Question about Microwave Ovens
Panasonic nn-t573s door button broken - Microwave Ovens
MicrowaveSvc
  • 9085 Answers
SOURCE: Panasonic NN-T687 (The Genius) door
You will need to remove the oven from the frame, then remove the outer cover from the door.
Once the outer cover's off, you'll be able to see that door opening button presses against the door opening lever, which presses up on the door key/hook to open the door.
Usually the problem is a broken door opening lever.
You can order that part directly from Panasonic here.
Once it's fixed, if you want to download the owner's manual, it's here.
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 26, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: door sticks
This is usually due to a grease buildup on the sides of the door open button or the frame that holds it.
It may also be a weak door button spring.
You'll need to remove the cover to see how the door open button works.
You can order parts here.
Posted on Jul 05, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: broken door catch, possible spring,
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Posted on Nov 27, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Panasonic Microwave NN-T785SF Door switches are broken.
Oddly enough, the switch holder is called a "door hook". For this model, it is part # F3020-1200 in case that is bad.
The hook assembly that protrudes from the door is called the "door key".
If you gently push up on the door key there should be spring tension. If it just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door key or the inner door panel.
If it's the door panel,it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door key is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the attached photo)and then you'll see the screws you need to remove.
The best place to order parts for this brand is Tritronics. Or you can call them toll-free at 866-779-5835. Their Web site will be down until Jan. 2nd.
Posted on Jan 01, 2009
SOURCE: Panasonic microwave model NN-2959: can't open door.
Your DOOR LEVER probably is broken. To open the door remove the filter (2 screws at the top) then remore the control panel by removing the screw holding it in place UNPLUG THE MACHINE. then unlatch the door. BUT I am trying to find a door lever and find they are no longer availabel.
Posted on Dec 21, 2009
Panasonic NN-SN789S
Hello, I don't know if it is helpful, but here is the manual - Panasonic Nn Sn789 Users Guide
Aug 20, 2012 | Microwave Ovens
Door release does't work
It may be a broken door open button, door open lever, or grease in the channel where the door open button moves in the control panel frame.
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
You can order Panasonic parts from Encompass here but without part numbers, it may be best to call them toll-free at 866-779-5835.
Dec 20, 2011 | Panasonic NN-H275 Microwave Oven
Door button does not function for panasonic microwave=need to know how to take the face off so that I can fix it
Take side panels off and press the button through from the back, my husband has just done this tonight on our Panasonic microwave model NN-ST477 as the door would not open. He found a piece of plastic like a hook had snapped off. The door now opens and functions normally. Took about 30 minutes to do . If and when it becomes stuck again we know that we will need a new replacement button. Hope this helpskind regardsChristine
Sep 14, 2011 | Panasonic NN-H275 Microwave Oven
Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Jan 19, 2010 | Panasonic Microwave Ovens
PANASONIC NN-S952WF FAN AND CAROSEL STILL CONTINUES WHEN DOOR IS OPENED. NOT SURE IF THE MICROWAVE CONTINUING AS WELL WHEN DOOR IS OPEN.
The door interlock system has beem compromised , meaning it shifted out of position or the interlock has broken. Dont continue using it like that it will eventually blow the fuse.
May 13, 2009 | Panasonic NN-S952 Microwave Oven
Nn t993sf
Sounds like the door switches are out of adjustment or broken.
I would take it to a shop for repair. Microwaves are almost always repaired affordably unless it is really old.
Hope ya fix it!
Feb 07, 2008 | Panasonic NN-T993SF Microwave Oven
Door will not open (no tension on botton)
This is usually a broken door opening lever behind the door open button. Sometimes it is a broken tab on the door opening button. It will require visual inspection to tell. Since this is a counter top model, the outer cover / wrapper will have to be removed to get to the door opening parts. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can order parts at one of these sites: http://www.pasc.panasonic.com/epartr http://www.vancebaldwin.com/
Mar 20, 2007 | Panasonic NN-P794SF Microwave Oven
Microwave Ovens Logo
65 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
