Question about Jamo ART Speaker
Jamo ART Speaker - Jamo ART Speaker
Hi,,is there a Jamo service center here in Davao City? My speaker need a repair.
Hello i am from outside the States but i know any KLIPSCH service center is maybe the place for JAMO or they know for sure where you should be in your Country.
Jamo About Jamo About
Sep 23, 2015 | Jamo Audio Players & Recorders
Why won't my a102 speakers from jamo witch came
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Sep 01, 2014 | Audio Players & Recorders
What is the impedance of the JAMO A3SUB.3 speaker?
22K is the impedance listed in the specs but you may have to look on the actual speaker itself to get the impedance of the physical speaker.
Sep 15, 2012 | Jamo HOME THEATER PACKAGE, 4 X A320,...
I have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
Sep 13, 2012 | Jamo SUB 200 Subwoofer
Need to replace 5.5" woofer in Jamo S426 floorstanding speaker
contact maplin electronics they are really good at replacement units.
Jun 30, 2012 | Jamo S426HCS3 5pcs Home Theater Speaker...
Would this speaker work in the jamo gf-25 ?? and if not does any one know what will ?
hi,
it will not be a perfect mach. u have to purchase a speaker with long term power handling capacity of 150W and 4 ohms impedance.
ok
Jan 06, 2011 | Jamo 8.5CS Main / Stereo Speaker
I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Mar 15, 2008 | Jamo 1060 SW Speaker
Jamo subwoofer issues
hai iam hans i had also a problem with the sub
turned out jamo denmark didnt had the spare parts to fix it?
can u believe that
so i wait 6 weeks and after 100 phone calls to denmark and my local dealer they deside to take the part out of another sub ?.
but i really had to make a a lot of effort to achive this
but for the price the jamo set is exellent
a shame about the service .
Jan 14, 2008 | Jamo A 102 HCS 5 System
26 people viewed this question
Top Jamo Audio Players & Recorders Experts
Electro Med Services...
Tom Chichester
Steve
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
