Question about Vestax Pdx2000 Direct Drive Turntable System
Hi, I have a Vestax PDX2000 deck which occasionally stops in the middle of a record and starts playing backwards for a few seconds then starts playing forwards again. Obviously this makes mixing impossible.Can You explain every step and send u step by step pics of the repair ?
2 Suggested Answers
SOURCE: Vestax PDX200 platter keeps changing direction
Hi everyone,
I had exactly same problem with my Vestax pdx 2000 mk2 TUNETABLE.
The solution involves some careful screwdriving but is fairly simple....
You need to take the motor out and carefully take it to pieces, the problem is caused by a tiny piece that needs to be put back into place. Of course you will loose your warranty but its cheaper and faster then getting new motor or sending to repair.
If u need help don't hasitate to email me: jazzbin@o2.pl
i can explain every step and send u step by step pics of the repair.
Posted on Apr 23, 2009
My pdx 2000 turntables go backwards randomly
Hello
The fault is to its motor control circuit board. Mechanism alingment also should be checked. contact any expereinced service technician to rectify this problem.
Mar 02, 2012 | Vestax Pdx2000 Direct Drive Turntable...
The platter keeps spinning backwards any advise ?
Hello
Its internal motor control circuit control logic has the trouble. The control IC alongwith the retulator transistor should be replaced. OK.
Mar 23, 2011 | Vestax Pdx2000 Direct Drive Turntable...
Vestax PDX 2000 motor going crazy problem
hey, it will work with the tape solution but you gotta pay attention to the light metallic circle which is used by the light sensor (the small black one with cables on it) to estimate motor movement - first time i opened it and did the tape thing to the black rubber circle i eventually touched the light metallic circle and i think that caused it not working for me too
the light metallic circle must be totally clean and plain, do your best, but be sensible
Jul 09, 2010 | Vestax Pdx2000 Direct Drive Turntable...
I have problem with tonearm on my vestax pdx 2000 turntable , no connection with needle , but when I make contacts of the needle wet it sometimes help a bit , but I should do it always to make it work. ...
I'd be checking the weight and height settings of the tonearm. Heres a link to the manual for the deck. There's instructions in there about how to setup up the tonearm properly. Don't be afraid to experiment with it. Just remember, too much weight will wear out your vinyl really quickly. Not enough weight will sound like **** and skip easily. Have fun!
http://www.vestax.com/v/info/support/pdf_players_manuals/VOM-PDX-2000E.pdf
Dec 15, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Eratic platter direction and speed changes.
Have you seen this solution (Padster07's), it solved my problem: http://www.fixya.com/support/t477894-vestax_pdx200_platter_keeps_changing
Oct 06, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Vestax pdx 2000 motor problem
This is a really common fault with this model of TT. I've just repaired a pair of them with the same problem.
You need to remove the bottom cover of the deck then take the round cover off the bottom of the motor assembly. Be really careful with that, delicate sensitive stuff inside. Once you remove the screws use a small flat blade screwdriver to lift it free of the rubbery glue that seals and holds it in place.
Once removed, in the centre of that cover is a small black rubber cirlce about 6mm in diameter that the shaft of the motor rotates on. The problem causing all of that erratic platter movement is with this small black circle.
The solution I found was to use double sided tape to hold this part in place. This serves two purposes. First, to stop the part from moving off its required location, Secondly, to raise the part up slightly from the bracket that it sits on. Layer the double sided tape up so its the around the same thickness as the small black rubber circle. Then place the black cirlcle into its original location bedding it firmly into the tape.
A tiny small dolop of grease on the end of the motor shaft. Replace the motor and bottom covers. Bingo! The decks a-go-go!
Happy mixing!
Jul 09, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Pdx2000
see inside the pdx2000 main board & you see the fues
Feb 05, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Hi i have a set of pdx 2000 vestax turntables and i am having the problem of a speed jump when you cue or scratch the record it only happens sometimes also i have noticed a creeking noise when i am cueing...
You need to remove the bottom cover of the deck then take the round cover off the bottom of the motor assembly. Be really careful with that, delicate sensitive stuff inside. Once you remove the screws use a small flat blade screwdriver to lift the cover free of the rubbery glue that seals and holds it in place.
Happy mixing!
Jan 15, 2009 | Vestax Pdx2000 Direct Drive Turntable...
Hi everyone,
Mar 30, 2008 | Vestax Pdx2000 Direct Drive Turntable...
Turntable spinning backwards
If it is a direct drive TT then it uses some electronic circuitry to control speed and it sounds like that circuit is having a problem. Possibly the actual driver IC for the TT motor has gone bad. Good luck.
Feb 13, 2007 | Vestax Pdx2000 Direct Drive Turntable...
Open Questions:
See all Vestax Pdx2000 Direct Drive Turntable System Questions
Vestax Pdx2000 Direct Drive Turntable System Logo
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Electric Dime
Electric Dime
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
