Question about Maytag Neptune MAH5500B Front Load Washer
My Neptune washer is leaking water from underneath.
I was told it's a hard water problem and that I need to replace the water valve. Is this the water inlet valve?
  • Anonymous Mar 12, 2014
    I replaced the water inlet valve, and the machine still will not stop filling with water
  • 130 Answers
Yes they are the same.
Posted on Jan 26, 2009
Bosch Axxis washer leaks underneath
take top off at back and check valve ,it should be at the top . Also check front rubber boot for rips, this is a big problem in all brands.
Nov 21, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Washer sounds like jet engine was told it is the drain pump how hard is it to replace
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jan 16, 2013 | Maytag Neptune MAH5500B Front Load Washer
Leaks water underneath - i think it only does it during the cycles that spin extremly fast to wring the water out
FAV6800A or FAV9800A correct?
If so you need to remove the front cover and try to determine if the water is coming down the Spinner Support shaft or if there is a leak in the drain line system.
I suspect with limitted info this could be a tub seal leak. with water collectig on the Clutch Pulley. Possible Tub Seal issue a big job but can be done by a basic DIY'er. I have helped others on this site replace the tub seal and Outer Tub Bearings.
If you want to DIY the fix we need to troubleshoot further and this is not the forum for that.
If you want to DIY the repair Google this phrase ""Sticky: Neptune TL Washer FAV6800AWW""" post your problem as a new issue not in the sticky and I will try to help.
Jan 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Water will not shut off when filling the tub, also when the water level is about half full water leaks (flows) from underneath the washer.
sounds like your water fill valve is bad,after awhile it gets sediment buildup inside and the valves get stuck,not a hard job to replace it,and as for as leaking ,it could be a hose,your main tub seal in between the drun and transmission could be leaking!
Jan 15, 2010 | Washing Machines
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
About 1 minute into the cycle water starts running out from underneath of the washer. Checked all the hoses that are connected to the back and none are leaking
this is either the front seal that goes from the outer tub to the front of the washer or a hole in the outer tub itself or one of the hoses underneath the seal and the hoses are easiest to check you can take a cup of water and slowly pour it into the front seal. take care not to overfill it to where it spills into the tub and see if you are getting water on your floor from that. the hoses tip the washer up onto its back and look at them from the bottom for any cracking etc. the tub itself can only rust out on some of the neptune models or on others is plastic and can get punctured. just have to look for damage with a light and a mirror.
May 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
"nF" error code at end of cycle, and water leak
nf means u have a bad water valve u may also have a bad hose underneath the lid as well if u have water in your control
Mar 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer is leaking while it is just setting still.
The first thing that I would check, is the hot & cold water hoses, that connect in the back of the washer, to see if they are tight. If they are tight and still leaking from there, then the rubber washer, inside the brass fitting part needs replaced. If that doesn't help, then disconnect the power, and water hoses, then turn the washer over and check the water hose underneath, to see if its leaking. One of these hoses has to be the problem.
Jan 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leak well after completion of wash cycle - Neptune Front Loader
peace,
ngafm1 at your service,
Water sprayed out of ( the leaky washers in the hot water shut off valve which need to be replaced.
They are inside all valves and wear out in time from normal use!
Or you can have a bad solder joint at the junction between the hot water shut off valve or the the pipe joint!
these washers in any shutoff valve can leak intermittently till they get worse and then leak all the time!
you should be able to stand there and watch it as you open and close the shut off valve again and again , and then stay there and watch it start leaking!
Or when you are opening it and closing the valve 4 times straight you may feel a trickle of water from the valve stem!!!!
This means washers in the valve stem need to be replaced!!!
Get a new plumber !!!!!!!!!!!!!!!!!! I'm no plumber but I do under stand this!
Bless You,
please give me a good rating here at fixya.com before you sign off!
Aug 01, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Leaking waher
water can leak from the other valve while filling up if you dont have the hose on it,if you blank the valve off with a nut and tail with a coin and rubber washer in it that will fix your problem.hope this helps.
Mar 09, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
162 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
