Question about Aeria Games Shaiya
Shaiya problem?
Alright, So shaiya loads runs wonderfully for me until i try to retrieve or finish a quest. When i click on the quest holder the bar freezes, Which ends with me logging out every single time i try to turn in or pick up a new quest. I have no idea what to do. I've restarted the game, And my computer several times. Help?
How Can I Download Shaiya On A Chromebook
go to the shaiya site and see what browser they recommend and use that instead of the one you use that doesn't support it.
Mar 15, 2014 | Computers & Internet
Startup very slow on my new dell 660 desktop
If it is updating it will take a while to load updates. Once all the updates are installed it should Boot and shut down faster. Just let it finish the updates. do not disturb until finished.
Dec 11, 2012 | Dell Computers & Internet
How to Download
For example, go to www.download.com type avast antivirus, scroll down the page until you locate it, click on download, if are running XP you will be prompted near the top browser, click the bar, and click do you won't to run the file, the download will commence until finished, then click run and follow the prompts. Now if you have windows 7 click on download it will prompt you at the bottom, click run and follow as prompted.
Mar 23, 2012 | Computers & Internet
My Gateway 838GM keeps freezing up
When you do get the pc to start do a disk cleanup, by right clicking the c: drive and going into properties in my computer and put a tick next to all of the boxes and hit next to delate them all. Once that has finished defrag the drive, this can be found in the start bar, programs, acessories, system tools. When that is finished go to start bar in the run or search text bar type cmd to open a command prompt window, and type chkdsk c:/f and press enter, it want do anything straight away and will ask you if you would like it to start it the next time the computer boots type "Y" for yes and exit the command prompt. Before restarting the system goto my computer, c: drive , windows , then scroll down until you see a folder named prefetch, open the folder and sellect all, highltight one file by a single left click on it and prees "ctrl"then "A" this highlights everything, hold the shift button down and press delete to delete the entire folders contence, once done reboot the pc. post back if this helps.cheers.
Jan 27, 2010 | Gateway 838GM (RB838GM) PC Desktop
Pc Game Error
Hi! I'm trying to install My Horse and Me the PC game, the installation goes through everything normal and but when I press Finish it gives me this error message
Unhandled Exception
Error Number:0x80040702
Description:Failed to load DLL:GameuxInstallHelper
When I press OK the installation window where you press Finish pops back up and it says
InstallShield Wizard Complete
The wizard was interrupted before MyHorseAndMe could be completely installed.
The system has not been modified.To install this program at a later time,run the installation again.
Click Finish to exit the wizard.
So I press Finish and then if I try to go and find it its not there its been uninstalled. And I have tried installing it several times with no luck .
So if you could please help me that would be wonderful because I really want to play my game.
Thank You!
Nov 14, 2009 | Atari Video Game Consoles & Games
Customers machine powers on. intel logo appears in bottom LH cnr of screen. Prompt appears saying push F2 or F12. Both options show the machine apparently trying toload more software, then the progress bar...
your pc is failing to upload youe system registry components, this makes it not able to go further and finish booting. please try to run system recovery using a disc that came out with the pc or if you do not have it anymore, use your windows disc to recover,
if it is vista, choose the upgrade option, you willl not loose the data and for Xp, continue as if you loading a fresh copy of you windows, soon after you have accepted the terms and conditions, there would be some options for you to choose from, do not format, press R to recover and then follow up all the steps to progress.
you will not loose your documents too.
thanks,
wonder
Sep 22, 2009 | Samsung Q45 Notebook
An Item Has Fallen Into The Space Behind The Cup Holder? Help.
I recently had to retrieve a small object (camera battery) that was dropped in the cup holder. The battery allowed the cup holder to close properly, but it would not allow the cup holder to open all the way, making the cupholder useless. Getting access to remove the object was quick and easy - all it takes is a small flat blade screw driver. Use the screw driver to gently pry up the wood trim panel in front of the cup holder. Be sure to pull it up evenly from both sides and it will pop out of its retaining sockets. You'll then have the access you need. When you've finished, just realign the wood trim piece and tap it back into place. You can see a picture of where to pry at http://info5000.com/LS400_trim.jpg
Jul 06, 2008 | 2000 Lexus LS 400
IBM T23 Freezes
have you tryed update on the bios ?
i had the same problem with a toshiba lap top
and a bios update solved it
Nov 04, 2007 | IBM ThinkPad T23 2647 Notebook
Optiplex Gx110 Freezing on Bios Post
The only thing I can think of is there should be a jumper pin that on the mother board that resets the cmos. Unplugging the battery does not clear the cmos rom. My guess would be the cmos rom is currupted and unfortunatly you need the rom loaded before you can flash and replace it. My advice is ditch it.
Aug 02, 2007 | Dell OptiPlex GX110 PC Desktop
Video Game Consoles & Games Logo
Top Aeria Games Video Game Consoles & Games Experts
James Wishart
Are you an Aeria Games Video Game Console and Game Expert? Answer questions, earn points and help others
