Question about Bosch Dryers
Bosch logixx dryer no heat
Not heating
SOURCE: My Bosch Condensation dryer (W2L 5400) won't heat up -- can't find the reset button
you need to remove the centre metal plate,after powering off the dryer. The small red reset button is on one of the black plactic connects on my model (WTA4408)
Posted on Jun 04, 2008
  • 7 Answers
SOURCE: Hi,there is no heat coming from my Bosch Tumble Dryer
USUALLY A FAULTY THERMOSTAT OR HEATER ELEMENT ASSEMBLY
Posted on Apr 10, 2009
  • 255 Answers
SOURCE: My Bosch dryer spins but does not heat up. It is
Most likely it is the thermal switch that is located near the heating elements. This switch is the device that regulates the temperature. When it goes bad, it remains open usually. Short of a burned heating element wire, this is probably it. The only other thing it could be is the switch on the end of the motor. This switch turns on the heating element only if the motor runs. Check that too. Good luck.
Posted on Nov 28, 2009
heatman101
  • 43501 Answers
SOURCE: Bosch nexxt 500 plus dryer does not heat up. I
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 28, 2010
  • 414 Answers
SOURCE: have a Bosch logixx condenser dryer. key sign on screen
You have activated the child lock, basically you have held the start button for over 3 secs. turn the dryer to the cycle you want and keep your finger on ther start button to deactivate. If this doesn't work you may have a module problem. Double check your manual for child lock info. if no module go to link and enter you Enr number.
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Posted on Jul 07, 2010
Bosch Logixx 8 Washing Machine E-NR-WAS28466GB /03
The heqating element has blown - common problem on our machine - happens around once per year - under warranty - now on our 3rd new heating element !
Mar 17, 2010 | Bosch Washing Machines
Not heating up
some times the heating coil breaks or the thermal resistor goes bad
Nov 02, 2009 | Bosch Logixx WFT 2806 Front Load...
No heat during drying cycle
your heating element or the thermostats that control the heating element could be bad. research no heat for your make of dryer, it should show how to ohm the thermostats and element for fault. They should all read 000 when ohmed. 000 being a complete circuit. I have been having thermal fuse problems with my whirlpool dryer, so I'm learning as I go.
Oct 22, 2009 | Bosch Logixx WFT 2806 Front Load...
How do I change the heating element on a Bosch wfd 2460?
go through this link to know your product better before fixing it:
http://www1.epinions.com/review/Bosch_WFR_2460_Axxis_Washer/content_84131024516
Jun 08, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch Worcester boiler, central heating not working
boiler may need more pressure in system pressurise to middle of green between 0.5 bar and 1.0 bar
Feb 22, 2009 | Bosch Logixx WFT 2806 Front Load...
Bosch Logixx vented dryer not working correctly
I had the same problem.
I took of the cover on the back and found the heating element had blown. I just replaced it for a fraction of the cost of a new drier, just unscrewed it and conected the two wires easily.
Jan 25, 2009 | Bosch Logixx WFT 2806 Front Load...
Washer dryer
Here is the link for a manual for your washer/dryer if you need it; https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM sounds like the heating element has failed, or just possibly the thermostat for the hot air. follow this link for a list of spares if you want to try it yourself, or for bosch repair centre details if not. http://www.bshappliancecare.com/Bosch/boschspares.html ask if you want to do it yourself for any guidance you need. Hope this helps :)
Sep 29, 2006 | Bosch Logixx WFT 2806 Front Load...
Dryers Logo
14 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
