Question about Rangemaster 110 (Gas) Kitchen Range
Oven not reaching maximum heat
The oven takes much longer (about half an hour) to warm up and if the regulo is set to regulo 8 or 9 cannot reach the maximum temperatures
    Top Expert:
  • Rangemaster Master
  • 9,472 Answers
What is the model number?
Posted on Jan 20, 2013
5 Suggested Answers
derrickbohan
  • 90 Answers
SOURCE: the right hand oven lights, but no matter which
the flame needs to be adjusted there's a small screw right inside of the shaft where the knob goes. Pull knob off and there should be a screw inside that u shaped shaft. Turn the burners on and set the flame accordingly.
Posted on Dec 16, 2010
SOURCE: Rangemaster 110
Reading the user manual, it states that the flame initially comes on low, until it is "sensed" by the flame sensing device. This to me sounds suspiciously like the flame isn't being sensed and so never gets increased to the normal level.
I've not had time for a proper look at it.... but from a quick glance this morning this looked like a "flame rectifier" probe next to my burner (as we commonly use in boilers to sense if the gas burner is lit). This is just a metal probe. They send a high-ish AC voltage signal (Sine wave) from it, through the flame, to the earthed metal case. The flame acts like a diode (yes it really does work !) and simple electronics detects the change in the applied signal (rectified) due to the flame. I know from personal experience they (the probes) get coated with crud (carbon, etc) and need a good clean. I suggest you try cleaning both it and the metal area opposite it. If necessary the probes metal tip could be GENTLY rubbed with very fine Emmery cloth, etc, if badly coated.
Other than that, if it is sensing the flame, then it must be the gas control device (solenoid valve ?) that is jammed, blocked or just defective.
Simples......
Posted on May 19, 2009
  • 1340 Answers
SOURCE: both ovens don't reach their proper temperatures.
I found your oven on a site I often use which has electrical diagrams that I can read.I did see that yours is available in both gas and electric.Would you please tell me which one you have?Also,how far off are the temperatures for which you want from what it goes to?Do both sides react the same?For example,set both sides to the same temperature.Do both sides stop working at the same temperature or different ones?If they are different,I would like to know what temp. you set and what each one cut off at,or even if they cut off at the same temp. for that matter.If I can figure this out,you may be able to order the part and fix it.If you bought this in Australia,there should be someone,somewhere who has parts for it unless it is about 15 years old or older.That would make it difficult.I have been to Perth when I was in US Navy and thought it was pretty nice and I would like to see more of Australia someday.I see some of the wildlife there on TV,but there's nothing like in person.Wild budgie flocks.Here we have quaker parrot flocks.Greg
Posted on Nov 04, 2010
Testimonial: "Thanks Greg. I must have the wrong manual because both my ovens are gas! Eeek! I'll keep ringing gasfitters here, but thanks for your help anyway."
ginko
  • 19396 Answers
SOURCE: My right hand oven will not reach the desired
Hi.
Hi regarding the bulb and the wire, and the gas pressure problem due to the defective 'gas tap' (probaby the pressure regulator), if the gas tap is not built in with the appliance, then it is probably a part called pressure regulator, that can be purchased alone from any part seller in Fr. If the gas tap is instead the burner inside the oven call Rangemaster (see below)
If the technician saw a defective burner or pressure regulator, than that is likely the problem. We check the colour of the flame to understand if there are gas mixture or gas pressure problems. Make sure that the temperature probe inside the cavity has also been tested. It must read about 1080 Ohms when you test impedance with a multimeter.
Parts for older appliances from this manufacturer are not available in France but they may be purchased from UK Rangemaster central. They should be able to ship in France.
Here the link Customer Support
Here different reseller distributing Rangemaster parts. Drop them an email:
Rangemaster™ Spare Parts
Currys partmaster.co.uk
Regards.
Ginko
Posted on Sep 22, 2011
Siemens oven not heating to high temperatures
possibly,but i would check both upper and lower elements are working first, lower element is hidden so test from the back with a multieter after removing oven fuse from the power box
Feb 03, 2018 | Siemens Ovens
Oven not heating properly
Sensor
must read 1100 ohms at room temp. If open or shorted that is yer probo. Could also just be a greasy quick connect not making a good connection.
Jan 10, 2013 | Electrolux EI30EF55GS Electric Range
I used my frigidaire self cleaning setting for the first time. It cleaned the oven well, but now the oven will not heat up properly.
useing a flashlight look over the elements top and bottom you are looking for a type of damage like bubbles or brakage , get back to me Frank
Dec 15, 2011 | Frigidaire Professional Series 24 in....
I set the oven at 350 degrees and after 3 hours it has only reached 185 and won't go any higher. The oven is approx. 8 years old.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 25, 2011 | Ovens
Oven will not start correctly
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jun 09, 2010 | GE JGRP17 Gas Single Oven
MY OVEN wont heat up. its takes at least an hour
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 28, 2010 | Ovens
Oven does not heat but broiler does.
hello mam please visit the manufacturers website there you can find it.
Oct 08, 2009 | Kitchen Ranges
15 yr-old GE electric oven takes over an hour to preheat to 450
After jiggling the lower burn element the oven heated up in the normal time. Perhaps a connection had come loose.
Feb 14, 2009 | GE JEM25 Microwave Oven
Slow warm up
hi petrich let me know if you had your voltage to the oven checked. is must be the problem to have two ovens slow to heat up... let me know..krazytech
Aug 25, 2007 | Elan E-948-DB / E-948-DW / E-948-DS...
Rangemaster 110 (Gas) Kitchen Range Logo
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
