Question about Hitachi 42HDS69 42 in. Plasma Television
THIN BLACK LINE DOWN CENTER OF TV
HITACHIE
  • Anonymous May 25, 2009
    I have a thin black line down the middle when I first turn on the TV but it goes away in about 15 - 20 minutes after the TV warms up. What is the problem?
How do you solve this problem of the black line down the middle of the tv?
Posted on Feb 01, 2009
    Problem Solver:
  • 13 Answers
It sounds like a dead pixel. if its under warrenty you might be able to get it fixed. If you purchased a extened warrenty they'll be able to fix it no problem
Posted on Jan 26, 2009
3 Suggested Answers
SOURCE: Black line down the center of screen
I had the same problem to and I fixed it.
At the bottom of the plasma there are six or seven ribbon cabbles that come out of the panel and connect to like driver boards. Each ribbon drives that section of the panel. Mine had it down the centre so I unplugged that ribbon cable and on the underside of a metal plate attached to it there are four big resistors and four small ones. The big ones labelled 100 required resoldering. Once they were resoldered it worked just fine.
Posted on Sep 24, 2008
SOURCE: red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Posted on Jun 18, 2009
TV screen has a thin horizontal line in center
this will only help until the next time it is out of alignment but if you slap the side of your tv about where the line is it should straighten out but there is no telling how long it will stay straight......My sons tv was doing that and i had a tv when i was young that did it that is what my mom told me to do and what i told my son to do and it works.... the problem is an alignment or conection problem from dust most likely.
Jul 11, 2012 | Sanyo Televison & Video
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
Sep 16, 2009 | Hitachi 36UX01S 36" TV
Red static in black background ~ thin line running down center
Robjrpena,
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
LCD TV - RED LINE
I have a thin red vertical line on the left side of my Philips LCD TV
Feb 25, 2008 | Televison & Video
Usually this means pixel, but I would question if the line is mostly near right side or left side of screen? If more to one side this could be a bad board inside. for more info ctechnicians.com
Dec 31, 2007 | Hitachi CMP4201U 42 in. HD-Ready Plasma...
Black line in center of screen
These black lines on the plasma screens are very fixable.  There is a dry solder joint on a circuit board at the bottom of the plasma that needs resoldered.  There are 6 or 7 "ribbons" along the bottom of the screen that correspond to vertical sections of the display, so you just follow the black vertical line down to figure out which one is faulty.  I just performed this fix successfully on my first attempt on a Gateway plasma, but it will work on most plasma's, specifically Hitachi, gateway, LG, Hyundai, & Akai. I think they may all have LG boards, my gateway did.
I can't really describe very well what to do, but I assure you it is fixable.  If anyone is near nashville, I might be able to help you out.  My email is tomp2000@juno.com.
thanks,
ST
Jan 18, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
My picture is black except for a thin horizontal line
hi When you let the line to long it will burn in!! you need to look into the VERTICAL output section. Most notably check the solder joints on the vert output IC and ESR the caps. If you don't know what any of that means, then take it to a professional. good luck
Feb 20, 2006 | Hitachi 36CX39B 36" TV
Hitachi 42HDS69 42 in. Plasma Television Logo
338 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
