Question about Saws
Carriage Bearings are Bad
Crafstman doesn't have them in stock anymore and I can't find anyone in the general bearing business that has them.
HEIM 633 bearing - radial sperical - apparently specially made for SEARS Craftsman.
Is there ny substitute?
  • David Ford
    David Ford May 11, 2010
    I checked with Bearings INC. and found Heim bearings but nothing with that number could you please recheck and let me know.
  • 2,976 Answers
Here are 2 links for Heim. If you can't find what you need, try an industrial supply cross reference. A good bearing supplier should be able to match you up with measurements as well as numbers. Check with the maintenance supervisor of a local manufacturer to see where they get their bearings.
Posted on Jan 30, 2009
I just bought new pinion an bearing kit for 2003 Suzuki ozark 250 pinion bearing is to large that was what was wrong with my old one are they two differ size bearing
The bearing have numbers stamped on them somewhere. If you have your old bearing, you can match the numbers. You can measure (BOTH BEARINGS) the bearing I.D., OD., and width with a GOOD set of calipers!! I have seen, rarely, bearings that are only available from a manufacturer. Look in the yellow pages or google search for bearing supply businesses near you.. they can help you find the bearing you need.. and usually at a lower price than a "factory bearing".
We used to purchase main bearings and transmission bearings from our local bearing supply house and stocked them under the Yamaha part numbers... our costs was about 1/3 vs factory costs..
Sep 03, 2017 | Suzuki 2004 Ozark 250
Possible bearing noise over 35mph
does it sound like wind blowing like a WOOOOOOOOOO sound?
if so get ur differential checked
Mar 14, 2013 | 2005 Toyota Matrix
Change cam bearings 1450 flhx
No, but if your cam shoes have never been replaced, have them checked. In some bikes they go as early as 30,000 miles. I just replaced the shoes in my Fatboy at 32,000. If you do replace the cam shoes or do any other work in the cam cavity, change the stock cam bearings for the Screamin' Eagle bearings. Better bearings and cheap insurance, but there is no need to change them unless you're in there for something else, unless the bearings went bad for some reason.
Sep 09, 2012 | 2006 Harley Davidson FLHX Street Glide
My beko condensor dryer is not turning anymore, the heat is fine but it doesn't tumble
Drum will not turn or rotate
1.broken or slipping belt---replace belt
2.jammed or bearings frozen ----check for foreign article between drum & shroud
Replace defective bearing or bearing support which allows drum to sag or hit
3.loose pulley----tighten pulley set screw
Sep 22, 2011 | Dryers
IBM Wheelwriter 6781 won't perform a full carriage
Spray some WD40 on the silver shaft that the carrier slides on. If this doesn't work Spray some on the carrier motor bearings, located under the case R. rear corner. You can access the front one from 9inside the rear you will have to fish the straw thru the case.
Aug 04, 2011 | IBM Office Equipment & Supplies
I have a less than two year old whirlpool WFW9500TW01 washer with a bad main drum bearings. I am told the bearings cannot be replaced and that the solution is to get outer tub and basket replaced for...
Hi Duane, welcome to FixYa.
While the price of $1000.00 sounds about right if hiring a pro, it is expensive. The parts alone you`d require are in the range of $675.00.
The outer rear tub assembly #W10250763 ( outer tub is in two pieces with the rear housing the bearing ) is listed at $315US
The basket #W10250573 is listed at $365US also, and it would need to be replaced because it is supported by the rear bearing, hence the spindle of the basket will likely be scored/worn really bad.
Whether or not you can perform the repair is hard to say, but it is very involved and even an experienced tech like myself will require 60-90minutes to complete, and I know them inside and out.
I certainly feel for you since it is relatively new, but it certainly sounds like a worn bearing. Check out on-line vendors for price matching and places like "youtube" for how to videos.
Hope that answer`s your questiuon at the very least.
Good luck.
macmarkus :)
Aug 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I need to replace the bearings in the drivers side front wheel,but cant find any car shop or garage that stocks daewoo parts anymore? I've had people tell me i can use bearings from astra? Is there any...
gm dealers, motor traders stock genuine parts for these vehicles, im in australia and can get after market also from, repco, sprints, etc...or even go straight to bearing company eg. cbc bearing company, tkn, etc... depending on brand of old bearing. i suggest you try a bearing company out of phone book some have listings for vehicle applications.
Aug 04, 2010 | Daewoo Lanos Cars & Trucks
The wholesale cost of the part is about $400+shipping. You'd pay more...
I'm in the business and mine did the same thing. When we couldn't turn the TV up loud enough anymore, I pitched it and bought a Duet!
Sep 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Need the Brick Carriage Rolling Bearings
i dont know where your located at, but when i need any parts for my tile saws i get them at the tile shop, that sells me the tile, most good tile distributors sell tile saws and most carry parts for saws targets a great saw and a good tile store will probably have those roller bearings in stock.good luck.chad
May 15, 2009 | Target Saws
Just looking for general advice...on FMF Pipe Install
i changed my pipe on 07 dt125lc and did not rejet, seemed fine until i holed a piston. best to rejet me thinks, about £20 instead of £150 for piston rebore bearings and jets plus the time to re build.
Apr 25, 2009 | 2003 Yamaha YZ 125
Saws Logo
191 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
