Question about Icom Programming Cable Clone Usb F50 F60 F70 F80 F3161 F4161 Opc-966u
Cloning cable icom f60 - Icom Programming Cable Clone Usb F50 F60 F70 F80 F3161 F4161 Opc-966u
Cloning CS-F50 using usb port
Do you have a USB programming cable for the radio? If not, get a USB to serial adapter and plug between the computer USB and serial programming cable. Adapter driver will help with the interface.
Jun 09, 2014 | Icom Cs-f50 Programming Software Ic-f50...
Icom ic fr5000 clone NG whats is solution for this?
Clone means that you are copying radio program from one radio to another of the exact same radio. For some reason the other radio did not take the information. The radio may now need to be re programmed and not cloned in order to work.
May 20, 2014 | Radio Communications
Adjust the squelch
Press the Mon and adjust the squelch level by moving the ch knob
Mar 15, 2014 | Icom IC-F60-81-DTC Two Way Radio UHF
Manuals free download
Go at site mods.dk (Member Maintenance, it is free)
Jun 06, 2013 | Icom Cs-f5021 Programming/cloning Software...
How to program scan in the software
OBD2
OBDii
Best Car Diagnostic Tool
This websit about:
AUTOCOM
Auto Engine Diagnostic Tool
Auto Injector Cleaner
Auto OBD Tool
Auto OBD Tools
May be able to help you!
Dec 27, 2012 | Icom Cs-f5021 Programming/cloning Software...
Programming issues with Icom F21
What you have is a programming issue. The radios need to be "cloned" so they will all work together. You can buy the software on line for about $65.00 then you can change frequencies when ever you want.
Nov 17, 2008 | Icom IC-R5 Handheld Scanner
ICOM IC-A23 CL-ERR Problem
My neighbor just had this problem so I delved into it and fixed it.
You will need another working radio and the cloning cable.
DO NOT GO BUY ONE FOR 23 BUCKS PLUS SHIPPING!!!!!!!
This cable is nothing more than the same one you use to pipe your MP3 player into a car's AUX input.
You either have one or know someone who does that you can borrow.
If not go buy one from Sears ,Best Buy or any decent truck stop should have them for about ten bucks.
Turn both radios off.
Now with the 3.5 mm cable plugged in to both radios hold down the up and down arrow buttons and turn them on.
They should say "clone".
Now press the" ENT" on the good radio,
This will send the data over to the "bad" radio.
Now turn them both off, remove the cloning cable and turn them back on.
Both should be working now.
\WARNING if your battery is in bad shape it can cause the problem to come back. Either deep six the battery or hit the battery for a few seconds with your car battery charger to shock the cells.
Some times this can extend the battery's life.
Good luck!!
Rich
Dec 27, 2007 | ICOM Informatique IC-A23 VHF NAV/COM Air...
Icom Programming Cable Clone Usb F50 F60 F70 F80 F3161 F4161 Opc-966u Logo
27 people viewed this question
Top Icom Radio Communications Experts
peter0911
Steve
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
