Question about Refrigerators
Specifications of A11HV and A2270 necchi compressors?
I am looking for the specifications of old A11HV and A2270 necchi compressors? What horsepower are they?
  • Mehmet Ali Talat
    Mehmet Ali Talat Jan 23, 2013
    The category "sewing machines" is misleading. Excuse me for that. But this category has been assigned by the web site. Actual category is "refrigeration". And my question is regarding compressors...
  • Mehmet Ali Talat
SOURCE: Specifications on a HP Motherboard
Dependant on your location try the HP support website. Input your Product information. Such as your computers Model.
It will either take you too straight to the computer specifications page, of which you will be able to look at your motherboards model.
If not: it will take you to a selection of models that are closest to your search and then you can select your HP computer from there.
Link:
http://welcome.hp.com/country/uk/en/support.html
^^ The link above relates to the UK version of the HP support Website ^^
You can ethier click the link or Copy/Paste into your website browser
Thank you. Ghostcc2
Posted on Feb 01, 2008
SOURCE: need valve lash specifications for Model 6076AF-00 (L)
Dear Sir or Madam, We have the pleasure of contacting with you today. We get your name and email address in internet and now would like to have a brief introduction about our company for your understanding. We are professional valves manufacturers and exporters in China, our main conditions are as follows: 1.Product: ball valves, gate valves, globe valves, check valves, etc. 2.Standard: API, DIN, JIS, GB. 3.Material: WCB, LCB, CF8 304, CF8M 316, CF3 304L, CF3M 316L, WC1, WC6, WC9, CN7M and so on. Should any of these items be of interest to you, pls feel free to contact with us or visit our website: http://yjjinglian.cn.china.cn., we will be happy to give you details. Look forward to your specific enquiries and hope to have the opportunity to work together with you in the future.
Best Regards
YONGJIA JINGLIAN VALVE CO., LTD.
TEL: 86-577-67952090
FAX: 86-577-67981377
E-MAIL: wu.zan@hotmail.com.
WEB: http://yjjinglian.en.china.cn
MSN: wu.zan@hotmail.com
Posted on Apr 10, 2009
  • 113 Answers
SOURCE: have an old model orion amp needing specifications
the specs are as follows
250watts x1 at 4 ohms
400watts x1 at 2 ohms
600watts x1 at 1 ohm
it is bridgeable and has a 50 amp maxi fuse
Posted on Jul 06, 2009
SOURCE: what are the specifications of ingersoll rand
irtechpubs.com/.../Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/SCD-749.PDF
Above is the parts manual and specs for you.
Posted on Aug 18, 2010
emissionwiz
  • 75005 Answers
SOURCE: HEAD TORQUE AND SPECS FOR A 2001 HONDA ACCORD 2.3L
Tighten the cylinder head bolts. Tighten the cylinder head bolts is sequence to 29 Nm (3.0 kgf-m, 22 ft. lbs.). Use a beam-type torque wrench. When using a preset type torque wrench, be sure to tighten slowly and do not overtighten. If a bolt makes any noise while you are torquing it, loosen the bolt and retighten it. Make sure the threads are clean, new heads bolts are best.
Posted on Oct 29, 2012
What are the specifications for the dodge eco diesel engine?
Displacement: 3.6 L/220
Engine Order CodeERB
SAE Net Torque @ RPM269 @ 4800
Fuel SystemSequential MPI
Engine TypeRegular Unleaded V-6
Engine Oil CoolerRegular
SAE Net Horsepower @ RPM305 @ 6350
2015 Ram 1500 The 3 0L EcoDiesel 6 Engine Was Made for Maserati Leith CDJR
Feb 15, 2015 | Dodge Cars & Trucks
Torque specifications for head on a 2003 50 horsepower Johnson outboard motor
Good Morning.
The Torque For Cylinder Head Screws Is:- 25-27 Nm-(18-20 Ft.Lbs)
Regards
Gordon
P.S.Please Rate Answer.
Jul 21, 2014 | Boating
Old boat specifications
You will need to contact Department of Natural Resources in your state to be sure but in most states boats over 21' don't have a horsepower restriction.
Jul 13, 2014 | Boating
I have a Honda eu2000i generator to run a Husky TAW-1524p air compressor. Initial start/run is fine but subsequent compressor restarts as demand for air is required, put the generator into overload....
If your mechanical enough to figure out how to lower the air pressure switch on the compressor it would help with start up loads. For instances if your pressure switch is set for 75 psi. Lower this to 60 psi. or as low as you can and still operate equipment. Otherwise depending what horsepower and voltage {guessing 110 vac) the motor is, I would try an Hard start capacitor for refrigerators or air conditioners. They are rated by horsepower and have a built in relay that kicks it off automatically after starting . You can find these at any appliance or a/c & heating supply house.
May 11, 2014 | Heating & Cooling
Used boat specifications
1976 Johnson 115hp motor what oil and mix what oil to use
Jan 16, 2014 | Boating
How much micro frard will i use for air compressor 0.5 hp
I don't believe there is a standard value for a specific horsepower rating. I have serviced and replaced plenty of these capacitors and the manufacturers say it is important to use only the value that the motor is originally supplied with. I have not seen it correspond to horsepower directly. Some motors use both a start and a run capacitor and I've never seen them identical. Horsepower listed ratings can vary wildly if it is not directly listed on the motor spec label. I believe .5hp corresponds to about 6 to 8 amps at 120 volts.
Oct 16, 2012 | Air Tools & Compressors
Spray painting
It depends on what kind of spray gun you have. If you have a HVLP gun the pressure doesn't have to be as high, but you need a compressor that will keep up. The pressure is usually pretty low on these guns, about 15 PSI or less. The paint manufacture will usually give you a recommended pressure to paint their paint. A normal (old style) suction type gun takes more pressure, about 50 PSI. If you are asking this to decide on a compressor size, you will find that a one horse motor on a two cylinder compressor will not keep up. The newer supposedly five horsepower compressor will not keep up consistant pressure either. You need a five horsepower that runs on 220 and driving a belt driven two cylinder compressor minimum. You can get by on less, but have to wait half way during a coat on a car to wait on the compressor to catch up. This may be o.k. if you are just going to paint one car, but if you are looking to do this consistantly, then I would get a five horsepower motor on a two stage compressor. Make sure you drain the air tank of water and use a good air filter to remove moisture from the air before trying to paint. Hope some of this helps you.
Feb 16, 2012 | Bernina Sewing Machines
Motor size 1996 hundai
1996 Hyundai Accent ENGINE SPECIFICATIONS 1.5L 92 hp I4 Horsepower 92 @ 5500 RPM Torque (lb-ft) 97 @ 3000 RPM Fuel Type/System Gasoline/MPFI Valves/Valve Configuration 12/SOHC Displacement (cc) 1495 Bore X Stroke (in.) 2.97 X 3.29 Compression Ratio 10.0:1 Turbocharger No Supercharger No
Mar 25, 2011 | 1996 Hyundai Accent
2000 Grand Am GT: I need the firing order diagram for a 2000 pontiac...
2000 Pontiac Grand AM 3.4 liter V-6 VIN "E"
Hope helps (remember rated this).
May 17, 2010 | 2000 Pontiac Grand Am GT
Air Compressor question
No, When an air compressor is built, it requires a motor or engine to power the process of producing air. The horsepower is not the only component of the equation. It has to be combined with the compressor pump that it runs to produce the air needed. The bigger the horsepower does not necessarily mean more air. Remember to keep your required cfm in mind. Horsepower does not make you work more efficiently, but horsepower working in unison with a quality pump that produces enough cfm for your needs. Make sure when shopping that you look for the running horsepower and not the peak horsepower you get at startup. Some manufacturers have falsely advertised or implied the peak horsepower to be the normal run horsepower. At start-up, there is a surge of power needed to start the motor and can be 1.5-3 times the amount of running power needed. This means the horsepower need for the motor peaks as well, but then drops back down to normal. Many of these manufacturers are involved in a class-action lawsuit for misrepresentation. They have used man’s machismo of “the more horsepower, the better” to their advantage to make sales. These aren’t cars we’re talking about!
Aug 27, 2008 | Porter Cable 4 5 Gallons 150PSI Job Boss...
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
