Question about Garden
Bosch Aquatak Eco Oil Leaking - Garden
4 Suggested Answers
SOURCE: bought bosch aquatak 100 pressure
Contact Bosch directly, they have been very helpful in the past.
Robert Bosch (Australia) Pty Ltd
1555 Centre Road
Clayton, VIC 3168
Phone: (03) 9541 5555
Fax: (03) 9543 5485
Posted on Jan 20, 2011
SOURCE: water leak from main housing
Any solutions Paul. I have the same problem
Posted on May 31, 2011
  • 316 Answers
SOURCE: I have a Bosch aquatak 120i the motor keeps
Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of time,not draining hose & machine, in the winter time the hose & pump will freeze causing hose & pump to expand and burst.handle to leak busting the o rings, build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps.thankyou. ~~
Posted on Feb 19, 2012
What is the quantity & the type of oil of Bosch Aquatak 10 pressure washer? Thanks
The link has changed in the meantime i see
You can use every EP zinc-free hydraulic oil what you want for it PERLUS ZF46 is a very good alternative
Jun 19, 2016 | Garden
Not using shampoo
use nozzel with big hole or open nozzle up if adjustable
Apr 20, 2014 | Bosch AQUATAK 150 PRO X Pressure Washer
Can't attach lance securely- falls off
replace lance or soak lance in solvent .
Feb 19, 2014 | Bosch Garden
Bosch aquatak power washer will not start
Check to make sure the outlet (power supply) is energized. This piece of equipment is supposed to be used on a ground-fault protected circuit, so make sure the ground-fault on the outlet didn't trip or the circuit breaker (fuse) at the electric panel did not trip (or blow)
Check to make sure you are going through the proper starting procedures as outlined in your user's manual on page 8.
Follow the troubleshooting tips on page 10 of the user's manual.
Beyond that, Bosch requires that you have your power washer repaired at an authorized / qualified repair center.
I did locate a web site that shows an exploded parts view of the pressure washer, if that helps. http://www.magic-parts.co.uk/acatalog/BOSCH-Aquatak-1200-Plus.php
In case you don't have a user's manual, you can view it at: http://www.manualslib.com/manual/537062/Bosch-Aquatak-110.html#manual
Best wishes on your project.
Nov 08, 2013 | Bosch AQUATAK 115 PLUS Pressure Washer
A blockage in the inlet of an aquatak 115 plus.
nothing to worry about could be due to water intake,wear on nozzle or just the gauge
Oct 14, 2012 | Bosch AQUATAK 115 PLUS Pressure Washer
Bought bosch aquatak 100 pressure washer. No manual or instructions in box. Store bought at cannot help.
1555 Centre Road
Clayton, VIC 3168
Fax: (03) 9543 5485
May 07, 2009 | Bosch Washing Machines
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
