Question about QuarkXPress Passport 4.1 (112283) for PC
Will Quark 4.1 for PC work with Windows XP?
It worked fine on my windows 98 setup, but can it be modified to work on XP?
    Problem Solver:
  • 7 Answers
I still wonder why nobody else has discovered the following, I used Quark 4 on XP. I used it on Vista; Read on:
As a matter of fact I am using Quark 4 on Window 7, I used it on Vista (where it performed better than Vista) and on XP back at least to 98 or perhaps 95 when MS had not yet decided they had fonts (less than) superior to Adobe. My original install required burning a floppy (good luck with that today) for the registration. I never bought an external floppy. At some point, I discovered it was truly portable and simply copied the installed Quark directory to a new location (anywhere) on each new system. I dragged out a shortcut to the executable onto the desktop on every new platform. It still runs fine on this 64bit Window 7. I am running Windows Home and not Professional no Ultimate in emulation mode. It has not blown up yet. Something I wish I could say about other software.
The only rub I found is that MS monkeyed about with associations (which worked fine in XP & Vista) and I have yet to be able to set.QXDs to Quark when I even set .QXTs to Quark.Windows 7 automatically served up In-Design as being the first (default) association in my programs list. Something I did not accept. I even tried to rewrite the registry in an attempt to make it work. If you bust this, please return your registry code.
If a matter of interest, I have a friend who worked on the prerelease 7 and reported they didn't care and he still needles the programmers. He discovered multiple forms of Windows .DLLs that can operate for 64, 32 and 16 bit applications. I don't know if this was the answer but Quark 4 worked on my Vista which was crippleware at best and will probably work on 8 which is be rewritten for LAN and WAN business environments. Hopefully MS can keep their mitts off procedures that work. They have a poor record of that. Look to Source Forge for programmers who might start up a new platform and dig away at the sandy MS foundation.
Posted on Mar 25, 2012
  • W. Michel Mar 26, 2012
    Quark 4.1 worked on 95 and 98. When I got XP, I had to copy the 98 installed directory (having no install floppy) and drag out a shortcut to Quark. I did the same on Vista AND Windows 7 64 bit where it functions better than Vista ever could. I expect it will function fine on Windows 8 which is a fix for 7 which is a fix for Vista. MS mistakes, your money. Save your Quark money by using the one you have.
  • 108 Answers
QuarkXPress is not certified to work on windows XP, you have to upgrade to QuarkXPress 7 or 8 in order to work with it on XP
Posted on Jun 16, 2009
I purchased Quark Xpress back in 1990 or so, and the installation discs were the old 3 1/4 discs. I paid for updaters, and at updater 6.1, I still have the Quark CD, but some of the original Quark Xpress...
I continue to be amazed that no body has found THE elegant solution I did. As a matter of fact I am using Quark 4.1 on Window 7, I used it on Vista (where it performed better than Vista) and on XP back at least to 98 or perhaps 95. My original install required burning a floppy (good luck with that today) for the registration. At some point, I discovered it was truly portable and simply copied the installed Quark directory to a new location (anywhere) on each new system. I dragged out a shortcut onto the desktop to the executable on every new platform. It still runs fine on this 64bit Window 7. Has not blown up yet. Something I wish I could say about other software. The only rub I found is that MS monkeyed about with associations (which worked fine in XP & Vista) and I have yet to be able to set.QXDs to Quark when I even set .QXTs to Quark.Windows 7 automatically served up In-Design as being the first (default) association in my programs list. Something I did not accept. I even tried to rewrite the registry in an attempt to make it work.
In fact, if you look into the .DLLs under Windows, you may find versions of the same .DLL that can run under 64, 32 and 16 bit environments. I suspect it will work under Windows 8 if MS doesn't leave working procedures ALONE!
May 20, 2011 | Quark Academic QuarkXPress 6.1 for PC
I am not expert in computer,my sound from desktop when i start and when i play itunes,vlc media,media player its playing video but no sound it was working from last 4 years ****. please help
Have you changed anything in your settings or setup recently before you lost sound? What platform are you running? Windows 98, windows 2000, Windows XP Home, Windows XP Pro, Windows Vista, Windows 7? or something else
Jan 06, 2011 | Computers & Internet
Can you run quark 4.1 under windows 7
Please! I am using Quark 4.1 on Windows 7 64 bit just as I did on 98, XP and Vista. Without a floppy, I had to copy the installed Quark directory to newer platforms then drag out a shortcut to the desktop. I just published some work to embellish in Acrobat 10. The installer doesn't work; Quark does! I expect it will work in Windows 8 if the MS programmers don't screw with procedures that work fine now.
Oct 04, 2010 | QuarkXPress 4.1 for mac
Error 1720. Trying to install Quark 6.1 on Windows 7
I definitively solved this problem. Follow these steps:
1) Install first Quark Xpress 6.1 on a Windows XP PC.
2) Copy the entire directory of installed files (Normally c:\program files\quark) on a pen drive.
3) Install Quark Xpress 6.1 on your Windows 7 PC until the installation stops with 1720 error.
4) Abort the installations, then copy the Quark directory stored on your pendrive in c:\programs x 86 directory overwriting the existing one.
This way Xpress 6.1 works perfectly on a Windows 7 PC. Guaranteed!
Sep 02, 2010 | QuarkXPress 6.1
Will not print correct as a network printer
1. Define your Star Micronics Printers device model TSP600
2. Define your operating system to install your Star Micronics Printers device
3. Search Printers driver category
4. Find Star Micronics Printers driver
5. Select Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95
6. Download Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95
7. Install Star Micronics TSP600 Printer Network Setup Utility Ver. 2.0.1 Windows XP, 2000, ME, 98, 95
8. Restart or reboot your computer to finish your driver installation.
Download here:
http://www.opendrivers.com/driver/247183/star-micronics-tsp600-printer-network-setup-utility-ver.-2.0.1-windows-xp-2000-me-98-95-free-download.html
Aug 16, 2010 | Star Micronics TSP600 Thermal Printer
How can I install my Quark 7 on my new Windows 7? All I get is 'QuarkXpress 7 requires that your computer is running Windows XP or Windows 2003. Help!
Start the Windows "Program Compatibility Wizard".
Tell it that you want to install a Windows XP application.
Tell it that the software to be installed is on a CD-ROM.
May 29, 2010 | QuarkXPress
I have a windows 98 system bios and i wish to Put a differnt Hard drive in that has windows xp on it . Is there a way to do this
Hi
It probably won't work. Win 98 machines not only had older BIOS but also the processor was older and most importantly the video was older. XP may just not be able to recognize these parts. In my lab I use an old Dell laptop that was made specifically for Win 98. I was able to install XP but the graphics stay in four color mode as there were no drivers ever written for XP. Also the hard drive with XP was probably formated using NTFS while Windows 98 (unless modified) only recognizes FAT. Good luck and sorry
Mar 05, 2010 | Gateway Essential 400 PC Desktop
No mac driver?
Check here for MAC compatible cameras.
Manufacturer/Model Driver version Platforms Meets requirements
3com Home Connect 6.6.4 Windows 2000, Me, 98 Yes
Apple iSight (Firewire) Firmware 1.0 Mac OS X (Pantder) Yes
BTC PC 380 Intel 3.20.1001.0 Windows XP Yes
Creative WebCam Go Plus 1.0 Windows XP, Me, 98 Yes
Creative WebCam (WDM) 1.0.11.131 Windows Yes
D-Link USB WebCam(DSB-C100) 0921 Windows XP, 2000, Me, 98Mac 9.2 and 9.1 Yes*
IBM Ultraport Camera 2 Most Current Windows 2000 Yes
Intel Deluxe PC Camera 1.0 Windows XP, 2000 Yes
Intel Easy PC Camera 1.0 Windows XP, 2000, Me, 98 Yes
Intel PC Camera CS 110 6.0.0.62 Windows X Yes
Irez Kritter USB 1.02b4 Windows 2000, Me, 98,Mac 9.1 Yes*
Irez StealtdFire 1.2 Mac 9.2, 9.1, 9.0.4 Yes
Logitech ClickSmart510 7.0.0.1221 Windows Yes
Logitech QuickCam traveler 6.0.1 Windows 2000 Yes
Logitech QuickCam Web 6.0.1 Windows 2000 Yes
Logitech QuickCam Express 6.0.1 Windows 2000 Yes*
Logitech QuickCam Pro 3000 6.0.1 Windows XP, 2000, Me, Mac 9.2 and 9.1 Yes
Logitech QuickCam VC Windows - 4.1.5 Macintosh - 2.1.2
Windows 2000, Mac OSX, 9.2, 9.1, 9.0 Yes
Logitech QuickCam Zoom 8.0.3.1110 Windows XP Yes
Orange Micro iBOT Pro Firewire 4.10.22 Windows 2000, Mac OS X and 9.2 Yes
Veo Stingray 5.0.0.0 Windows XP, Me, 2000, 98 Yes
Copy this site and paste it in your web browser address bar and hit ENTER todownload the MAC drivers macam version 0.9.2 (current version)
for Logitech Quick Cam.
http://webcam-osx.sourceforge.net/downloads.html
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ )
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.HTML )
Dec 21, 2009 | Logitech Webcam
HOW DO YOU INSTALL A SECOND OS ON A SLAVE DRIVE. I AM RUNNING WINDOWS XP HOME EDITION. I WANT TO INSTALL WINDOWS 98 SECOND EDITION ON A SLAVE DRIVE DISC. SOME PROGRAMS I HAVE WILL NOT WORK ON XP.
You cannot install 98 directly on your system slave drive, but there is a way to install it.
1) disconnect your primary drive
2) make your slave drive as primary.
3) install 98
4) Connect your actual primary drive again and start your system
XP records your mac id of your motherboard and 98 does not records, the other way is, you can install both the OPS on your one primary drive by creating different partitions, you will need to full format your drive first.
1) Full format your primary drive.
2) Create partitions.
3) Install 98.
4) Install XP in different drive of your same hard disk
You will be able to see both your OPS when you start your system.
Sep 18, 2009 | Computers & Internet
Quark XPress 4.1
quarkxpress_56302.jpg Related Tags:
  • quark
  • xp
  • windows 7
  • windows xp
Problem with Quark QuarkXPress
Posted by avatar15.jpgNervousFlyer on May 29, 2010
Solutions (2) Start the Windows "Program Compatibility Wizard".
I continue to be amazed that no body has found THE elegant solution I did. As a matter of fact I am using Quark 4 on Window 7, I used it on Vista (where it performed better than Vista) and on XP back at least to 98 or perhaps 95. My original install required burning a floppy (good luck with that today) for the registration. At some point, I discovered it was truly portable and simply copied the installed Quark directory to a new location (anywhere) on each new system. I dragged out a shortcut onto the desktop to the executable on every new platform. It still runs fine on this 64bit Window 7. Has not blown up yet. Something I wish I could say about other software. The only rub I found is that MS monkeyed about with associations (which worked fine in XP & Vista) and I have yet to be able to set.QXDs to Quark when I even set .QXTs to Quark.Windows 7 automatically served up In-Design as being the first (default) association in my programs list. Something I did not accept. I even tried to rewrite the registry in an attempt to make it work.
MikeE
Jan 04, 2009 | QuarkXPress Passport 4.1 (112283) for PC
QuarkXPress Passport 4.1 (112283) for PC Logo
341 people viewed this question
Top Quark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Michael Galve
Michael Galve
Are you a Quark Computer and Internet Expert? Answer questions, earn points and help others
