SOURCE: code chunghop RM 139ES for
The Mitsubishi TV codes for this remote are 011 and 051.
Programming instructions:
1. Switch on the TV
2. Press the "SET" button in the top-left corner of your Chunghop remote until the LED next to the "SET" button illuminates.
3. Enter the first code above 0 1 1 using the numerical buttons on the remote.
The LED next to the "SET" button will go out if you have correctly entered a code.
4. Test the remote with the TV. If it doesn't work - or doesn't operate the TV functions as you would expect - repeat the above steps for the other code.
Please note: Not all universal remotes will work with all TVs.
If the codes above don't work please post back for further assistance. It may be that your remote wont work with your TV or you may need to run the code search feature of the remote to find the correct code.
Hope this helps.
Regards,
BElectric
SOURCE: I have my universal remote
On most Universal remotes there is an Auto search function, you should try this. Check the manual for the remote it will tell you how to do this.
Hope this helps.
SOURCE: chunghop rm-309es code for sharp
Hello
Setup codes for Sharp TV with Chunghop remote are:
0044/0054/0119/0124/0196/0198/0225/0227
OK.
SOURCE: Does the Chunghop RM 133E
041, 049, 005, 094, 106, 148, 237, 238, 239, 240
these are the codes I could find for Sony with your Chunghop remote control. I hope this helps!
