Question about LG KG800 Cellular Phone
Slide problem The problem with my phone is that when the slide is closed i can access the menu by pressing two times in the volume key. But when the slide is opened i cant do anything theres no display so that i cant send messages or make new calls.The screen is completely blank. So please help me ...
  • jenish kurian Jul 18, 2007
    please help mee...
    Problem Solver:
  • 5 Answers
Same thing with my phone, I have the kg800 black unlocked version. There are only 2 things you can do here: (I suggest scenario 2) 1. Get it repaired. (problem with that is that it costs up to $100. If you're going to spend that much, you might as well get another phone. Plus, since it's imported, there's no guarentee that this "blank screen" won't happen again. 2. Get out yout owners manual, a pen, a notepad, and some coffee. There are ways to send texts, add new contacts, and do almost everything else a normal phone can do (without opening the slide.)The only thing I can't get around is picking up phonecalls without opening the slide. It's an inconvinient process, but if you like the phone as much as I do, you'll learn to deal with it. If you have any SPECIFIC questions about the phone, I'm not an expert, but I've found many ways to get around opening the slide and still do things such as text, and add new contacts. You can contact me at [email protected]
Posted on Sep 20, 2007
Look i'm not sure but the same problem was with my frendz fone so he took out the battery and left it out of the fone for about 10mins and put it back in and turned the fone on and off lyk 10 times....
Posted on Jul 25, 2007
SOURCE:
How do I master reset gravity smart phone using only buttons
Hi
Power off the phone.
Slide it open while still off.
Press and hold the Power key and the T key at the same time until you see the Android system recovery display.
By pressing the Volume key down,scroll to Wipe data/Factory reset.
Select by pressing the power button.
Again use the Volume key down to select yes -wipe user data.
Press on the power key.
Scroll to reboot system now by pressing on the Volume down key.
Press on the Power key to confirm selection.
And your phone reboots!
Hope it helps.Thanks!
Feb 27, 2012 | Samsung Cell Phones
I need to set internet to my ks360 how do i doit
    1. Press Menu (left soft key)
    2. Select Connectivity
    3. Select Network
    4. Select Access points
    5. Press Options (left soft key)
    6. Select New access point
      Note Slide the handset open to access the keypad
    7. For the Name enter #Profile
    8. For the APN enter #InternetAPN
    9. For the User name enter #Username
    10. For the Password enter #Password
    11. Ignore Primary sever and Secondary server these are preset at 000.000.000.000
    12. Press Save (the OK key)
    To setup the Internet profile
    2. Select the Browser
    3. Select Settings
    4. Select Network Profiles
    5. Press Options (left soft key).
    6. Select New profile
      Note Slide the handset open to access the keypad.
    8. For the Homepage enter #Homepage
    9. Set Proxy to #Proxy (to change press the Navigation buttons left or right).
    10. For the IP address enter #InternetProxy
    11. For the Port number enter #InternetPort
    12. Scroll to Access point and set it to #Profile (to change press the Navi buttons left or right).
    13. Press Save (the OK key).
    14. Scroll to #Profile and press Activate (the OK key).
    15. The Internet is now setup
Aug 20, 2011 | LG Cell Phones
Dear expert, i have some problem with my tmobile htc hd2, i bought from ebay & it was unlocked until few weeks ago it worked normally. but one day the problem happened, i can't acces my...
First off please access your sd card via computer and make some space on the card . Its always ideal you keep 20 % space free on the card .
Now please do a hard reset of the phone ( considering that you are on default windows mobile 6.5 )
Go to
  1. Menu > All Settings > System > Clear Storage.
  2. Enter 1234.
OR
  1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
  2. While holding the volume buttons, press the END/POWER button briefly and then release it.
  3. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
NOTE : PLEASE TAKE A BACKUP OF YOUR DATA , USE PIM BACKUP,
Aug 03, 2011 | HTC HD2 Smartphone
Hi How to silent the key tone volume of Samsung S5233W
Main Menu select -> Settings -> select phone profiles -> select normal profile by pressing the >> icon against it -> while on this screen on the top you would see a drop down list with following options "Incoming" "New Messages" "Phone Sounds", select "Phone Sounds" and slide phone sound volume to 0 value and save your profile
Feb 12, 2011 | Samsung Star GT-S5233 Cell Phone
How do I adjsut the earpiece volume on my Nokia 2680?
Hi
This ias waht to do.
Dial a number and press the right hand side of the menu key to increase the volume and the left and side of the menu key to decrease eh volume.
Goodluck.
Aug 30, 2010 | Nokia 2680 Slide Cell Phone
Nokia 6600 slide keys not working
you need to replace the cable flex of your 6500s..thanks
Jun 05, 2010 | Nokia 6600 slide Cellular Phone
How do i disable keypad tones on a samsung star s5233
Under Main Menu select -> Settings -> select phone profiles -> select normal profile by pressing the >> icon against it -> while on this screen on the top you would see a drop down list with following options "Incoming" "New Messages" "Phone Sounds", select "Phone Sounds" and slide phone sound volume to 0 value and save your profile
Nov 16, 2009 | Samsung Star GT-S5233 Cell Phone
WHEN I AM TYPING ON MY KEYPAD I GET A SOUND ON EACH LETTER TYPED.
go to standby mode (close the phone) slide it up and press the volume button (the ones on the left side) this should make you able to adjust the volume of the key tone. hope this answers you question.
Feb 23, 2009 | Samsung SGH-U900 Flipshot Cellular Phone
LG Shine 8700 user manual
THANK YOU MAN its the last four digits of your phonen umber
Feb 17, 2008 | LG Shine KE970 Cellular Phone
LG KG800 Cellular Phone Logo
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
