchen Range
Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
Apr 21, 2008 | GE Profile 30" Free-Standing 5 Burner Self...
GE Electric Range
It is very common for elements to "catch fire" when they fail. It is really electical arching. But to answer your question you shouldnt be concerned if it ever happens to the bottom element immediatly kill the breaker it will stop instantly. dont use a fire extinguisher as it wont stop the arching. And most ovens do use the upper broil element for baking for very short intervals like 10secs on every minute or so to brown the top of product. Some models (especially older builder line ) do not
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
