Question about Dualit DAB Kitchen Radio FMDAB
I can not connect to digital it keeps saying channel not available
I can't get get my Google account to go threw keeps connection isn't strong enough which I have max strength wifi?
can you log into your wi fi router admin account ?
Can you try changing the channel from auto to say 3 channel numbers higher than the lowest channel number available . This is in case you have neighbors with wi fi that might be interfering with your wi fi signal .
Nov 18, 2016 | Tablets & eReaders
We have an antenna, digital converter box, and digital tv. Can only get 5 channels. No nbc, abc, cbs. Get the message indicator available for digital broadcasting only
You should be able to use the box remote and select channel search mode. As it searches, you will see it "hit" available channels and store them. When channel search is finished, you should see a picture displayed. if no results, there is something wrong with the antenna, the way it is connected to the box, the way the box is connected to the TV, or the way the TV is connected to the box. You may have to reread the instructions to find what is at fault.
Sep 05, 2015 | Televison & Video
TV keeps saying run channel scan
Then run it but ensure that the aerial is in a good condition and is correctly connected. Also...ensure the tv is set to the correct source....digital.
Hopefully this should find your channels. when scan is completed
Remember to save the channels
Jul 16, 2015 | Televison & Video
How to watch digital channels on my tv in ghana
How to watch digital channels? With your eyes wide open. What else to say.
Provide more details please; man.
Jun 27, 2015 | Televison & Video
Missed channels
Those particular channels are not being detected because of antenna orientation or weak signal level. We have similar problems receiving digital channels 3, 6, 23, and 52 here in the Philadelphia area.
Jun 08, 2017 | RCA Dta800b1 Digital-to-analog Converter...
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I have a 42 inch plasma and teletext wont work any
A factory reset made teletext available again on digital channels.
When on standby, push on remote in quick succession <info><menu><mute><power> buttons. Follow onscreen menu to option 12 (reset) and select. Be aware that you will have to tune in all analogue and digital channels again.
Jul 22, 2009 | Televison & Video
Dualit DAB Kitchen Radio FMDAB Logo
Top Dualit Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Dualit Audio Player and Recorder Expert? Answer questions, earn points and help others
