Question about Sport & Outdoor - Others
IPC what does it mean
Used in job description of aircraft industry
Illustrated parts catalog
Posted on Aug 20, 2013
  • Byron Betts PE Jun 28, 2014
    Also means Instrument Proficiency Check for an Instrument Rated pilot without the minimum fight requirements in the last six calendar months.
    Top Expert:
  • 2,899 Answers
The FAA www.faa.gov
Has free books and classes for all phases of pilot training.
The FAA book "FAR/AIM" book is the best for the info you asked about.
Hope this helps.
Posted on Apr 11, 2015
    Problem Solver:
  • 5 Answers
Byron Betts PE Also means Instrument Proficiency Check for an Instrument Rated pilot without the minimum fight requirements in the last six calendar months.
AC No: 61-98B Currency Requirements and Guidance for the Flight Review and Instrument Proficiency Check
Posted on Jun 28, 2014
1997 Cadillac Eldorado fuel gauge not reading fuel level correctly
Did you test before replacing ? Do you know how it work's ?
Fuel Level
The body control module (PZM) monitors the fuel level sender input in order to determine the current fuel level. The PZM filters the input and sends a message via the Class 2 serial data line. The IPC receives this message and displays the current fuel level. The fuel level is sent from the PZM to the IPC at changes of 0.5 L (0.02 gal) or on the request of the IPC, with a resolution of 0.04 L (0.01 gal).
• For the digital IPC, when the fuel level is above 18.5 gal, the IPC displays an F. For readings between 18.5-2.5 gal, whole gallon/liter numbers are displayed. When the fuel level reaches 3.0 gal the message FUEL LEVEL LOW is displayed on the driver message center. When the fuel level reaches 2.5 gal, the IPC displays an E. When the fuel level is 1.2 gal or below the IPC displays a flashing E.
• For the analog IPC, when the fuel level is above 18.5 gal, the fuel gauge pointer is on F. When the fuel level is below 2.5 gal the fuel gauge pointer moves to E. When the fuel level is below 3.0 gal the IPC displays a FUEL LEVEL LOW message.
If the updates are not received or a communication error is detected, the IPC performs the following actions:
• For the digital IPC, the fuel gauge is dashed.
• For the analog IPC, the fuel gauge pointer moves to E.
Fuel Gage Inaccurate or Inoperative
Circuit Description
The IPC monitors the fuel level sent by the PZM through the class 2 serial data line. The IPC software controls one of the following two gauge types:
• A digital gauge consisting if a two-digit numeric seven-segment display
• An analog gauge consisting of a needle pointer.
The IPC interpolates and scales the fuel level information that the IPC receives from the PZM.
When you operate the vehicle in diagnostic mode, either in the vehicle diagnostic system or with a scan tool connected, the fuel signal supplied to the IPC is not filtered by the PZM. The unfiltered fuel signal causes the IPC to show real time readings and may be mistaken as an erratic fuel level display.
Diagnostic Aids
Connect a scan tool to the DLC.
Oct 12, 2017 | Cadillac Cars & Trucks
Doesnanyone have a diagram showing where the wires on a speedometer connect to? I need to see if i pulled it on accident. And fuel gauge. Im learning so pictures are easier. Thx 2001 chevy tahoe
The speedometer gauge is controlled by information sent over the class 2 data bus from the PCM/ECM - engine computer . There is a VSS - vehicle speed sensor mounted on the transmission , this VSS is a input to the engine computer .
Speedometer
The IPC displays the vehicle speed based on the vehicle speed signal from the PCM. The IPC- instrument panel cluster receives the vehicle speed signal via a discreet wire. The IPC uses the vehicle speed signal circuit (4000 pulses/mile) from the PCM in order to calculate the vehicle speed. The speedometer defaults to 0 km/h (0 mph) if a malfunction in the vehicle speed signal circuit (4000 pulses/mile) exists.
Is the whole instrument cluster dead ?
Fuel Gauge
The IPC displays the fuel level as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the fuel level percent. The fuel gauge defaults to empty if:
• The PCM detects a malfunction in the fuel level sensor circuit.
• The IPC detects a loss of class 2 communications with the PCM.
When the fuel level is less than a pre-determined value, the low fuel indicator illuminates.
Reviewing the fuel system description will further explain how the system functions. Refer to:
• Fuel System Description in Engine Controls - 4.3 L
• Fuel System Description in Engine Controls - 4.8 L, 5.3 L and 6.0 L
• Fuel System Description in Engine Controls - 6.6 L
• Fuel System Description in Engine Controls - 8.1 L
Hourmeter
The IPC can display the accumulated engine run time hours using the VF display when the cluster is in the LOCK or ACC position. The IPC stores the accumulated engine run time hours in a non-volatile format. The accumulated hours will not change if the battery was disconnected or removed. When the ignition is OFF and the trip reset switch is pushed in and held for more than 4 seconds, the IPC will display the accumulated hours for 30 seconds. The hourmeter will reset to 0.0 when 10,000 hours are accumulated.
Odometer
The IPC contains a season odometer and a trip odometer. Momentarily press the trip/reset switch on the IPC in order to toggle between the season odometer and the trip odometer. Press the trip/reset switch for greater than 2 seconds, while the trip odometer is displayed, in order to reset the trip odometer. The IPC displays the vehicle mileage and trip mileage as determined by the IPC. The IPC calculates the mileage based on the vehicle speed signal circuit from the PCM. The odometer will display 'error' if an internal IPC memory failure is detected. The odometer can be configured to display either miles or kilometers.
PRNDL Display
The IPC displays the selected gear position as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the gear position. The PRNDL display blanks if:
• The PCM detects a malfunction in the transmission range switch circuit.
• The IPC receives a class 2 message indicating the park position and the column park switch indicates a position other than park (open input).
GM had problems with stepper motors that control the needle position .
Your best bet buy a used instrument cluster from the auto slavage yard .
Apr 30, 2017 | Cars & Trucks
My guages stoped working and transmition seems to be slipping in my 2001 shevy silverado 4.8
Well ronnie do you know how to do automotive electrical testing with a volt meter ? How to read an understand a wiring diagram ? Would think not to be a relay problem because other thing's would not work as well ! More then likely a loose ground or something on that order ! Plus you must mean Ignition . 1 relay , because there isn't a eng.1 relay . Ign. 1 relay powers the PCM - engine computer , fuel injectors , the TAC - electronic throttle control module . Do the instrument cluster lights still work when the gauges quit ? Looking at power distribution diagram I see a engine 1 fuse but has nothing to do with the instrument cluster . Supply's B+ voltage to the maf sensor , EVAP system , CAM sensor , IAT sensor , fuel pump relay ! Could be a communication problem on class 2 data bus . All the modules on the vehicle share information on the class 2 bus . The gauges get thier info from the PCM over this data network !
Engine Coolant Temperature Gauge
The IPC displays the engine coolant temperature as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the engine coolant temperature. The engine coolant temperature gauge defaults to 75°C (160°F) or below when:
• The PCM detects a malfunction in the engine coolant temperature sensor circuit.
• The IPC detects a loss of class 2 communication with the PCM.
Fuel Gauge
Speedometer
The IPC displays the vehicle speed based on the vehicle speed signal from the PCM. The IPC receives the vehicle speed signal via a discreet wire. The IPC uses the vehicle speed signal circuit (4000 pulses/mile) from the PCM in order to calculate the vehicle speed. The speedometer defaults to 0 km/h (0 mph) if a malfunction in the vehicle speed signal circuit (4000 pulses/mile) exists.
Tachometer
The IPC displays the engine speed based on the engine speed signal from the PCM. The IPC receives the engine speed signal from the PCM via a discreet wire. The IPC uses the engine speed signal circuit (2 pulses/engine revolution) from the PCM in order to calculate the engine speed. The tachometer defaults to 0 rpm if a malfunction in the engine speed signal circuit (2 pulses/engine revolution) exists.
Transmission Temperature Gauge
The IPC displays the transmission temperature as determined by the PCM. The IPC receives a class 2 message from the PCM indicating the transmission temperature. The transmission temperature gauge will default to 40°C (100°F) or below if:
• The PCM detects a malfunction in the transmission temperature sensor circuit.
Voltmeter
The IPC displays the system voltage as detected at the ignition 1 input of the IPC. When the engine is ON, the gauge should be between 10 and 16 volts.
The only one that has a hard wired sensor is the oil pressure gauge.
Engine Oil Pressure Gauge
The IPC uses the engine oil sensor signal to determine the engine oil pressure. The oil pressure sensor signal circuit is hard-wired to the IPC. The engine oil pressure sensor signal to the IPC is a variable resistance ranging from 0-90 ohms. A sensor resistance of 1 ohms will display as 0 psi (0 kPa) and a resistance of 88 ohms will display as 80 psi (550 kPa). The Check Engine Oil Pressure indicator will be displayed in the message center if the IPC detects a low engine oil pressure.
Does this one drop out also ? quit working
I would suggest that you take an have the IPC checked for DTC'S - diagnostic trouble codes , NOT OBD 2 engine codes , these are different an need a professional type scan tool .
You could check G103 for being loose . G103
On the left rear of the engine block . Also pull the instrument cluster out an check connection at the back of IPC . Check power an ground circuits at the PCM as well . You can fine wiring diagrams here
http://www.bbbind.com/free_tsb.html Enter the vehicle info . year , make , model an engine . under system click body an acc. then under subsystem click on instrumentation .Click the search button , then click the blue link . At the top of the diagram it shows B+ power supply , The connectors on the back of IPC , A,B , plus the pin # an color wire .
PCM power and ground testing avi
How To Use Multimeter Test Car Ground Video 3
Intermittent Electrical Diagnostics with Rich Peterson
Apr 10, 2017 | Cars & Trucks
I have a 2003 GMC Yukon XL Denali that today all of the gauges went to zero and Odometer is out. The truck starts and drive Great.... What can cause this problem?
Only the gauges don't work ? All the warning lights come on when you turn on the key ? ABS , check engine, air bag etc... Have you had the vehicle to a repair shop to have the vehicle checked for DTC'S - diagnostic trouble codes stored in the instrument cluster ? There is a microprocessor inside the instrument cluster an can store DTC'S which have nothing to do with the check engine light . The gauges are controlled by that microprocessor based on information from the PCM ,sent on the class 2 serial data network .
Indicators and Warning Messages
Refer to Indicator/Warning Message Description and Operation .
Engine Coolant Temperature Gage
The instrument panel cluster (IPC) displays the engine coolant temperature as determined by the powertrain control module (PCM). The IPC receives a class 2 message from the PCM indicating the engine coolant temperature. The engine coolant temperature gage defaults to 75°C (160°F) or below when:
Engine Oil Pressure Gage
The instrument panel cluster (IPC) displays the engine oil pressure as determined by the powertrain control module (PCM). The IPC receives a class 2 message from the PCM indicating the engine oil pressure. The engine oil pressure gage defaults to 0 kPa (0 psi) or below if:
• The PCM detects a malfunction in the engine oil pressure sensor circuit.
Fuel Gage
The instrument panel cluster (IPC) displays the fuel level as determined by the powertrain control module (PCM). The IPC receives a class 2 message from the PCM indicating the fuel level percent. The fuel gage defaults to empty if:
• Fuel System Description in Engine Controls - 4.8L, 5.3L and 6.0L
• Fuel System Description in Engine Controls - 8.1L
There are also U codes , communication failure's DTC U1000 and U1255
Circuit Description
Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. When a module receives a message for a critical operating parameter, the module records the identification number of the module which sent the message for State of Health monitoring. A critical operating parameter is one which, when not received, requires that the module use a default value for that parameter. When a module does not associate an identification number with at least one critical parameter within about five seconds of beginning serial data communication, DTC U1000 or U1255 is set. When more than one critical parameter does not have an identification number associated with it, the DTC will only be reported once. The class 2 serial data line on this vehicle is a ring/star configuration. The following modules communicate on the class 2 serial data line:
• The body control module (BCM)
• The digital audio broadcast (DAB) module
• The digital radio reciever
• The driver door module (DDM)
• The electronic brake control module (EBCM)
• The front passenger door module (FPDM)
• The HVAC control module
• The HVAC control module-rear auxilliary
• The inflatable restraint sensing and diagnostic module (SDM)
• The instrument panel cluster (IPC)
• The memory seat module (MSM)
• The powertrain control module (PCM)
• The radio
• The radio amplifier
• The rear seat audio (RSA) controller
• The rear seat entertainment (RSE) assembly w/U42
• The rear wheel steering control module
• The remote playback device-CD player w/U1S
• The suspension control module
• The transfer case shift control module
• The transmission control module (TCM) w/allison transmission
• The theft deterrent control module
• The vehicle communication interface module (VCIM) w/UE1
Your best bet would be to take it to a qualified repair shop .
Mar 23, 2017 | GMC Cars & Trucks
I have a 2008 Chevrolet Silverado and the warning lights keep coming on telling me AC not working/engine hot ,, ??
ENGINE HOT TURN A/C OFF
Cooling System Description and Operation
ENGINE COOLANT HOT
The instrument panel cluster (IPC) displays ENGINE COOLANT HOT message when the IPC receives a class 2 message from the powertrain control module (PCM) requesting illumination of this driver warning.
ENGINE OVERHEATED
The IPC displays ENGINE OVERHEATED message when the IPC receives a class 2 message from the PCM requesting illumination of this driver warning.
DTC P1258: Engine Coolant Over temperature - Protection Mode Active
Have it check
Mar 03, 2017 | Chevrolet Cars & Trucks
What does Air Traffic Controllers mean when they say "12 o'clock" to a pilot? or 6 o'clock ?
it is the relative direction around the aircraft using a clock face. 12 oclock is in front of the pilot, 6 oclock behind. 3 oclock to the right etc. it is also used with high, level or low. for example, a contact off to the right and above the flight level of the pilots aircraft would be 2 oclock high.
Jan 04, 2017 | Aircrafts
Have 2004 Chevy1500z71&service 4wd message comes onafter it in 4H but it still worksHad fluids changed 2 yrs ago.Goes into 4wdfine&seems like it runs good. Comes on sometime even not in 4wd. Thanks
Which transfer case does your truck have ?
SERVICE 4WD
Refer to
Transfer Case Description and Operation for the Transfer Case - NVG 149-NP3
Transfer Case Description and Operation for the Transfer Case - NVG 246-NP8
Transfer Case Description and Operation for the Transfer Case - NVG 261-NP2
Transfer Case Description and Operation for the Transfer Case - NVG 263-NP1
The SERVICE 4WD indicator is located in the instrument panel cluster (IPC), and shares the common power and ground of the IPC. The transfer case shift control module controls the service indicator by sending the IPC a Class 2 message. This indicator may be controlled with the scan tool using the IPC device controls.
You should take it to the dealer an have it checked for DTC'S -diagnostic trouble codes
Jan 07, 2016 | Cars & Trucks
How am i supposed to get ride off the Service theft system?
It's hard to fix something if you don't know how it works ! Fixed ignition ? What did you fix or change ?
SERVICE THEFT SYSTEM
Security: Refer to Theft Systems Description and Operation in Theft Deterrent
You need to have it checked for trouble codes .
The theft deterrent system on this vehicle is comprised of two separate systems, the vehicle theft deterrent (VTD) system and the content theft deterrent (CTD) system. The VTD system prevents drive away theft by keeping the vehicle from starting. The CTD system is the vehicle alarm system which discourages unauthorized entry into the vehicle. These systems are described and diagnosed separately within this section.
Theft System Indicators
SECURITY The instrument panel cluster (IPC) illuminates the SECURITY indicator as determined by the vehicle theft deterrent (VTD) system and the content theft deterrent (CTD) system. The IPC receives a message from the theft deterrent control module or the rear integration module (RIM) via the serial data circuit requesting illumination.
The VTD system requests the IPC to illuminate the indicator only when the ignition switch is ON. The VTD system uses the indicator as a malfunction indicator. For specific VTD condition that will illuminate the security indicator, refer to
Vehicle Theft Deterrent (VTD) Description and Operation .
The CTD system requests the IPC to illuminate the indicator only when the ignition switch is OFF. The CTD system uses the indicator in order to identify system status. For specific CTD condition that will illuminate the security indicator, refer to Content Theft Deterrent (CTD) Description and Operation .
The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
SERVICE THEFT SYSTEM The radio illuminates the SERVICE THEFT SYSTEM message when the VTD system detects a failure. The radio receives a message from the theft deterrent control module via the serial data circuit requesting illumination.
This is one you need to take to the dealer , unless you have a GM factory scan tool !
Nov 21, 2015 | 2004 Cadillac CTS
My clock keeps resetting to 12:00 when I turn my ignition on. The battery charge gauge remains in the middle. That happened twice yesterday and once this morning. To add to the confusion a new light came...
Hello Cjmm,
Your vehicle presently has 37 Technical Service Bulletins
(TSBs) Driver Amenities: Instrumentation.. None specifically
point to your issue (not even looking at "tow" issue)...
but the associated wiring clearly depicts
"a continuous battery source"... which should supply
continuous battery during ignition key operation...!!
>> Assuming all battery & ground points are clean
(battery cables & post connections are the FIRST
step
in ALL ELECTRIC anomalies)...
>> The NEXT is
Fuse terminal ("hot at all times") Fuse 19, 15 Amp
RDO Battery is your IPC (INSTRUMENT PANEL CLUSTER)
source on your vehicle's wiring diagram.
FREE wiring & TSBs
are available (after registration)
at BBB Industries website for most POPULAR USA market vehicles (I am using it now to verify your "IPC" connection).
See BBB Industries (at bottom):
After FIRST cleaning your battery terminals...
Place FELT WASHERS to prolong protection:
Amazon com Road Power 0989 Anti Corrosion Fiber Washers 1 Pack 2 Washers 6...
Amazon com NOCO NCP2 CB104S 4 Oz Brush On Oil Based Battery Corrosion...
... and remember those cables have two ends...
Them move on to inspect that fuse ...
Amazon com Bussmann DIA 2 ATM Blade Fuse Diagnostic Kit Automotive
Hope this helps
Carnac the Magnificent
Jul 13, 2017 | 2001 GMC Jimmy
Sport & Outdoor - Others Logo
961 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
