Question about Water Sport
How can i make sure the tow rope doesn't get caught in the propellor of my boat?
    New Friend:
  • 103 Answers
The most important rule is not to go in reverse while you have a tow rope out. also, when you are throwing the handle to the skier/boarder, coil the rope and keep it away from the prop
Posted on Jan 20, 2013
How do you start 1993 bass tracker?
Bass Tracker? Bass Boat? If its a tiller motor, yank the rope until it starts, or, your arms fall off, whichever comes first! If its electric start, check your batteries are good & fully charged. Make sure your "kill" switch is connected & you're in neutral. Turn the key. In fact make sure you're in neutral for the tiller motor also.
Apr 28, 2016 | Miscellaneous
Tip
Not all ropes are created equally
Choosing the wrong type of rope for the purpose you are going to be using it for can result in injury and / or broken property. It may seem to you that some ropes are a little thicker than others, or that some feel stronger than some others. It is very important that you know what you are going to be using your rope for and doing a little research before you walk into a hardware store and blindly buy just any rope.
For water skiing the ropes that come with the ski isn't made to handle shock loading, this is when the rope goes completely slack and then get taught very quickly. This can lead to injury should the rope snap. This is why many water skiers and water tubers go out to buy replacement ropes.
There are many different strengths of towing ropes and cables, the recommended strengths for tubing are 3,350 lb. break strength, 4,100 lb. break strength and 6,000 lb. break strength. A regular rope that you might pick up at a hardware store might only have a break strength of 1,350 lb. which is not strong enough. Also when you buy the rope specially made it will have the knots already in the rope so you don't have to tie them yourself. When you do tie the knots yourself it tends to reduce the strength of the rope.
Its always better to be safe than sorry. When it comes to safety in a water sport don't take your chances with the cheaper rope, buy the right stuff!
on Jan 05, 2014 | Water Sport
How do i remove the propellor shaft
Hi Herman
We'll need to clarify your question from the posting place in Cars & Trucks. .
  • If you're really asking about a propellor shaft, you're driving a very unusual vehicle (or a member of the License to Kill MI-6 group ;-) ).
  • If you're talking about something like a boat motor, it'll be more appropriately posted in a boat section.
  • If you got zapped by auto-correct, and are looking for help with something like a driveshaft, camshaft, or crankshaft, then we'll need you to post up some more specific information about the year/make/model of your vehicle and which part we're talking about. Any of those shafts on any vehicle will be a very involved project.
Hoping a re-posted question with more detail will help us help you (It'll get better response if you re-post instead of just replying to this thread)
Happy Holidays
D
Dec 14, 2015 | Cars & Trucks
Cant get forward gear,
check the rubber bushing in the prop as it tears when the prop is jammed
if there is no rubber bush there will be a shear pin in the shaft that will be broken
Jun 12, 2015 | Boating
Towing capacity list
1st. Is this vehicle ABLE TO HANDLE what your towing ! 2nd. make sure tires are up to specs in both air & amount of Plys in sidewalls(need more than a 2ply , if boat is heavy..) make sure your rear end of vehicle is not Sagging to the GROUND. ( SPRINGS !Air shocks help alot !) If all is good , Try Moving load a little (INCHS) forward or Back in Trailer . after all this you should be fine, good luck. My Olde '78 Electra Still is the Best Boat Puller I EVER SEEN(403, turbo 400, 3.25 locker, rear Cargo Coils , rear Sway bar, & Air shocks) Steve , 62yr. old Life long Wrench.... Good Luck.. ..& Don't Forget Extra cooling for both Engine & Trans... .
Mar 28, 2014 | 2009 Jeep Grand Cherokee - 3.7L V6 -...
Boat propeller shaft seems to bind
Fishing line/net or another rope in the propellor??
Jul 17, 2017 | Boating
Is there any safety rules to tell my kids when they go out tubing relating to tow cables?
  • Make sure the person you put in charge of the rope knows how important their job is.
  • Always keep a toolbox on board with a knife to cut lines / ropes. You may want to start shopping atToolSource.
  • When in salty water swimming a boat out of shallow water wear shoes in case you come across an oyster bed.
  • Keep a marine first aid kit on board to patch feet cut on oyster beds.
  • When your kneeboard/wakeboard rope is cut or broken you can use a regular ski rope and just shorten it. It works like a charm.
taken from http://waterski.about.com/library/weekly/aa060198.htm
Feb 20, 2013 | Water Sport
Where can i find a tow cable that is: 50' 1500 lb?
iboats.com
http://www.iboats.com/1-Person-50-Tow-Rope-1500-lb-Rating-Airhead/dm/cart_id.371468676--session_id.922598044--view_id.166429
Need to replace my fuel line from my gas tank to my outboard engine.The tank runs under the floor & the length of the boat 17ft.any help or suggestion will be welcomed
attach a small rope to one end and pull the old line out reuse the rope to pull new line in and reattach at both ends
Oct 26, 2010 | Boating
Can I tow a car from Warwick to London with a rope from another car, route is M40 Thank you
Towing a car with a rope is dangerous, and illegal over here. If the front car has to stop, you now have at least two wrecked cars and at least two injured persons. It is a relatively new car, surely one or the other person has the wherewithal to hire a real tow vehicle or rent a tow bar made for that purpose. The tow bar maintains a constant distance between the vehicles.
Apr 09, 2010 | 2008 Mini Cooper Clubman
Water Sport Logo
838 people viewed this question
Top Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
