Question about Vehicle Parts & Accessories
Need to turn alarm off but key fob broken, is there a nother way to turn alarm off, the car will start and run ok, but alarm keeps going off
  • paulsmurf1
    paulsmurf1 Jan 28, 2013
    looked at site but alarm key fob not there
emissionwiz
  • 76673 Answers
SOURCE: key fob will not undo
If you don't have one that works for the vehicle now, you'll have to take it to your local dealer to have it programmed to the vehicle. Some will charge for this, some will do it at no charge.
If you do have a remote that is programmed and working for the vehicle, then the following steps will allow you to program another remote:
1. Enter vehicle and close all doors.
2. Put seatbelt on (or clip it into the buckle) to shut the warning buzzer off.
3. Put key in ignition, turn to run position but don't start it.
4. Press and hold the unlock button on the working key fob and hold for 4 seconds, then also press the panic button.
5. Release both buttons and you should hear a single chime to indicate it is in program mode. You have 30 seconds after the chime to program any additional remotes you want to program.
6. Press and release both the unlock and lock buttons simultaneously on the remote you are programming. You should hear another single chime.
7. Within 4 seconds after hearing the chime, press either lock or unlock button on remote that you are programming.
Posted on Oct 16, 2008
  • 11 Answers
SOURCE: 2006 cobalt won't run
try unhooking the negative cable on the battery and let it sit for an hour this should reset the computer
Posted on Jan 11, 2009
jyackle5
  • 8197 Answers
SOURCE: pairing new alarm fob to cobra 777
Turn ignition key on and off around 5 times or till you here the alarm then hit the left and right button on fob till you here the alarm again then it is set. if you have 2 remotes you need to do them both at the same time.
Posted on Apr 07, 2009
  • 7 Answers
SOURCE: Audi A4 2003 Alarm Problem
There is a few things to do check the door switches that control dome lights, check wire down by the skid plate when you get oil changed there is a sensor for the starter there if it is stolen the alarm will go off or just take a BAT and BEAT the living **** out of your horn and call it good like I am going to. I hope this helped or will help I recommend an aluminum bat vrs. wood
Posted on Sep 07, 2009
SOURCE: Have 56 plate seat leon 1.6 .the alarm keeps going
I have Seat Leon 07 and my alarm has gone off loads of times in the last 18 months. The first time it was the window motor that went - went in under warranty and part replaced - it's now back in the garage getting the same problem fixed again. the neighbours are fed up with the alram going all times of the day and night. Hope this helps
Linda
Posted on Sep 18, 2009
Key fob won't work even after changing battery, can only open and lock car using key, alarm won't shut off and keeps ringing
retry replacing battery new doesnt mean cant be defective if it is good than fob needs a relearn different cars have different relearn that you can perform but if the fob has other features such as start that will have to be done at dealer ----
Free Keyless Remote Fob Entry programming instructions procedures for all... look up your vehicle and will have instructions one how to program fob --will also tell if need to be done at dealer
Aug 02, 2015 | Cars & Trucks
How do I disarm my 2011 jeep grand cherokee alarm? It keeps going off randomly and my remote doesn't shut it off
GOT OPTION "ENTER AND GO"???????????????
did you use both FOBS. car came with 2, try using both , one at a time and not both near car as SAME time. ever.
mines turned off for ever,
i never armed it.
so page what.
wow 6 owners manuals, 4 for Uconnect, wow. pain.
page 22. read that?
sure.
is this not clear ,quoted
The Vehicle Security Alarm is designed to protect your
vehicle; however, you can create conditions where the
Vehicle Security Alarm will arm unexpectedly. If you
remain in the vehicle and lock the doors with the RKE
transmitter, once the Vehicle Security Alarm is armed
(after 16 seconds), when you pull the door handle to exit,
the alarm will sound. If this occurs, press the UNLOCK
button on the RKE transmitter to disarm the Vehicle
Security Alarm. You may also accidentally sound the
Vehicle Security Alarm by unlocking the driver's door
with the key and then opening the door
good luck deciphering this page, wow.!
page 23 is NO ENTER AND GO', OPTION.
Either press the UNLOCK button on the RKE transmitter,
pull on the front driver or passenger door handle (refer to
"Keyless Enter-N-Go" in "Things To Know Before Starting
Your Vehicle" for further information) with a valid
key fob in range, or press the Keyless Enter-N-Go Start/
Stop button (requires at least one valid Key Fob in the
vehicle), or insert a valid Key Fob into the ignition switch
(if the Start/Stop button is removed) and rotate it to the
ON/RUN position.
END QUOTES FROM YOUR GUIDE.
if all this fails get jeep to fix it. (the magic is broken so...)
or ask them to explain, page 23 , in non GREEK..
Feb 27, 2015 | 2011 Jeep Grand Cherokee Laredo
Fob still won't work after new battery and nothing wrong with the contact inside, do not hae original code for the Kia sportage 1998 so what is the next best thing ,to do?
When replacing the key fob battery there is no reprogramming required! If the key fob was working prior to the battery replacement then it would point to the contacts not being correct! Remove key fob battery and start again!
Dec 31, 2014 | 1998 Kia Sportage
Will I be able to start and use my car if the key fob/plip isnt working?
everything should be ok as long as u got the key to start the car
Jul 07, 2014 | 1999 Renault Megane
2007 night train wont start and alarm keeps going off
Hi Anonymous, you may need an alarm reset, for more information about your question please visit the websites below. Good luck and have nice day.
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Jul 21, 2012 | Harley Davidson FLHRI Road King...
Key fob wont re set on my ssan yan rexton
I recently changed the battery on my key fob for my ssanyong rexton. I then did the following for the key fob to make it work. 1. Enter vehicle and close all doors.
4. Press and hold both buttons on key fob until red light on fob stays on. Then let go of both buttons. Then pressed the alarm button then the panic button, somthing like that. To be fair the button sequence after the red light came on is a bit vague. The alarm was blaring so i was happy when it just stopped.
May 23, 2012 | SsangYong Rexton Cars & Trucks
2003 Audi A4 Cabriolet alarm problem. The fobs (both) keep losing sync with the car. The fobs have new batteries. The hazard warning lamp switch on the dash is illuminated constantly, and I believe the...
unlock the car with the key and hold the key over for 30 secs,(the windows will go down) then lock the car/hold key over for 30 secs,(the windows will go up). wait 30 secs then press/hold down the unlock button on the key fob,this will resyncronise the alarm/key fobs.
Nov 23, 2010 | 2003 Audi A4 Cabriolet
1999 volkswagen passat car alarm factory installed system
Do you have a key fob? Unlock the car with that and you should be OK. My sons Elantra is the same way, you can only get in with the fob. I guess the car thinks it's being stolen otherwise. If you don't have a fob, I'm no help
Mar 28, 2009 | 1999 Volkswagen Passat
Alarm &immobiliser
the security system is shutting down the starter. is it factory alarm?
Jan 15, 2009 | Vehicle Parts & Accessories
Both fobs won't work, i cannot even start the car even with the key because i cannot turn off the car alarm, any ideas what wrong and what i can do?
Hi, i had this problem with my 96 model.. i let the battery go flat, then recharged it.
Although disconnecting the battery my work.
Assuming that the batteries dont need replacing in the fobs.
Jul 23, 2008 | Hyundai Tiburon Cars & Trucks
Vehicle Parts & Accessories Logo
19 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
