Question about Dryers
Roper dryer res7745pq is taking 2 cycles to dry and vent is clean?
  • 50 Answers
Check if the thermostats in rear part of dryer are covered with lint. take power off to dryer and remove back panel you will see 2 or 3 thermostats if there is a lot of lint around them carefully remove lint. if that doesn't solve problem make sure clothes are coming out of washer spun dry enough .. check lint screen on dryer. is the vent clear all the way outside ?, in winter little critters like to set up housekeeping in vents where the temperature warms them up. you can also check if heat is cycling open door to dryer and press the door button, start dryer and observe heater , it will come on then shut down and it should come back on in a minute or two, if it doesn't come back on the cycling thermostat may be at fault
Posted on Jan 26, 2009
Roper dryer red4440vq1 not drying after changing internal fuse, internal bias, high limit thermostat and thermal cut off and cleaning vent, element heats up to temp and cycles
If heater is heating and not drying clothes, you have a blockage in ventilation system somewhere either internally in dryer or going out from dryer to outside. Take vent off back of dryer and turn on. Is air flow strong and hot?
Sep 15, 2017 | Roper Dryers
Takes 2 cycles on high to dry cloths. i hooked osiloscope up to it and it will draw 22.5 amps for about 25 seconds and bounce between 2 and 7 amps for about 90 seconds and keep repeating this way (on high...
Hello. Generally, when clothes take a long time to dry the problem is excessive lint in the exhaust pipe. pull the dryer out from the wall, disconnect the vent pipe and remove lint going to the outdoors and also back inside of the dryer. Regards, joe
Dec 07, 2009 | Roper RES7648E Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Takes three cycles to dry
you may need to take apart the dryer and make sure that the exaust line isnt clogged up with lint,paper,ect.
May 15, 2009 | Roper REX3614KW Electric Dryer
Dryer steaming up my house
ck vent againalso be sure dryer is not pushed back too far crimping vent double ck leave rear vent hose off and dry a load ..may be some lint and moisture in house but if dryes in mormal time will confirm vent problem ..vent may only be partially blocked also look for hole in vent hose or better yet replace entire vent hose
Oct 27, 2008 | Roper RGX4634KQ Gas Dryer
Roper dryer
if you are sure vent is ok ..did you try a load with vent disconnected??...there is a chance there is something blocking air flow in lint screen/blower housing ..remove the 2 screws under filter remove all back screws remove 4 screws holding blower housing in place then can pull complete housing out back
May 18, 2008 | Roper REX4634KQ Electric Dryer
Needs 2 drying cycles
I am assuming you are cleaning the lint filter. Check the vent pipe out the back. If it vents into the wall, the piping leading to outside may be plugged. Your washer is spinning the clothes good, right? If the clothes are excessively wet they will take longer to dry also. If its practical, remove the vent hose and let it dry blowing into the room. It may suck but just once for a test.
Mar 06, 2008 | Roper REX4634KQ Electric Dryer
Roper dryer ot drying very well
try cleaning out your vent hose that runs from the back of the dryer to the outside.
Feb 19, 2008 | Roper REX3614KW Electric Dryer
Dryers Logo
140 people viewed this question
Top Dryers Experts
