Question about Canon iP4700 InkJet Photo Printer
My Canon IP4700 will not recognise Ink Tanks - Canon iP4700 InkJet Photo Printer
SOURCE: Error messages: U150 + Ink tank errors have occured
An on-line problem solver answered this question for me as follows, and it worked beautifully. I had previously tried just removing the ink cartridges, and then re inserting them, but that did not work.
"This is a somewhat common problem with the metal contacts that connect to the ink cartridge. Sometimes it can be fixed by cleaning the contacts, but other times it requires getting a new ink holder from Canon customer service.
To clean the contacts, you'll need a Q-tip and some isopropyl alcohol (it's important that it is isopropyl and not another kind of alcohol). Pull out the ink cartridges and clean the contacts on each one with the Q-tip dipped in alcohol. In particular, you want to make sure there are no fingerprints on the contacts. Then, turn off your printer and do the same with the contacts in the ink holder in the printer. Once the alcohol has dried on both sides, reinstall the cartridges and give it a try.
If this doesn't work, I recommend calling Canon tech support, so they can send you a replacement part."
According to Canon's instruction manual, you must complete the cleaning in less than 10 minutes. It took me about five. I did exactly the tech suggested, and after turning everything off and waiting a minute or so, I restarted everything, and the problem was solved.
You must be careful though, because if you leave a Canon Pi6600 cartridge out of the printer for more than 10 minutes, not only will the cartridge tray move back to the "off" position (out of reach), but the ink cartridges nossles will dry out and possibly not work. Also, do not "squeeze" the ink cartridges or you will get ink on yourself.
Posted on Jan 10, 2009
  • 8 Answers
SOURCE: Some ink tanks can't be recognised
please remove the cartridge and printer of after smoth cloths is in water and clean the cartridge cerkit and opp sid in cartridge ( onder of printer) please clean and after 10minuts will you chaked.
Posted on Jul 28, 2009
Reset Canon MP600 to the Factory Setting
  1. Press the HOME button.
  2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
  3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press the OK button.
  4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset settings, then press the OK button.
  5. Use the Easy-Scroll wheel or the up/down arrow to select Yes on the confirmation screen and then press OK.
  6. Press the HOME button to return to the HOME menu.
Posted on Sep 12, 2009
Razz_1976
SOURCE: Canon iP4300 - ink tanks not recognised
Buy HP instead Canon :) This is the only solution..
Posted on Nov 09, 2009
  • 1218 Answers
SOURCE: Canon iP4700 with error 6C10
It's probably a waste absorber issue.
A fix from FixYa Support:
1. Start with printer off
2. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
3. While holding the Power button, release the Resume Button.
4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
6. Turn off the printer and turn on again
http://www.fixya.com/support/t5998845-error_code_6c10_mean
Hope this helps.
Posted on Sep 27, 2010
Canon ip4700
Hi Louis-Georges
Please try the following to see if we can resolve your issue:
1. Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Place the print head back in and lock the lever down.
6. Place all of the ink tanks back in the printer.
7. Close the cover and turn the printer off.
8. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
9. Plug the power back in and turn the printer on.
Bud
Oct 09, 2013 | Office Equipment & Supplies
Canon printer ip4700 can't replace ink cartriges holder does not stop at the right place
force carriage to one side fully with power off, this might reset carriage sensor and get it to go back where it needs to be to change ink.
Oct 19, 2010 | Canon iP4700 InkJet Photo Printer
Printer is saying more then one ink tanks of the same colour is installed. Yellow. Then it is saying it isn't recognising the yellow ink
Do you have all Genuine Canon Ink Jet Cartridges?
If you don't then that could be the problem.
Otherwise, if you do, then I would try another yellow ink jet cartridge from Canon.
Aug 20, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Hello the following message comes up when i have put some new ink in. U043 the following ink tank cannot be recognised. any ideas? i have tried 2 ink tanks and same message comes up.
This Canon ink tanks has a memory chip.Try clean this chip with piece of cotton and some alcohol.Clean the contacts on the print head too.Sometimes happen this chip going to fail and printer not recognize it respectively not recognized and ink cartridge.In worst case your print head may be defective.
Oct 29, 2009 | Canon MP610 Photo All-In-One Printer
Jul 28, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Oct 05, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Canon iP4700 InkJet Photo Printer Logo
155 people viewed this question
old marine
old marine
