TONER MARKS ALONG LEFT SIDE OF COPY
EVERY COPY WE DO HAS TONER HASH MARKS DOWN THE LEFT SIDE OF THE COPY. ANYONE HAVE ANY IDEAS ON HOW TO CLEAN UP WHATEVER IS LEAVING THE TONER MARKS THERE?
THANKS,
**** HATCHIK
  • 4 more comments
  • switchtech Jan 27, 2009
    I have a 1023iF with the same problem
  • Anonymous May 04, 2009
    long toner mark on left side of paper on all copies
  • John Cole
    John Cole May 11, 2010
    It sounds like that toner got on to the fuser and is burnt on there causing that. Now are the lines random or is in seem like a pattern?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Does the green drum have any black lines on it?
  • Tim Babcock
    Look at the drum and see if there are any black marks on it. Do you see any?
  • Mike May 11, 2010
    its either the drum/toner unit or the fuser unit. What machine is this?
  • 77 Answers
Let me know the make & model. there may be a toner dposit in the paper path.
Posted on Feb 21, 2009
When i copy a document it comes out with black marks along the left hand side of the copy about 1/4 inch into the copy.
Clean the printer first, if that fails to cure the issue replace the toner. You gave no make, or model number of the printer so I assume it uses a Toner drum as that is the most common complaint for that type of printer.
Feb 23, 2017 | The Office Equipment & Supplies
Smudge marks on left side of paper?
If you use new original toner, this should not happen, nevertheless, clean the drum first.
Sep 04, 2014 | Brother Laser Printers HL5450DN HL-5450DN...
Toner marks
Your Drum Cylinder has a scratch or clot of toner stuck to it. Every time it rotates along the page (usually 4 rotations per A4) it leaves a copy of the defect on the page. If you take the toner cartidge out of the drum unit, you will be able to turn the drum cylinder until you find the fault. Either replace the drum unit or CAREFULLY clean it with alcohol on a cotton ball (meths or iso propoyl will do) in the case of a toner clot. If the fault recurs quickly after cleaning, then you have a damaged drum and it should be replaced.
Best of luck.
Mar 20, 2014 | Brother HL 2140 Laser Printer
My printer is leaving toner "tire marks" up and down the right and left side of the page margin as well as spilling uneven blotches of toner along the right side of the paper.
Your printer needs cleaning. Consult your printer manual on how to clean it. If you do not have the manual, you can usually download it from the printer manufacturer's website.
Apr 23, 2010 | Dell 1700n Laser Printer
I have a HP Colourjet 2600n which has worked well for 12 months plus. However it has just started printing with thick black smudges along the left of every page. It looks like there is yellow powder...
If you have BLACK Marks on the paper the YELLOW roller does not need to be cleaned usually.
To clean the yellow toner off the roller use a DRY lint free cloth. For this issue my suggestion for a resolution to the Yellow toner issue is replace the toner. They are not supposed to leak in the first place.
As for the BLACK tone on the left of the page you most likely have a Fuser issue causing that.
Jul 27, 2009 | HP Color LaserJet 2600n Printer
HP LaserJet 2600n
Yes, u can just clean the drums , I means the rolls inside the printer, just open the printer door , then remove the cartridge , then u can use tissues with a little of alcohol to clean the rubber rolls inside .
Feb 03, 2009 | HP Color LaserJet 2600n Printer
Oki C5500 printing a yellow stripe
1) clean LED heads with Alcohol swab.
2) Check fuser rollers for dirt, smudges. Clean with swab.
3) Remove all toners/drums and check for spilled toner. Vacuum or wipe clean.
4) Check tansfer belt for marks, stray toner, creases.
4) Re-seat toner and drum cartridges.
Nov 23, 2008 | OKI C5200n Laser Printer
1320n marks along left side of paper
repetitive defects are caused by either a ding on the drum in the toner, a scratch or dirty transfer roller, or scratched or dirty heat roller in the fuser, Last but not least is dirty exit roller. the first step to any print quality defect is to cahnge the toner cartridge. Good Luck!
Aug 04, 2008 | HP LaserJet 1320 Printer
Black smudge marks along left side edge of paper.
Its probably a defective toner. If the film on the toner drum is scratched it can cause toner to stick to the drum everytime it spins causing the constant marks.
Jul 08, 2008 | HP LaserJet 1320 Printer
Yellow line on edge of page
on a ricoh - that would be the pcm - photoconductor module on an ecosys the module should last 100,000 pages nothing ever seems to last that long send an email to http://www.pcandl.com/ or call where you bought it
Aug 07, 2007 | Kyocera Mita FS-C5016N Printer
115 people viewed this question
k24674
jasbo
jasbo
