Question about Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System
I need to reset ring tone
Need to reset ring tone
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
What model Uniden 5.8GHz phone?
Posted on Nov 30, 2013
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
No ringing tone while getting call from somebody also when I goto setting to change ring tone I can not play any of tones and I ca not close the window as well and I have to restart manually .
Possible that there are errors in your software. so remove the battery and memory card. scan your memory card for virus or corrupt files. If not format the card.Now reset and start the phone , if there is no change in your tone settings, the the software needs to be reinstalled.
Please make sure that a recently downloaded music file or ring-tone has caused this breakdown , if so remove the file and try once again.
Jan 22, 2011 | Cell Phones
I have Nokia 1661-A and model: 1661-2b. When
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 23, 2010 | Nokia 1661 Cell Phone
Nokia 1661 my phone not ringing why ?
Mar 22, 2010 | Nokia 1661 Cell Phone
I had purchase a new nokia 1650 wont ring or vibrate
just fomat your phone first then try to change your tone settings
Mar 11, 2010 | Nokia 1650 Cell Phone
Ringar is not working plis help
ok first you need to check to see if your phone plays any tones at all .
if so you most likely have your ringer turned off. go to menu then settings then sounds. in sounds select ring tone or ring volume.
you will need to check in this area of your phone. select a tone and check to see if your ringer is off.
if that is not the problem you may want to try a soft reset. this will reset your phone to factory settings.
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
Nov 14, 2009 | Nokia 3220
Assigning ringtones to a profile
If you set the profile ring tone to OFF. Then select a contacts' number and assign it a Ring Tone. When that contact calls you the Ring Tone you assigned will ring.
If you select the same Ring Tone for all your contacts in a group they will all sound the same when they call.
Or select the same ring tone for a profile, but cancel the Tone you assigned to the contact(s).
Feb 02, 2008 | Nokia N70 Cellular Phone
Ring File corrupted
use a different ringtone or try to put the ring tone in a different folder and if that donsent work then do a hard reset
Nov 22, 2007 | T-Mobile MDA
Uniden 5.8GHz Expandable Cordless Phone System with Digital Answering System Logo
23 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
