Question about Geovision GV-AS200 Controller (2 Door) V2 Access Control Panel 55-AS202-200
How to reset factory gv-as controller without as-keypad
Try and follow the directions at this website...
http://www.usavisionsys.com/forums/viewtopic.php?f=14&t=195
Also, the manual is here...
http://www.usavisionsys.com/forums/viewtopic.php?f=7&t=33
Posted on Jun 30, 2013
How do I reset my tv without remote control?
Without the remote control, you can not do a factory reset; Can only of the hard reset. There are two methods to reset TVs. The first is simple to do; Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it to reset system [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the website linked here. Pull up older posts. Http://electronicshelponline.blogspot.com/
Service entry mode, adjust and exit procedure to many popular brand are given Beheerder TVs. Never forget to exit the service mode, after all adjustments Have Been done.
Jun 09, 2016 | Televison & Video
How to unocked keypad
press *** on the keypad, then enter from the softkey. If the phone keypad was accidently locked you can unlock it without a pw, but if was intentionally locked with a pw the only way to unlock it is either with a pw or to factory reset the phone
Apr 22, 2015 | Grandstream GXP1450
Reset to factory settings xerox 3635 mfp
Solution : Perform a Software Reset The Software Reset utility allows for the reset of the machine software without powering the machine off and on.
  1. Press the [Log In / Out] button on the Control Panel.
  2. Enter the password using the numeric keypad, and then select [Enter] on the Touch Screen.
    NOTE: The default password is "1111". It is recommended that the System Administrator change this password. For additional information, press the [Help] button on the Control Panel.
  3. Press the [Machine Status] button on the Control Panel.
  4. Select the [Tools] tab on the Touch Screen.
  5. Select [Device Settings].
  6. Select [Tests & Resets].
  7. Select [Software Reset].
  8. Select the [Reset System Software] button. A pop-up window will be displayed warning that jobs in the system may be lost, and asking you to confirm that you wish to continue.
  9. Select [Confirm] to perform the reset.
Dec 16, 2014 | Xerox Office Equipment & Supplies
Reset tv without remote
How do I reset my TV without remote control
Jan 02, 2014 | Sanyo AVM-3256 TV
Philips bdp5000 limited reaction to remote control
you must use the MENU for to restore the fACTORY setting.
Howwever you must open the remote control for to cleant the KEYPADS for dirty, grease, with c. cleaner solvents very IMPORTANT.
Otherwise you must to the repair shop TV for fix it.
God bless you
Jan 25, 2013 | Televison & Video
Factory reset code for samsung gt-s3650
Here's the factory reset code for your Samsung Corby Genio Touch:
On the main menu(desktop) type in the following using the virtual keypad:*2767*3855#
  • Warning: All data & setting in phone erase & reset to factory default automatically without any confirmation
Feb 22, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
How to reset anti theft system
KEYLESS ENTRY SYSTEM You can use the keyless entry keypad to:• lock or unlock the doors without using a key.• open the trunk.• recall memory seat/mirrors/steering column/adjustable pedals positions1 or 2. The keypad can be operated with the factory set 5-digit entry code; this code is located on the owner's wallet card in the glove box, is marked on the computer module, and is available from your authorized dealer. You can also create your own 5-digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation. Programming a personal entry code. To create your own personal entry code: 1. Enter the factory set code. 2. Within five seconds press the 1 • 2 on the keypad. Note: The lock motors will cycle, locked then unlocked 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other. 4. Enter a sixth digit to indicate which personality feature should be recalled by the personal code. Note: The lock motors will cycle, locked then unlocked. • 1 • 2 recalls driver personality 1. • 3 • 4 recalls driver personality 2. • 9 • 0 does not recall a driver personality. Wait 5 seconds without pressing a keypad button in order to store a personal entry code. Tips: • Do not set a code that uses five of the same number. • Do not use five numbers in sequential order. • The factory set code will work even if you have set your own personal code. • If you set a personal code and store it over an existing personal code it will erase that personal code only. Erasing personal code 1. Enter the factory set 5-digit code. 2. Press and hold the 1 • 2 for two seconds and release; this must be done within five seconds of completing step 1. 3. Press and hold the 1 • 2 for two seconds to erase the customer programmed code; this must be done within five seconds of completing step 2. Your personal code is now erased and only the factory set 5-digit code will work.
Feb 09, 2011 | 2002 Lincoln LS
Is it possible to program keypad code without the factory code?
No this is a safety issue because if you could make your own code without the factory code then anyone could make their own code for your vehicle and break in. You should go back to the dealer and have them reset the code for you.
Mar 03, 2010 | Ford F-250 Cars & Trucks
How to reset the keypad on my 2004 navigator
You must have the original code to change it, if u do here is how you do it.
With the keyless entry keypad, you can:
• lock or unlock the vehicle doors without using the key,
• release the liftgate glass,
• enable or disable the autolock function, and
• add or delete a 5–digit personal user code.
Your vehicle has a factory set 5–digit code that operates the keyless
entry system. You can also program your own 5–digit personal entry
code. The factory-set code is located:
• on the owner’s wallet card in the glove compartment,
• at your dealer,
• or on the module located under
the right-hand side of the
instrument panel, adjacent to the
passenger compartment fuse
panel.
Note: The 5–digit code (e.g. 12345)
will be in large, BOLD numbers on
the module label.
When pressing the controls on the keyless entry keypad, press the
Programming your own personal entry code
To program your own code:
6. Enter the factory set code (keypad will illuminate when pressed).
7. Press the 1 • 2 control within five seconds of Step 1.
8. Enter your personal 5–digit code.
Enter each digit within five seconds
of previous one.
9. After the code is entered, the
locks will cycle, confirming that the
new code has been set.
Do not set a code that includes five of the same number or presents
them in sequential order. Thieves can easily figure out these types of
codes.
Your personal code does not replace the permanent code that the
dealership gave you. You can use either code to unlock your vehicle. If a
second personal code is entered, the module will erase the first personal
code in favor of the new code.
If you wish to erase your personal code, use the following instructions:
2. Press the 1 • 2 control and release.
The system will now only respond to the factory set code.
Nov 25, 2009 | 2004 Lincoln Navigator
LOST REMOTE CONTROLL CANT RESET PASS WORD
try to go to their homepage for assistance ,since this item no longer available,heres the link : www.govideo.com/?GV=DP5040
Apr 22, 2008 | GoVideo DP5040 Portable DVD Player
Geovision GV-AS200 Controller (2 Door) V2  Access Control Panel 55-AS202-200 Logo
85 people viewed this question
Top Geovision Home Security Experts
Lawrence Oravetz
Are you a Geovision Home Security Expert? Answer questions, earn points and help others
