Question about Miele Novotronic Premier 500 Front Load Washer
Miele w970 not spinning top speeds - Miele Novotronic Premier 500 Front Load Washer
Removal of fasia on mieie w970 wasing machine to fit new on off switch.disp removed and 3 screws removed .right hand side is fixed dont want to force it.
Hi dear. Open the door. There should be 1 or 3 10mm bolts around door gasket remove them. Where soap dispenser Top LHS 3 T10 screws,remove them. Open Bottom LHS pin trap.Remove the drain hose from the cover and right underneath it, there is a clip. You need to push it down to open front panel from left to right. Then you can access it. Thanks.
Mar 29, 2016 | Miele Washing Machines
Where can I get a service manual for dryer Miele softronic T 4422 C
Manual is normally hidden inside the case, either bottom right, or inside the console at the top.
Make sure all the vents and pipes to outside are clear of lint and obstruction.
Jul 28, 2015 | Miele Dryers
Miele W1926 burning smell
The front support seals -felt around the top of the door -are worn out. You can order them online with your model # or call the parts distributor and tell them you need the replacement kit - it comes with the top and side seals. To get them separate is more money. You will have to take apart the front of the unit - top first - then the control panel and then the door (front). It supports the drum. You will need to scrape off the old seals and apply the heat glue for the seals. Put the new seals on and reassemble the unit. This should do it if it was rubbing on the front plastic.
Jan 08, 2014 | Miele W1926A Front Load Washer
Unable to find an english operating manual for a miele w822 washing m/c
Hi Dear. I assume this machine made for Nederlands - Dutch market. You can not obtain English manual for it. You may contact your local Miele center. They may able to supply you translated copy of user manual. Thanks.
Note: What I can understand from control panel, buttons from left to right : Door Button - On/Off - Pre -wash - Water Plus (adds more water)- Gentle wash and Short wash then Final spin speed selector.
Right hand side Program & wash temperature selector (Clock wise): Cottons - Minimum Iron - Delicate - Wool - Starch - Spin only - Pump only & Mini Program (Quick Wash)
Mar 07, 2012 | Miele Washing Machines
Hi I can't get the washing machine door to open on model w970 please help
sounds like interlock has packed in.
WITH POWER OFF......
you need to remove lid...............put your hand down front of door interlock and flick the switch.................replace interlock asap.....
cheers
Mar 26, 2011 | Miele Washing Machines
My miele silver moon attachment brush stopped spinning. the belt looks good what could it be
It is most likely the hose. There are wires inside the hose that connect the speed and suction control on the handle, to the board inside the canister. After years of use, the wires can become damaged to the point that they wont complete the circuit anymore. Any vacuum store that sells miele will have the replacement hose. You can also get it from miele directly, or off ebay. Be careful going to the vacuum store if you dont have a trusted shop, as they make more money from the sale of a new vacuum, rather than a replacement hose.
Feb 20, 2011 | Miele s558 Silver Moon Vacuum
Miele W1926 washer shakes more then usual when spinning at low speeds. Could it be problem with shocks? How to open the machine? Thanks
I'd start simply.
They do move over time and if the floor is not even the machine will be out of balance.
If you have not done so check the machine is still level and all feet are solidly on ground.
Try to shake the machine by hand and see if is solid on the ground. There are leveling legs under the unit you can adjust.
Hope this helped. Please rate answer if it does.
Mar 11, 2010 | Miele W1926A Front Load Washer
I have a Miele 1926A that spins fine with out any load, but if any clothing is placed inside. The tub get seriously out of balance. I have replaced the internal shocks alredy.
the washer is probably not reaching the right speed possible cause may be your motor capacitor replace this and try again if this does not work possible control circuit problem keep me informed
Nov 06, 2009 | Miele W1926A Front Load Washer
Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Sep 05, 2009 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
21 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
